Posted: Mon Apr 20, 2009 10:19 am Post subject: Converting Yak 55 to Cleveland wheels and brakes |
Has anyone converted their Yak 55M to Cleveland wheels and brakes and if yes, would you mind posting what the Cleveland part numbers are for the conversion? Thanks very much.
Dennis
A. Dennis Savarese
334-285-2141
334-546-8182 (cell)
Skype: yakworld1
www.yak-52.com
warner.wesley(at)gmail.co Guest
Posted: Tue Apr 21, 2009 1:38 pm Post subject: Converting Yak 55 to Cleveland wheels and brakes |
These are the the ones I used...
Std. Disc 199-104 $1589.00
http://www.aircraftspruce.com/catalog/lgpages/cleve_homebuiltwb.php
Hope that helps.
Wes
On Mon, Apr 20, 2009 at 2:18 PM, A. Dennis Savarese
<dsavarese0812(at)bellsouth.net> wrote:
| Quote: | Has anyone converted their Yak 55M to Cleveland wheels and brakes and if
Dennis
A. Dennis Savarese
334-285-2141
334-546-8182 (cell)
Skype: yakworld1
www.yak-52.com
Posted: Tue Apr 21, 2009 2:40 pm Post subject: Converting Yak 55 to Cleveland wheels and brakes |
Thank you very much Wes. Much appreciated.
Dennis
Posted: Tue Apr 21, 2009 3:02 pm Post subject: Converting Yak 55 to Cleveland wheels and brakes |
Sure. No problem. BTW, I used 15X6.00-6 tires. Are you planning on
using gear extensions, or just adapters?
On Tue, Apr 21, 2009 at 6:30 PM, A. Dennis Savarese
[quote] Thank you very much Wes. Much appreciated.
Dennis
Posted: Tue Apr 21, 2009 3:18 pm Post subject: Converting Yak 55 to Cleveland wheels and brakes |
I am gathering this information out for a gentleman in France. So whatever suggestions you pass along, I pass along to him.
Dennis
A Dawkins
Posted: Thu Jan 17, 2013 12:31 am Post subject: Re: Converting Yak 55 to Cleveland wheels and brakes |
Hi, I bought my yak 55 with Cleveland brakes installed. Had no problem except that you needed strong legs to hold the beast at full power. A year ago I had a back operation and don't have those legs anymore. I could not even hold the brakes at 50% power. It seems the ratio between the master cylinder and the calipers were not correct. The calipers fitted are similar to a Cherokee 140. I got hold of a set from a Cherokee that was in a crash and made a new torque plate to carry one caliper in front and one at the back.
Now the brakes feel normal and I have no problem holding 100% power. The pedal travel is +/- 15 mm from zero to max.
The calipers the yak came with have 50 mm pistons and the extra ones I fitted are 44 mm.
André Dawkins
adawkins(at)iafrica.com
South Africa.
A Dawkins
Posted: Thu Jan 17, 2013 12:41 am Post subject: Re: Converting Yak 55 to Cleveland wheels and brakes |
South Africa.
