tn3639(at)hotmail.com Guest
Posted: Tue Jun 06, 2006 1:51 pm Post subject: Super unleaded in 160hp O-320 |
Converting to 160 hp (8.5 to 1) does not preclude your use of Auto fuel. It
simply means that you will have to use 91 -93 octane super, rather than 87
octane regular.
Is this true? This is the first I have heard of it.... if so, I sure could
save some $$$$$ if so
Scott
RV6-A
!60hp O-320
jmsears(at)adelphia.net Guest
Posted: Tue Jun 06, 2006 3:28 pm Post subject: Super unleaded in 160hp O-320 |
| Quote: | > Converting to 160 hp (8.5 to 1) does not preclude your use of Auto fuel.
> It simply means that you will have to use 91 -93 octane super, rather
> than 87 octane regular.<<
| Quote: | Is this true? This is the first I have heard of it.... if so, I sure could
According to some old documentation I got from Petersen Aviation, owner of
one of the auto gas STCs, the 150hp/160hp O320 and the 180hp O360 engines
were approved by the FAA for auto gas. Oh, yeah. Let's not forget the
normally aspirated O540s, either. I think those are the 235 hp versions for
you -10 builders? H2ADs and fuel injected O360s were not approved. I think
it applies to any fuel injected engine, actually. Of course, he noted that
fuel line sizes, routing, and other variables, could impact the use of auto
gas due to vapor lock. He also mentioned that some materials in our tanks
may not hold up to the rigors of auto gas. The engines were OK, though.
To run the higher compression engines on auto gas, just bump up to 91-93
antiknock gas.
I invested in my first auto gas STC in 1986 and have saved money on gas for
my airplanes, since. My RV-6A has a 150hp O320 that runs well on 87
antiknock. The tanks and fuel system have shown no adverse effects of
having auto fuel in them, other than the minor vapor locking that can happen
during fast turnarounds. The plugs are clean, except for some carbon build
up. Oil, not fuel. No lead to foul plugs. Per Petersen's STC, I do put in
some 100LL a couple of times a year. I can always tell the difference.
Within an hour, or so, the lead deposits start building up and fouling
plugs.
Vapor locking is a minor problem, as was the case in my other two airplanes.
If in doubt, I add some 100LL to the mix to change the vapor pressure so
that the fuel is less apt to vapor lock. About the only time I chose to do
this is if I'm going to take up a lot of kids during a Young Eagles day. If
it's cold outside, I don't bother.
If I ever get around to finishing my -7A, it will have an O320 160hp engine
or an O360 180hp engine. Since I already have some pieces and parts for the
O320, that will probably be my choice. I plan on using premium unleaded in
it. I can't afford to own an airplane and keep it filled with 100LL. I'm
just getting used to putting premium in my new Miata! (It does get good gas
milage, though. )
Jim Sears in KY
RV-6A N198JS (Scooter)
RV-7A #70317 (Started on fuse)
EAA Tech Counselor
gptyler(at)metrocast.net Guest
Posted: Tue Jun 06, 2006 4:21 pm Post subject: Super unleaded in 160hp O-320 |
My understanding is that the engine will work on the mogas but the STC
doesn't cover it. So, it would seem the decision is if you want to keep your
engine certificated.
Bruce(at)glasair.org Guest
Posted: Tue Jun 06, 2006 4:41 pm Post subject: Super unleaded in 160hp O-320 |
Once an engine is installed on an experimental aircraft, it looses its
certified status and cannot thereafter be reinstalled on a certified
airframe without a complete disassembly/OH to determine it's status.
Bruce
www.glasair.org
klwerner(at)comcast.net Guest
Posted: Tue Jun 06, 2006 5:05 pm Post subject: Super unleaded in 160hp O-320 |
Bruce,
I did not know this!
I always thought that if you take a dataplate of the engine (or modify it!) it would loose its certified status, ...but not by simply bolting a fully certified engine into a non-certified airframe?
sbuc(at)hiwaay.net Guest
Posted: Tue Jun 06, 2006 6:29 pm Post subject: Super unleaded in 160hp O-320 |
Bruce Gray wrote:
As I understand the situation (and I am certainly willing to be
corrected!) the mere act of bolting a certificated engine to an
experimental airframe does not cause the engine to lose its certificated
status.
