cubflyr(at)comcast.net Guest
Posted: Tue Jun 06, 2006 4:23 am Post subject: Landoll Balancer? |
> (am assuming you are using a metal prop, as wooden props really do not need such a device).
> BTW, it is not a "balancer", as it balances nothing. It is actually a "harmonic dampener".
> Catch my forums at OSH for what it actually does.
Opps: I believe it is the other way around: you need something flywheel-like up front to make up for lack of weight and inertia of a wood prop. Something like a Landoll dampener would not be necessary with a METAL (flywheel) prop as the weight and inertia is already there.
Michael
| - The Matronics Engines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Engines-List |
n801bh(at)netzero.com Guest
Posted: Tue Jun 06, 2006 5:28 am Post subject: Landoll Balancer? |
Actually Archie is correct, the device is a harmonic dampener, or to put it different it absorbs alot of unwanted vibrations which in effect smooths out the power pulses. A balancer is usually a static action to correct a shaking motion, the harmonic balancer is an active device doing its thing as the engine runs.
Ben Haas
N801BH
www.haaspowerair.com
Michael
archie97(at)earthlink.net Guest
Posted: Tue Jun 06, 2006 12:23 pm Post subject: Landoll Balancer? |
I work with these on a regular basis, and can assure you the a wooden prop will
absorb and dissipate orders of harmonics where a metal prop will not.
That is not to say it cannot be used, however.
The dampener may add some flywheel effect but why would anyone install it for that
purpose? We are not incorporating it for flywheel effect. The purpose of any dampener
is to absorb torque spikes which are generated in every internal combustion piston engine.
Archie
