		Kelly McMullen
				 Posted: Fri Nov 23, 2012 7:04 am    Post subject: GPS mounting |
				I am thinking about mounting my Garmin GA-35 antenna on top of the cabin cover just behind the rear door post area where the roof gets thinner. The antenna calls for a ground plane. (first gps ant I've seen wanting one). I'm guessing I will need both thin metal/tin foil, and a grounding wire if I do that. Just wondering what others have done. I likely will put my Dynon GPS ant under the cowl just forward of the firewall, and it doesn't need ground plane.
  Kelly
 85% done, 90% to go
A&P/IA, EAA Tech Counselor
KCHD |
				 Posted: Fri Nov 23, 2012 8:15 am    Post subject: GPS mounting |
				I mounted both the Garmin 650 and Dynon SkyView GPS antennas on top of the glare shield.  Both work perfectly and is as easy an install as you will get.  I did the same in the 8A (flying 10 years).
 Of interest, given a few minutes the SkyView GPS even locks in when the plane is inside a metal roof hangar with the metal door shut.
 Carl
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
 Sent: Friday, November 23, 2012 10:04 AM
 Subject: GPS mounting
 Kelly
 85% done, 90% to go 	  | Quote: | 	 		  |   </==================<www.buildersbooks.comwww.homebuilthelp.comhttp://www.matronic=================[/b] | 	  http://forums.matronics.com[/url]=====[/b] [b]
		n223rv(at)wolflakeairport Guest
				 Posted: Fri Nov 23, 2012 8:34 am    Post subject: GPS mounting |
				I mounted all my GPS antennas, GDL39 module, and my XM antenna under the cowl in front of the firewall.  Works awesome and probably save 8 knots of drag  ....  Well, at least I don't have to look at them....
 -Mike Kraus
 On Nov 23, 2012, at 11:14 AM, "Carl Froehlich" <carl.froehlich(at)verizon.net (carl.froehlich(at)verizon.net)> wrote:
 [quote]  <![endif]-->   <![endif]-->
 Carl
 From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Kelly McMullen
 Kelly
 85% done, 90% to gohttp://forums.matronics.com=====
 ctric.com
  	  | Quote: | 	 		  www.buildersbooks.com
 uilthelp.com
 matronics.com/contribution
 ://www.matronics.com/Navigator?RV10-List
 cs.com
		Strasnuts
  Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
				 Posted: Fri Nov 23, 2012 9:24 am    Post subject: GPS mounting |
				I had to mount one for my gts800. I used a 10x18 sheet of aluminum epoxied and riveted to cabin top first layer then blended and covered with glass cloth. Can't tell it is there at all. Couldn't use the inside of cabin top because of thickness. When I was testing I used 300mph tape and it worked as a ground plane too. I used the same tape to connect the ground plane to ground by wrapping it to the inside of the cabin top through the 1-1/2 inch coax hole.
 On Nov 23, 2012, at 8:03, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
 [quote]I am thinking about mounting my Garmin GA-35 antenna on top of the cabin cover just behind the rear door post area where the roof gets thinner. The antenna calls for a ground plane. (first gps ant I've seen wanting one). I'm guessing I will need both thin metal/tin foil, and a grounding wire if I do that. Just wondering what others have done. I likely will put my Dynon GPS ant under the cowl just forward of the firewall, and it doesn't need ground plane.
  Kelly
 85% done, 90% to go
 ctric.com
 uilthelp.com
 cs.com
  _________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
		jfrjr(at)roadrunner.com Guest
				 Posted: Fri Nov 23, 2012 9:40 am    Post subject: GPS mounting |
				I am repainting my 10 (professionly this time) and would like to use metallic paint. I have my nav and glide slope ants. in the wing tips, ADSB-IN and GRT gps under fiberglass access panels in front of the windshield, and ELT under the epi. fairing. All the other ants. are mounted externally. I have had LOTS of different opinions about metallic paint over fiberglass interfering with antenna functioning.  Does anyone have solid data or information?  Thanks, Jay Rowe 320 hours
 On Nov 23, 2012, at 8:34 AM, Michael Kraus <n223rv(at)wolflakeairport.net (n223rv(at)wolflakeairport.net)> wrote:
 [quote]I mounted all my GPS antennas, GDL39 module, and my XM antenna under the cowl in front of the firewall.  Works awesome and probably save 8 knots of drag  ....  Well, at least I don't have to look at them....
 -Mike Kraus
  	  | Quote: | 	 		    <![endif]-->   <![endif]-->
 Carl
 Kelly
 ctric.com
 uilthelp.com
 cs.com
		Jim Berry
				 Posted: Fri Nov 23, 2012 10:42 am    Post subject: Re: GPS mounting |
				Jay,
 My Nav antennae are wingtip mounted. There is no discernible difference in performance now that they are painted with a very metallic PPG paint, compared to when they were unpainted.
