user9253
Joined: 28 Mar 2008 Posts: 1940 Location: Riley TWP Michigan
Posted: Thu Dec 20, 2012 8:23 am Post subject: TV Antennas in parallel |
This is not aviation related, but may be of interest to electron herders.
Cable is not available at my location. I get TV signals from antennas in the attic. I read some place that two antennas can be connected together if the feed lines are of equal length. I took it one step further and connected 3 antennas together using equal (≈ 8 foot) lengths of 300 ohm twin-lead TV antenna cable. The 3 antennas point in different directions. I was surprised to receive even more stations than I had hoped for, a total of 34 counting the sub-channels, all with digital quality.
Joe
_________________ Joe Gores |
sam.marlow
Posted: Thu Dec 20, 2012 10:46 am Post subject: TV Antennas in parallel |
Where did you purchase your antennas?
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=390745#390745
harley(at)AgelessWings.co Guest
Posted: Thu Dec 20, 2012 12:17 pm Post subject: TV Antennas in parallel |
I did the same thing that Joe did, but with only two antennas...I get 32 channels over the air (again, including the subchannels), here just south of Rochester NY, most from Rochester, but some of them from Buffalo.
I didn't buy the antennas, I made them, and mounted them in the crawl space above my ceiling, pointing North and West (although, unlike the instructions, I used old wire coat hangars for the wire, didn't use screws and washers to connect but scraped the enamel off where contact was needed and soldered them together, and bent them so the cross wires don't touch...didn't use any shrink tubing):
www.popularmechanics.com/technology/how-to/tv/build-your-own-digital-tv-antenna
You can also find a number of video instructions to make these on Youtube. And they do work better than any commercial ones I've used in the past. I am thinking of dropping Dish Network, as several of the channels I receive here over the air are also on Dish (Ion for example)!
Harley
On 12/20/2012 1:47 PM, Sam Marlow wrote:
[quote]--> AeroElectric-List message posted by: Sam Marlow <sam.marlow(at)roadrunner.com> (sam.marlow(at)roadrunner.com)
user9253 wrote:
Quote: | --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com> (fransew(at)gmail.com)
Joe
Joe Gores
Checked by AVG - www.avg.com
12/19/12
user9253
Posted: Thu Dec 20, 2012 5:41 pm Post subject: Re: TV Antennas in parallel |
Quote: | Where did you purchase your antennas? |
I do not remember where I bought them. They have been in the attic for years. Long ago there were 3 sets of lead-in cables connected to a RF A-B-C switch behind the TV. Now the A-B-C switch is not needed. There is only one lead-in cable used.
Joe
john.maccallum(at)bigpond Guest
Posted: Thu Dec 20, 2012 6:39 pm Post subject: TV Antennas in parallel |
Hi Joe,
That is a good outcome but usually you just can't add antennas in parallel
like that due to Impedance and phasing mismatches.
The feedlines need to be matched to the frequency you are working at and be
either 1/4 wave or 1/2 wavelength multiples depending on
The antenna configuration and not just be equal lengths.
The characteristic feed line impedance in your 300 ohm hook up will be way
off and it will not be 100 ohms as is suggested by simple
Mathematics and as well the impedance will also vary with frequency.
Multipath will cause issues with such a setup and the antennas will have
multiple
lobes and nulls. Being in the attic instead of outside is less than ideal to
boot.
But if it works it works! Just don't expect it to work at other locations
with the same degree of success.
Cheers
John MacCallum
VH-DUU
RV 10 # 41016
VK2GCN
mrspudandcompany(at)veriz Guest
Posted: Fri Dec 21, 2012 10:12 am Post subject: TV Antennas in parallel |
Harley [quote] How did you connect the 2 antennas together? Did you use an impedance match transformer at the antennas? A picture or a simple sketch would be interesting. Roger[b]
jonlaury
Posted: Fri Dec 21, 2012 11:29 am Post subject: Re: TV Antennas in parallel |
user9253 wrote: | snip... I was surprised to receive even more stations than I had hoped for, a total of 34 counting the sub-channels, all with digital quality.
Joe |
Except for TV, nature abhors a vacuum.
My condolences, Joe.
Posted: Fri Dec 21, 2012 12:05 pm Post subject: TV Antennas in parallel |
www.amazon.com/CHANNEL-2512-Passing-Splitter-Combiner/dp/B00006JPEA/ref=pd_cp_e_0 [quote] OK, the above is one piece of the puzzle! I am assuming that you connected an impedance matching transformer to each of the antennas then went through the above combiner with the outputinto a 75 ohm cable to the TV. Roger[b]
Posted: Fri Dec 21, 2012 12:21 pm Post subject: TV Antennas in parallel |
Yeah...I didn't mention them because as far as I'm concerned they are part of the antenna themselves... as part of the construction.
www.amazon.com/CHANNEL-2512-Passing-Splitter-Combiner/dp/B00006JPEA/ref=pd_cp_e_0 Quote: | OK, the above is one piece of the puzzle! I am assuming that you connected an impedance matching transformer to each of the antennas then went through the above combiner with the outputinto a 75 ohm cable to the TV. Roger |
ceengland7(at)gmail.com Guest
Posted: Fri Dec 21, 2012 12:37 pm Post subject: TV Antennas in parallel |
On 12/21/2012 2:05 PM, Roger & Jean Curtis wrote: TV balun for converting 300 ohm balanced (antenna) to 75 ohm unbalanced (coax):
A regular 75 ohm splitter can be turned around & used as a combiner for a lot less money than the one shown with the DC pass-through (assuming you don't need the pass-through):
The only need for a DC pass-through is if you're using some type of remotely powered RF amp.
You can buy frequency selective filters that will reduce interference from 2 antennas seeing the same station, but as others have demonstrated, you often don't need them.
Charlie
user9253
Posted: Sat Dec 22, 2012 7:34 pm Post subject: Re: TV Antennas in parallel |
http://www.hdtvprimer.com/ANTENNAS/ganging.html
There is a drawing on this website that is similar to the way that I connected my antennas together, except that my 3 antennas are all connected in parallel. Another 300 ohm cable connects that junction to a balun for conversion to 75 ohms. After reading this article, I realize that I am lucky to have good reception.
Joe
