[Norton AntiSpam]Re: Switches all upside-down...
JOHN TIPTON
PostPosted: Sun Dec 30, 2012 1:58 am    Post subject: [Norton AntiSpam]Re: Switches all upside-down... Reply with quote
Why not use a pre drilled bus bar
http://www.chiefaircraft.com/aircraft/installation-supplies/terminal-blocks/ms-25226-10-16.html
which will not only give your switch/breaker spacing but your common feed
bus bar (for the breakers)
John
eschlanser
PostPosted: Wed Jan 02, 2013 6:56 pm    Post subject: Re: [Norton AntiSpam]Re: Switches all upside-down... Reply with quote
John
Because I'm using fuses and toggle switches instead of circuit breakers.
Eric