 Jim Berry
				 Posted: Fri Nov 23, 2012 11:08 am    Post subject: GPS mounting |
				The paint makes no difference.
 I have a homebrew wingtip VOR/GS antenna in the 10 and 8A, both metallic paint.  They work well.
 Carl
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jay Rowe
 Sent: Friday, November 23, 2012 12:40 PM
 Subject: Re: GPS mounting
 -Mike Kraus
 6789012345678
   | 	  901234567890123456789 	  | Quote: | 	 		  | =================================== | 	  0 	  | Quote: | 	 		  | =================================== | 	  1 	  | Quote: | 	 		  | =================================== | 	  2 	  | Quote: | 	 		  | =================================== | 	  3 	  | Quote: | 	 		  | =================================== | 	  4 	  | Quote: | 	 		  | =================================== | 	  5 	  | Quote: | 	 		  | =================================== | 	  6
		Kellym
				 Posted: Fri Nov 23, 2012 12:34 pm    Post subject: GPS mounting |
				I can tell you that a friend with RV-7A put a Bob Archer nav antenna in
 one wingtip, along with marker antenna, and a BA com antenna in the
 other wingtip. They worked fine until he had the wingtips painted
 metallic silver to go with his polished alum airframe. The metallic
 paint reduced the reception and transmit range to about 10 miles of
 mediocre quality. He wound up putting a CI-122 on a wing access panel to
 restore com function to reasonable range.
 On 11/23/2012 10:40 AM, Jay Rowe wrote:
  	  | Quote: | 	 		   I am repainting my 10 (professionly this time) and would like to use
 > -Mike Kraus
 > Sent from my iPhone
 > <carl.froehlich(at)verizon.net <mailto:carl.froehlich(at)verizon.net>> wrote:
 >> Carl
 >> *From:*owner-rv10-list-server(at)matronics.com
 >> <mailto:owner-rv10-list-server(at)matronics.com>
 >> [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Kelly
 >> McMullen
 >> *Sent:* Friday, November 23, 2012 10:04 AM
 >> *To:* rv10-list(at)matronics.com <mailto:rv10-list(at)matronics.com>
 >> *Subject:* GPS mounting
 >> Kelly
 >> 85% done, 90% to go
 >> *  *www.aeroelectric.com  <http://www.aeroelectric.com><www.buildersbooks.com  <http://www.buildersbooks.com>www.homebuilthelp.com  <http://www.homebuilthelp.com>http://www.matronics.com/c=                               -Matt Dralle, List         - The RV10-List Email Forum utilities such as List Photoshare, and much much    -->http://www.matronic=================  <http://www.matronics.com/Navigator?RV10-List>
 >> <http://www.matronics.com/Navigator?RV10-List>=====
 >> ctric.com  <http://ctric.com>
 >> uilthelp.com  <http://uilthelp.com>
 >> matronics.com/contribution  <http://matronics.com/contribution>
 >> ://www.matronics.com/Navigator?RV10-List  <http://www.matronics.com/Navigator?RV10-List>
 >> cs.com  <http://cs.com>
 > ctric.com
 > uilthelp.com
 > cs.com
 Checked by AVG - www.avg.com
KCHD |
		Kelly McMullen
				 Posted: Fri Nov 23, 2012 1:08 pm    Post subject: GPS mounting |
				Any concerns about heat? Anyone actually measured temps between engine mount and firewall? Of course any engine fire could get real expensive in a hurry if it damaged those units.
 On Fri, Nov 23, 2012 at 9:34 AM, Michael Kraus <n223rv(at)wolflakeairport.net (n223rv(at)wolflakeairport.net)> wrote:
  -Mike Kraus
 Carl
  Kelly
 85% done, 90% to go http://forums.matronics.com=====
  | 	    	  | Quote: |
 _blank">www.aeroelectric.com
KCHD |
		Bob Turner
				 Posted: Fri Nov 23, 2012 1:38 pm    Post subject: Re: GPS mounting |
				Jay and others: if the "metallic paint" actually conducts electricity (put an ohmeter on it) then it will affect the internal antenna's reception. However if the paint has tiny metallic flakes which are insulated from each other by the rest of the paint then the effect will be much smaller.
 Fiberglass top ground plane: There is no need to run a wire to the airframe. All of the currents in the ground plane should flow in and out of the coax ground shield. (The ground plane looks like a "mirror" to the vertical antenna, and acts in the same way). However, I would be concerned with a ground plane on the inside of the cabin and the antenna on the outside. They should be close to each other, close meaning in terms of wavelength. GPS is at 1.6 GHz which has a wavelength of 20 cm. I'd want the ground plane within 2 cm, minimum (3/4"), closer is better. How thick is the top?
