larkrv10(at)gmail.com Guest
Posted: Mon Dec 31, 2012 11:23 am Post subject: Naca Vents |
Hi all, I'm getting ready to cut the NACA vent hole(s) in my tail cone for an overhead console and am wondering if I really need 2 vents. Seems to me I've read comments about one vent being sufficient. Also being in Southern Ontario, the summer temps aren't sustained for nearly as long as those of you south of the Mason Dixon line, thus the reason I question if 2 are needed.
Any and all opinions are welcome. Happy New Year to everyone.
Rick
#40956
Southampton, Ont
rnewman(at)tcwtech.com Guest
Posted: Mon Dec 31, 2012 11:42 am Post subject: Naca Vents |
Rick, I went with just one Naca scoop in the tail cone area (just behind baggage door) feeding my overhead console. It has provided plenty of air from overhead. There’s a few pictures in my web album starting with this one:
https://picasaweb.google.com/102955683430141812381/CoolingFans#5576300260864810306
Bob Newman
N541RV
Sent: Monday, December 31, 2012 2:23 PM
Subject: Naca Vents
Rick
#40956
Southampton, Ont
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
aerosport1
Posted: Mon Dec 31, 2012 11:50 am Post subject: Naca Vents |
Rick I would still put 2 in. I have 2 and in the summer you get some air from them when taxiing. It is not a lot
but sure helps when it is hot. You can always close the vents or for you put in the NACA control
valve from Aerosport Products. You can shut the whole system down in the winter with the controller and open it up in the
summer. Its easier to do it now then later. It will take maybe 1 hour more for the extra vent.
FWIW
Geoff Combs
Aerosport
www.aerosportproducts.com
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Lark
Subject: Naca Vents
Rick
#40956
Southampton, Ont
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
rleffler
Posted: Mon Dec 31, 2012 12:59 pm Post subject: Naca Vents |
I put a pair of them in, along with an Aerosport Products vent controller. Like Geoff mentioned, in the air one is probably enough, but while taxiing you'll want them both wide open in the summer.
You might drop Ivan an email and see what his experiences are in Guelph.
On Dec 31, 2012, at 2:23 PM, Rick Lark <larkrv10(at)gmail.com> wrote:
[quote] Hi all, I'm getting ready to cut the NACA vent hole(s) in my tail cone for an overhead console and am wondering if I really need 2 vents. Seems to me I've read comments about one vent being sufficient. Also being in Southern Ontario, the summer temps aren't sustained for nearly as long as those of you south of the Mason Dixon line, thus the reason I question if 2 are needed
_________________ Bob Leffler
N410BL - Phase I
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Mon Dec 31, 2012 1:06 pm Post subject: Naca Vents |
I have two in the back as well. I vote for two.
On Dec 31, 2012, at 13:58, Bob Leffler <rv(at)thelefflers.com> wrote:
[quote] I put a pair of them in, along with an Aerosport Products vent controller. Like Geoff mentioned, in the air one is probably enough, but while taxiing you'll want them both wide open in the summer.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
bill.peyton
Posted: Tue Jan 01, 2013 4:17 pm Post subject: Re: Naca Vents |
It's too easy to add that second vent now.
_________________ Bill
WA0SYV
Aviation Partners, LLC |
Posted: Tue Jan 01, 2013 4:42 pm Post subject: Naca Vents |
Hi Guys, sorry to take so long responding, New Years got in the way.
Ok, so I guess popular consensus is 2 NACA vents. Thx for the opinions.
Rick
On Tue, Jan 1, 2013 at 7:17 PM, bill.peyton <peyton.b(at)sbcglobal.net (peyton.b(at)sbcglobal.net)> wrote:
[quote]--> RV10-List message posted by: "bill.peyton" <peyton.b(at)sbcglobal.net (peyton.b(at)sbcglobal.net)>
WA0SYV
http://forums.matronics.com/viewtopic.php?p=391357#391357
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
bruce1hwjohnson(at)yahoo. Guest
Posted: Wed Jan 02, 2013 2:19 pm Post subject: Naca Vents |
I just finished putting my vents and overhead in and went with two naca's. I got Geoff's controller and decided not to put it in and see how it worked without and so far its fine. Went with the Stien eyeball vents and they do a good job of sealing off air flow unless you want it. Not to talk you out of putting in the controller, just my experience.
Sent: Tuesday, January 1, 2013 5:42 PM
Subject: Re: Re: Naca Vents
Rick
WA0SYV
le, List Admin.
www.t="_blank" href="http://www.homebuilthelp.com/">www.homebuilthelp.com</ target="_blank" href="http://www.matronics.com/Navigator?RV10-List">ht[b]
aerosport1
Posted: Wed Jan 02, 2013 3:13 pm Post subject: Naca Vents |
The one thing about the controller is that in the winter you will still have all that cold air up in the overhead. The Stein vents
works great but I was amazed at how much warmer the cabin is when the overhead is completely shut off. I was like you at first Bruce
I did not have the controller in for the first couple months. I almost canned the idea but love it now.
Either way 2 are better than one.
Geoff
Geoff Combs
Aerosport Modeling and Design
8090 howe industrial pkwy
canal winchester, ohio 43110
614.834.5227p
614.834.5230f
www.aerosportmodeling.com
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bruce Johnson
Sent: Wednesday, January 02, 2013 5:17 PM
Rick
| Quote: | --> RV10-List message posted by: "bill.peyton" <peyton.b(at)sbcglobal.net (peyton.b(at)sbcglobal.net)>
WA0SYV
le, List Admin.
www.t="_blank" href="http://www.homebuilthelp.com/">www.homebuilthelp.com</ href="http://www.matronics.com/Navigator?RV10-List" target="_blank">ht
| [quote][b]
RV-10 QB N829GW
Flying 500 hrs
40033 |
