				 Posted: Mon Dec 24, 2012 7:10 am    Post subject: Problem with the Harbor Freight Carbon   Pile battery tester |
				At 06:25 PM 12/23/2012, you wrote:
 I've used this unit a few times without a problem.  Then it suddenly
 stopped working.  I couldn't seem to apply a load though the exact
 symptoms I don't quite remember.
   is it failing to APPLY a load or failing to
   INDICATE what that load is? Does the voltmeter
   behave as expected?  Can you depress the voltmeter
   reading and get it to smell hot by cranking the
   load knob down?
  	  | Quote: | 	 		  Today, I pulled the unit apart and found
 1) a fuse on a small circuit board which had not blown (not easily
 replaceable either)
 2) the carbon disks that presumably supplies the variable resistance
 seem to be stacked between two steel plates  but the carbon disks
 appeared to be loose or askew.
    Those are classically not tightly captive.
    A carbon pile rheostat is a PRESSURE device
    wherein once the slack is taken out of the
    stack height by the first turn of load knob
    rotation, the pile doesn't physically move
    much after that. It's behavior is a response
    to pressure not motion.
  	  | Quote: | 	 		  If I screw the big knob down and shake things a bit, I can get the
 stack of carbon plates lined up and it seems that increased
 resistance results from placing more pressure on the stack.
 Does that sound right?
    No, the resistance between the fat wires to hte
    battery should drop markedly. To load a battery
    to 500A at 8 volts requires a resistance on
    the order of 16 MILLIOHMS.
  	  | Quote: | 	 		  Furthermore, it would seem for consistent operation, it would be
 best to lie the unit on its back to insure the carbon plates remain flat.
     Doesn't matter.
  	  | Quote: | 	 		  Tomorrow I will attempt to use it again to see if it works now that
 the plates are back in position.
 Any insight or tips welcome.  I will report further tomorrow.
     I've got two of these critters and they've
     performed as expected for 5+ years. Sounds
     like something may be unhooked. Tell us what
     behaviors you see on the voltmeter while trying
     to get the load increased.
