Dennis.Kirby(at)kirtland. Guest
Posted: Tue Jun 06, 2006 7:14 am Post subject: Wheel Camber on a FireFly |
<< Since I bent a landing gear leg ... The straightened leg survived
another landing on a rough grass field, ... Jack B. Hart >>
Jack -
I did not know you could straighten the stock (alum) Kolb gear legs in
place. Thanks for sharing your idea - I need to do the same on my Mark-III.
One of my gear legs is showing signs of slight bending, and I was thinking
of removing it to straighten it. Your jack-and-lever idea should work for a
Mark-III, wouldn't you think?
Dennis Kirby
New Mexico
Posted: Tue Jun 06, 2006 8:15 am Post subject: Wheel Camber on a FireFly |
Dennis, The stock aluminum MkIII leg is a pretty strong piece.
Take my word for it, it takes a BUNCH of pressure to restraighten.
-You would damage the plane before correcting any curvature.
Take it out if really necessary.
Even a perfect leg will show some flex with the normal aircraft
weight on it. Mine has some but they match.
I think I dropped it in from 3 feet recently with no problem.
-BB, MkIII, suzuki G10, 48.7hrs.
On 6, Jun 2006, at 11:13 AM, Kirby Dennis Contr MDA/AL wrote:
<Dennis.Kirby(at)kirtland.af.mil>
Jack -
Mark-III.
thinking
for a
Dennis Kirby
New Mexico
Posted: Tue Jun 06, 2006 2:12 pm Post subject: Wheel Camber on a FireFly |
At 04:13 PM 6/6/06 +0100, you wrote:
Jack -
Dennis,
The leg was straightened before the camber was set. When adjusting the
camber, you are bending the 5/8 inch OD steel tube that is the FireFly axle,
not the leg.
Sorry for the confusion.
Jack B. Hart FF004
Winchester, IN
