nickc(at)mtaonline.net Guest
Posted: Wed Dec 05, 2012 2:03 pm Post subject: Tail up grades... |
Hello John,
Thanks for figuring out what I was trying to ask the “List.” I think I understand most of what you described, but where did you mount the “saddle” on the boom. Was the Saddle haft the circumference on the boom tube, and riveted to the boom?
What material did you use, “ In addition to bracing the tail post” for this bracing?
Thank you very much,
Nick Cassara
Palmer, AK
607AK
Posted: Wed Dec 05, 2012 4:01 pm Post subject: Tail up grades... |
bracing?
Nick Cassara
Nick C/Kolbers:
I included the two previous photos of my lower vertical stabilizer and tail
post braces. At the forward end of the lower vertical stabilizer the 4130
saddle is visible.
We fabricated the lower vertical stabilizer on my MKIII from 4130 because we
knew this was a high stress area during ground handling/taxi. The saddle
was cut out of a section of 4130 tail boom ring, welded to the forward end
of the lower vertical stabilizer and pop riveted to the bottom of the tail
boom.
309.99 KB |
5658 Time(s) |
303 KB |
5658 Time(s) |
_________________ John Hauck
Titus, Alabama |
lcottrell
Posted: Wed Dec 05, 2012 5:51 pm Post subject: Tail up grades... |
I did it a little differently from John. I am sure that he and Jim did it right, I modified an existing screw up and just drilled through the ring at the back of the tube. The ring is under no stress, and a new hole in it isn't going to hurt a thing, so I could find no reason to make it any more complicated than necessary. I used some alum tubing for the brace. Just be sure you don't split it when you flatten the ends. Your options are open and do as you think right. Larry
On Wed, Dec 5, 2012 at 3:03 PM, Nick Cassara <nickc(at)mtaonline.net (nickc(at)mtaonline.net)> wrote:
Hello John,
Nick Cassara
Palmer, AK
607AK
_blank">www.aeroelectric.com
.com" target="_blank">www.buildersbooks.com
tp://forums.matronics.com
734.77 KB |
5651 Time(s) |
770.74 KB |
5651 Time(s) |
706.23 KB |
5651 Time(s) |
Richard Pike
Posted: Fri Dec 07, 2012 7:56 am Post subject: Re: Tail up grades... |
Here is what we did on Ed's Firestar II, just a length of 1/8" aluminum flat stock on each side. Drilled one new hole on each side of the steel ring, and used the existing bolt that secures the tailwheel strut. I will be doing the same on my MKIII this winter.
77.48 KB |
5608 Time(s) |
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Dennis Thate
Posted: Mon Dec 10, 2012 6:37 pm Post subject: Re: Tail up grades... |
For pilots who like that.... [add-on look]..... How about this short field landing tail-hook device.
85.7 KB |
5555 Time(s) |
_________________ Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern |
