		alienwes
				 Posted: Sat Jan 05, 2013 4:42 pm    Post subject: Viking/Honda Engines-Again! |
				I know that this new engine has been talked about in the past, but it seems they have been shipping out alot of them and it looks like they might be around for the longterm. One the viking yahoo forum there is a guy who says he is seriously considering mounting the Viking on a KOLB.
 Jan-
 I think it would be great if you looked at the integration of the engine on the
 2 place KOLB's. I think it would be an excellent performance fit and I believe
 the market, especially retrofit, would be at least as large as the SeaRay. I
 could send you pictures or scanes of the drawings offline. The KOLB factory
 guys could probably do even better. I am aware of these airplanes with mostly
 912's Jabs and 582's, but also 618's, Hirths, Subarus, VW's, and BMW's. I am
 not aware of any of them using a conventional welded tubing engine mount. They
 bolted from a bottom framework on the engine essentially at the engine
 longitudinal CG to 4 Berry/Lord mounts on about a 10 in square horizontal pad at
 the aft end of the KOLB cage. If there is available structure for that on the
 Viking it would probably be the most structurally efficient option...especially
 for those of us with a finished cage and looking at a retrofit from the Rotax
 configuration.
 Bob
 Might be another alternative to the costly 912?
  _________________ Wesley Elliott
Sport Pilot-PPC |
		neilsenrm(at)gmail.com Guest
				 Posted: Sat Jan 05, 2013 8:15 pm    Post subject: Viking/Honda Engines-Again! |
				Wes
 You are asking a lot of interesting questions. That's good. A new engine on a airplane is from personal experience a lot of time and effort. Seemed like everything needed to be designed and built for that engine/air frame. Check the engine weight closely, it is real tough to beat the power/weight of a 912. Engine manufacturers are notorious for under reporting their operational weight. Additional weight means less load carrying capacity so you could end up with a single passenger airplane or worse. Engine mounts and exhaust systems are a nightmare and don't expect to have a engine or airplane manufacture to design one for you without a proven market opportunity. Seemingly easy things like prop selection and reduction ratios are very difficult to get right the first or second time. Bottom line it is easy to spend more than the cost of a 912 and not have as good a engine or worse.
 Rick Neilsen
 Redrive VW Powered MKIIIC
 On Sat, Jan 5, 2013 at 7:42 PM, alienwes <elliott.wesley(at)yahoo.com (elliott.wesley(at)yahoo.com)> wrote:
  [quote]--> Kolb-List message posted by: "alienwes" <elliott.wesley(at)yahoo.com (elliott.wesley(at)yahoo.com)>
  Jan-
  configuration.
  Bob
  Wesley Elliott
  Sport Pilot-PPC
  http://forums.matronics.com/viewtopic.php?p=391684#391684
  le, List Admin.
		ceengland7(at)gmail.com Guest
				 Posted: Sat Jan 05, 2013 8:21 pm    Post subject: Viking/Honda Engines-Again! |
				It's also good to take a very close       look at the vendor. That particular vendor has a long track record       (that, with a different name, precedes the Viking project &       has a much longer record). Your mission, should you choose to       accept it, is to determine what that track record is.
        Charlie
        On 01/05/2013 10:15 PM, Rick Neilsen wrote:
      [quote]Wes
        Rick Neilsen
             	  | Quote: | 	 		  -->             Kolb-List message posted by: "alienwes" <elliott.wesley(at)yahoo.com (elliott.wesley(at)yahoo.com)>
              Jan-
              configuration.
              Bob
              Wesley Elliott
              Sport Pilot-PPC
