		sean(at)stephensville.com Guest
				 Posted: Fri Nov 23, 2012 10:41 am    Post subject: Spinner Back Plate Hardware |
				On page 47-02 Step 4 it states that the spacers and hardware required to
 attach the spinner back plate to the prop are supplied with the propeller.
 I ordered my prop from Vans and did not receive any such hardware with
 the prop.  I'll be calling Vans about this on Monday, but was wondering
 if anyone else had this situation?
 -Sean #40303 (engine mounted today)
		Kelly McMullen
				 Posted: Fri Nov 23, 2012 1:07 pm    Post subject: Spinner Back Plate Hardware |
				Yes, kind of spooks folks that haven't dealt with a Hartzell prop before. Bolts are built in, get changed when prop is overhauled. More fun finding correct wrench or a crow's foot socket that works with those bolts.
 On Fri, Nov 23, 2012 at 11:46 AM, Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)> wrote:
 [quote] --> RV10-List message posted by: Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)>
  Please disregard.  I just realized that the hardware was attached to the prop hub.
  All this engine and prop stuff has me a bit jittery.  First time I've done anything like either and the install manuals need to be read a few more times in order to decipher.
  On 11/23/12 12:40 PM, Sean Stephens wrote:
   	  | Quote: | 	 		   On page 47-02 Step 4 it states that the spacers and hardware required to attach the spinner back plate to the prop are supplied with the propeller.
  I ordered my prop from Vans and did not receive any such hardware with the prop.  I'll be calling Vans about this on Monday, but was wondering if anyone else had this situation?
  om" target="_blank">www.aeroelectric.com
  ooks.com" target="_blank">www.buildersbooks.com
  et="_blank">www.homebuilthelp.com
  le, List Admin.
  http://forums.matronics.com
A&P/IA, EAA Tech Counselor
KCHD |
		Bob Turner
				 Posted: Fri Nov 23, 2012 1:25 pm    Post subject: Re: Spinner Back Plate Hardware |
				Make sure your engine is set up for a CS prop. It seems engines, even new ones ordered thru Vans, vary. Some have the plug inside the crankshaft that needs to be removed; some don't.
  _________________ Bob Turner
RV-10 QB |
