dmasys(at)cox.net Guest
Posted: Tue Jun 06, 2006 1:50 pm Post subject: blown fuses |
---- linn Walters <pitts_pilot(at)bellsouth.net> wrote:
| Quote: | Jesse Saint wrote:
The only problem in-flight would be getting your legs
| Quote: | >out of the way so you could flip it down, but in most cases where you are
>blowing a fuse, putting another one in is probably not going to fix the
>problem. The blown fuse is just evidence that there is a problem that needs to be fixed.
And while you're preoccupied with the fuses, you aren't flying the
plane, checking for traffec etc.!!! Best to wait 'till you're back on
solid ground. IMHO, of course
Linn
This is very much the spirit of the Aeroelectric approach: make critical systems redundant so that if one fails (e.g., a fuse blows) you don't have to try to fix it while flying. Just note it and switch to the alternative approach to getting the same job done.
The only fuse I have blown in the -7A was the pitot heat, which was sized for the continuous current load but not for the current spike that accompanies the startup of the pitot (approximately 1.6 x the steady state amperage). Switched from a 15A to 20A fuse and lived happily ever after .
-Dan Masys
