cjhukill(at)cox.net Guest
Posted: Wed Jun 07, 2006 6:33 am Post subject: transponder antenna |
I mounted my transponder antenna in the tailcone, just abeam the elevator bellcrank. This allows for a very short coax feed, as I will use a remote transponder, as the panel space in a 10 is very limited for an IFR machine. This location is very accessible, and far enough away from the comm antennas, which are mounted in the area just forward of the rear seats, under the flap tubes covers, which are also accessible. As I work in the tunnel, I would like to comment that there is lot of stuff in there already, and trying to jam in anything else, like an antenna would be masochistic. Don't forget that you'll be standing on your head working in that tunnel at every annual to clean and inspect that fuel filter.
Chris Hukill
developing tunnel vision