However, if the engine was to be returned to service on a certificated
airframe, the installation would have to be signed off by an AI.
And.....how many AI's are going to put their career on the line by
signing off on an engine that they are not *absolutely certain* meets
all certification requirements.
The AI covering his backside is why the engine will most likely be torn
down to insure compliance, not just the fact that it was bolted to an
experimental airframe. If you can find an AI that is willing to sign off
the engine installation without a teardown, it will be legal. This
*might* actually happen if the AI owned or had detailed knowledge of the
experimental aircraft the engine was on.
Sam Buchanan
Posted: Tue Jun 06, 2006 7:13 pm Post subject: Super unleaded in 160hp O-320 |
That's my understanding of the situation also. The engine would have to be
examined to be sure all parts were in compliance and all AD's were up to
snuff. In essence an overhaul.
Bruce
www.glasair.org
Posted: Tue Jun 06, 2006 7:47 pm Post subject: Super unleaded in 160hp O-320 |
Bruce Gray wrote:
Only if the AI insisted on the inspection/overhaul, but not because the
FARs require it. If the AI has extensive knowledge of the engine and its
compliance with AD's, he *might* forgo the inspection.
The A&P/AI that helped me with the yellow-tagged and updated logbook
overhaul of the O-320 in my RV-6 might have returned that engine to
certificated service without further inspection since he was familiar
with the overhaul and all major service following the overhaul. But a
different AI who didn't know the engine most likely would have required
an internal look at the engine and logs before he signed off the new
installation.
Sam Buchanan
Posted: Tue Jun 06, 2006 8:11 pm Post subject: Super unleaded in 160hp O-320 |
Sam,
I believe the FAR's exempt our engines from AD's even if we don't remove the
data plate. I recall emails from our friendly FAA guy that stated that the
FAA considered all appliances when attached to an experimental airframe to
be experimental. If your engine logs state that your engine was installed on
an RV, Glasair, or any other experimental airframe followed by your
signature, I don't know of any AP/IA that would sign if off for a reinstall
on a certified aircraft. The local FSDO would be sure to frown on it. It's a
real grey area. This might be a good question to kick up to the EAA experts.
Bruce
www.glasair.org
Posted: Wed Jun 07, 2006 2:08 am Post subject: Super unleaded in 160hp O-320 |
| Quote: | My understanding is that the engine will work on the mogas but the > STC
doesn't cover it. So, it would seem the decision is if you want > to keep
your engine certificated.
One has to look at the STCs. The EAA STC may not cover high compression
engines; but, the Petersen seems to cover them. Do keep in mind that STCs,
ADs, etc. do not apply to experimentals; but, one is foolish to not comply,
in many cases. If the testing was done for the Petersen STC for high
compression approval, I'd think it would be OK to use 91-93 antiknock fuels
in them. If not, I wouldn't. Fortunately, his STC does seem to cover them;
so, I'm going to use autogas in my next RV, as well.
As for the certification, Pat Patterson learned in AB-DAR school that a
certifiied engine is indeed decertified when it is attached to an
experimental. It is true, even if one does not remove the data plate, which
I refuse to do. Just as Sam said, all one has to do is have an IA approve
the engine's use on a certified airplane for it to be put back to use as
such. I'm sure mine could be put back to service with a couple of changes
like removing the starter and alternator. I kept mine in certified
condition, I thought, by having an A&P sign off the engine at inspection
time. I quit that when Pat told me what he'd learned. I still have Pat,
the A&P, help me with the inspection; but, I do the sign off, now.
Actually, I don't know why we worry so much about keeping our engines
certified, anyway. How often do you think an engine from an experimental is
going to be put back into a certified airplane? Most likely, it will be
snapped up by another experimental builder before the certified status comes
into play.
Jim Sears in KY
RV-7A #70317
EAA Tech Counselor
