Rotax 914 Right Mag rough
Goto page Previous  1, 2
uuccio(at)gmail.com
PostPosted: Sat Dec 15, 2012 8:22 am    Post subject: Rotax 914 Right Mag rough Reply with quote
Brilliant
On Dec 15, 2012, at 14:59, "Thom Riddle" <riddletr(at)gmail.com> wrote:
Regarding portable jack for tire(tyre) changing, I built something simple and lightweight for my Kolb Slingshot which has an axle that extends inboard from the axle fitting. Your airplane may have a different setup and might require a different connection, but the principle is the same.
A block with an axle and two wheels, plus a removable handle for leverage. The over-center characteristic is the key. Note in the short YouTube video I made that I put the wedge (cut from the top, under the raised end to keep it from falling if the airplane is accidentally pushed when on the jack.
http://www.youtube.com/watch?v=4ars22PxPjE&list=UUXuIm2BjpicnSovZDhKc06w&index=8
or
http://tinyurl.com/bmkps9g
The prototype shown in this video was made of simple pine board. It broke in time, so it should be made of hardwood or other stronger material for durability.
Thom Riddle
Buffalo, NY (9G0)
Kolb Slingshot SS-021
no engine
FOR SALE
Diamond Katana DA20-A1
Rotax 912 F3
- Anonymous
http://forums.matronics.com/viewtopic.php?p=390475#390475
Thom Riddle
PostPosted: Sat Dec 15, 2012 9:06 am    Post subject: Re: Rotax 914 Right Mag rough Reply with quote
If you make one and want to be able to use it on soft ground, take a small piece of plywood with you for the over-center jack to sit/work on. Otherwise it will just sink into soft surface.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Duncan McFadyean
PostPosted: Sun Dec 16, 2012 3:13 am    Post subject: Rotax 914 Right Mag rough Reply with quote
<<.... or wait till summer before i fly.>>
Or stick a hairdrier under the cowl for 20 minutes prior to start up.
This works for me, even when the engine has been cold soaked at -3C.
Duncan McF.
goodings(at)yorku.ca
PostPosted: Sun Dec 16, 2012 11:36 am    Post subject: Rotax 914 Right Mag Rough Reply with quote
PLEASE don't make something complicated out of something simple. To
change a wheel or whatever on a Zenair Zodiac, simply get your shoulders
under the spar and lift the wheel off the ground. My 70-year-old-legs are
plenty strong enough. (Further outboard gives you a mechanical advantage.
You are lifting less than 200 pounds.) Support it with some cardboard
boxes or whatever is handy. Make sure the support is under the spar. A
blanket or coat or whatever over the support is probably a good idea.
This is simple, it is quick, it is portable, it is foolproof (even by
me!). Take 10 seconds to try it before making a (complicated) jack.
[Perhaps other aircraft are much heavier than a Zodiac???]
John Goodings, C-FGPJ, CH601HD Zodiac with R912S, Carp/Ottawa/Toronto
Thom Riddle
PostPosted: Mon Dec 17, 2012 7:24 am    Post subject: Re: Rotax 914 Right Mag rough Reply with quote
John Goodings,
Following was the original question about tyre changing:
How the hell do i change a tyre if i get a flat away from base.?
Your self lift procedure is fine for getting the tyre/tire off the ground. Do you carry large carboard boxes around with you when you fly? How about a saw horse or other bulky object on which you can support the wing you lift way out away from the wheel?
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Page 2 of 2
