Richard Lamprey
Posted: Sun Jan 13, 2013 12:32 am Post subject: Trailer regulations in UK |
Good morning all,
Does anyone have info for regulations about trailers in UK, eg for a Europa? Does it have to be made/ constructed by some company, up to British Standard xxxxxd. Or can I stick it together in my backyard, bolt on some lights at the back, and get going. And to register ? New number plates, or those of the car that pulls it?
So, if I had a trailer made here in Kenya by a very good Kenya manufacturer, shipped my Europa (Classic) back to UK in it, in a 20' container, what sort of problems will come at me at the UK end when I try to put it on the road?
Obviously the problems of UK/LAA certification of the Europa itself will be of an entirely different order, but lets start with the trailer!
Best
Richard
Kenya, reg 5Y-LRY
dg.watts(at)talktalk.net Guest
Posted: Sun Jan 13, 2013 1:45 am Post subject: Trailer regulations in UK |
Richard,
In the UK I have built a lot of trailers over the years for myself (well
over 10, in fact I have 4 in use at the moment).
Anybody can build a trailer in the UK and it doesn't have to be registered
or insured. It will use the cars registration when on the road.
The requirements are:-
You must use UK approved suspension units.
You must use a UK approved coupling.
If it is over 750Kg it must have brakes and the brakes must have auto
reversing mechanism.
It must have light, number plate and triangles showing at the rear.
Max weight cannot exceed 3.5 tons authough the tow car may have lower
restrictions.
Max width and length are somewhere around 9ft and 23ft (I can't remember the
exact dimensions as they are under what I usually build, although I did
build a 22ft 10inch trailer once, which was right on the limit) These
dimensions can be exceeded if the load is indivisible.
I think I have covered most of the required points, but let me know if you
want any more.
Dave Watts
G-BXDY (Hoping that I can fly again one day if the runway ever dries out
after all the rain we have had)
Posted: Sun Jan 13, 2013 2:23 am Post subject: Trailer regulations in UK |
On 01/13/2013 09:32 AM, Richard Lamprey wrote:
| Quote: | Does anyone have info for regulations about trailers in UK, eg for a
Europa?
Unfortunately every country in Europe has its own rules. For me in the
Netherlands it is impossible to get the UK-trailer registered. Luckily
it is allowed to carry the number plates of the car on the trailer,
provided the total loaded weight of the trailer does not exceed 750
Kg's. (Yes I know it is a bit heavier than this, but I think it is close
enough to talk my way out of it and in the few years I have trailered
the aircraft back and forth to the airfield for every trip nobody has
ever questioned about it).
Frans
Posted: Sun Jan 13, 2013 2:55 am Post subject: Trailer regulations in UK |
Hi Frans,
You say that you are over the 750Kg weight limit. That is a surprise.
Assuming your empty aircraft with full fuel is somewhere around 450Kg (not
unreasonable I would think), that leaves 300Kg for the trailer. Even for a
fully enclosed trailer (as I have) that seems rather a lot. Mind you I do
get very obsessive about building light, whatever I am building.
Dave Watts
Posted: Sun Jan 13, 2013 4:10 am Post subject: Trailer regulations in UK |
On 01/13/2013 11:55 AM, David Watts wrote:
| Quote: | You say that you are over the 750Kg weight limit. That is a surprise.
I have put my empty trailer on an agricultural weight scale, and the
receipt said that it was 420 Kg's. Of course they usually measure the
amount of fertilizer loaded in a tractor which is a much higher weight
so the scale might be a little bit less precise on the lower end, but it
didn't look unreasonable to me. (Note that this is a trailer for a tri
gear, so it has a twin axle).
I just found the Europa Tri-gear Trailer Specification (the attached
file was rejected by Matronics) it says the empty weight is 360Kg. As I
have added boxes for the tail planes, a winch plus battery, spare wheel,
and some other goodies it might weight close to 420 Kg's after all. I
wish my Europa was only 330 Kg's but it is a tad heavier than that.
Frans
Posted: Sun Jan 13, 2013 4:25 am Post subject: Trailer regulations in UK |
Frans, Googling UK Towing Regulations gets you to
www.solentribster.com/towing_requirements.htm which nicely
summarises UK regs. There is no stipulated National limit
for the weight a car can tow. The limit is set by the
manufacturer and varies with the car. There is a
stipulation that if the trailer weight exceeds 750kg then
the trailer must have a braking system, but I cannot
imagine any plane trailer would be made without an
over-ride system.
Regards, David Joyce, G-XSDJ
On Sun, 13 Jan 2013 13:09:38 +0100
Frans Veldman <frans(at)privatepilots.nl> wrote:
>is a surprise.
scale, and the
usually measure the
higher weight
lower end, but it
trailer for a tri
(the attached
is 360Kg. As I
after all. I
than that.
Frans
Un/Subscription,
Forums!
Admin.
Posted: Sun Jan 13, 2013 4:40 am Post subject: Trailer regulations in UK |
David,
You say that you cannot imagine a plane trailer without an over-ride
system, buty the standard factory monowheel trailer has no brakes and it
seems to tow fine by all accounts.
Dave Watts, G-BXDY
Posted: Sun Jan 13, 2013 10:40 am Post subject: Trailer regulations in UK |
David, you are right but it probably weighs very little or
at least not enough to exceed the limit with an average
Europa.
On another tack, are you contemplating a
Laddingford fly in this year?
Regards, David Joyce, G - XSDJ
On Sun, 13 Jan 2013 12:39:47 -0000
David,
an over-ride
no brakes and it
Dave Watts, G-BXDY
Posted: Sun Jan 13, 2013 12:30 pm Post subject: Trailer regulations in UK |
Hi David,
Yes we are and I think Peter Kember will be contacting you shortly about it
as we have only discussed it in the last 2 days. The date will be 17th
August with a rain date of 18th.
Dave.
Richard Lamprey
Posted: Mon Jan 14, 2013 11:49 pm Post subject: Re: Trailer regulations in UK |
Thanks, Dave, David and Frans,
This is very useful indeed. I'll endeavour to have my builder keep the trailer down below 300 kgs, but he builds strong steel trailers for our potholed roads, so it may be a challenge.
All best
Richard
Kenya
Posted: Tue Jan 15, 2013 1:10 am Post subject: Trailer regulations in UK |
Richard, If you are still building it I would strongly
reccommended putting in an over-rite brake anyway. Whether
trailer + plane weigh 700 or 800 kg, it will still
seriously degrade your ability to stop in a hurry without
one? Regards, David Joyce, GXSDJ
On Mon, 14 Jan 2013 23:49:04 -0800
"Richard Lamprey" <lamprey.richard(at)gmail.com> wrote:
All best
Richard
Kenya
http://forums.matronics.com/viewtopic.php?p=392315#392315
Un/Subscription,
Forums!
Admin.