  _________________ Bob Turner
RV-10 QB |
		Kelly McMullen
				 Posted: Fri Nov 23, 2012 4:47 pm    Post subject: GPS mounting |
				I have yet to understand why a GPS antenna needs a ground plane, when those in handhelds, Ipads, etc work great without one. Given the size of the antenna one would expect a full dipole rather than a quarter wave. Dynon's antenna/receiver is smaller than the Garmin antenna and needs no ground plane.
  I would guess the area of the top I am looking at is around 1/3-1/2" thick, not the area around the doors that is probably 1.5" thick with the foam sandwich.
 On Fri, Nov 23, 2012 at 2:38 PM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
  [quote]--> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
  Bob Turner
  RV-10 QB
  http://forums.matronics.com/viewtopic.php?p=388759#388759
  ="_blank">www.aeroelectric.com
  ooks.com" target="_blank">www.buildersbooks.com
  et="_blank">www.homebuilthelp.com
  le, List Admin.
KCHD |
		Strasnuts
				 Posted: Fri Nov 23, 2012 4:48 pm    Post subject: GPS mounting |
				For my GTS800 antenna the top is too thick to use a ground plane on the
 inside.  It will not work, I tried this.  When I installed this antenna I
 tried to follow Garmins recommendations for grounding.  The GTS800 has an
 O-ring like many other GPS antennas and as you can read below it states to
 use the mounting screws, not the coax.  This is for the GTS800 not the GPS.
 Below is part of the GTS800 instructions. Further down you can read Garmin's
 instructions for the G3X GPS/XM antenna concerning the ground plane.  It
 states the mounting screws AND the coax.
 2.3 Electrical Bonding
 Electrical equipment, supporting brackets, and racks should be electrically
 bonded to the aircraft's main
 structure. Refer to SAE ARP 1870 section 5 when surface preparation is
 required to achieve electrical
 bond. The electrical bond should achieve direct current (DC) resistance less
 than or equal to 2.5
 milliohms to local structure to where the equipment is mounted. Compliance
 should be verified by
 inspection using a calibrated milliohm meter. An equivalent OEM procedure
 may also be substituted.
 There may be OEM-specific reasons for electrically isolating equipment or
 having a higher bond
 resistance. These reasons should be rationalized upon installation approval.
 In general, Garmin
 recommends that all GTS 8XX equipment be electrically bonded.
 The antenna ground plane and doubler plate must be electrically bonded to
 the antenna baseplate. The
 electrical bond must achieve direct current (DC) resistance less than or
 equal to 2.5 milliohms.
 For composite aircraft, the antenna baseplate must be electrically bonded to
 the common ground of other
 installed equipment for lightning purposes. This can be achieved through the
 antenna mounting screws.
 G3X GPS/XM Antenna
 6.4.5 Antenna Grounding Plane
 Although no ground plane is required, the antennas typically perform better
 when a ground plane is used.
 The ground plane should be a conductive surface as large as practical, with
 a minimum diameter of 8
 inches. To use an antenna in aircraft with fabric or composite skin, a
 ground plane is recommended. It is
 usually installed under the skin of the aircraft, below the antenna, and is
 made of either aluminum sheet or
 of wire mesh.
 6.4.6 Antenna Grounding
 The antenna is grounded through the mounting hardware and the coax
 connection. The mounting
 hardware (washers and nuts) and doubler plate should make contact with an
 unpainted grounded surface
 ensuring proper antenna grounding. It is important to have good conductivity
 between the coaxial shield
 and the ground plane. The bottom of the antenna does not need to make
 contact with the ground plane
 (i.e. the surface may be painted).
 Sent: Friday, November 23, 2012 2:38 PM
  is the top?
  Bob Turner
  RV-10 QB
780 Hours
				 Posted: Fri Nov 23, 2012 5:41 pm    Post subject: GPS mounting |
				It may be that Garmin just wants the base of the antenna to be grounded, as opposed to  what we normally think of as a ground plane. That would of course be accomplished through the coax as someone pointed out. My sense has always been that the GPS antenna has the ground plane built in. I've mounted many to fiberglass in the past but not to the top of a 10. I don't think I'd hesitate. It's receive only so you can't really hurt anything, you just risk poor antenna performance.
 --Dave
 On Nov 23, 2012, at 17:46, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
 [quote]I have yet to understand why a GPS antenna needs a ground plane, when those in handhelds, Ipads, etc work great without one. Given the size of the antenna one would expect a full dipole rather than a quarter wave. Dynon's antenna/receiver is smaller than the Garmin antenna and needs no ground plane.
   	  | Quote: | 	 		  --> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
  Bob Turner
  RV-10 QB
  le, List Admin.
 ctric.com
 uilthelp.com
 cs.com
