		Strasnuts
  Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
				 Posted: Wed Jan 16, 2013 10:30 am    Post subject: Rear baffling |
				What is the consensus on rear cowling baffle length. I think mine is 2inches and I see fold marks where air might be escaping. Is shorter better?
  _________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
				 Posted: Wed Jan 16, 2013 6:00 pm    Post subject: Rear baffling |
				Not sure on what length you are referring to.  The thumb rule I know is
 there should be 3/8" to 1/2" clearance between the top of the baffle
 aluminum backing plate and the cowl.  The baffle material will of course be
 longer to both extend below the top and attach to the aluminum plate, bridge
 the gap to the cowl and have another inch or more to bend over to form with
 the top of the cowl so that it does not get blown out from the cowl intake
 air.
 Carl
		Strasnuts
				 Posted: Thu Jan 17, 2013 8:28 am    Post subject: Rear baffling |
				Yep. I'm talking about the amount of material that folds forward from the rear baffling. I have 2" and can see areas that air escapes past. It looks like the material is folding. Just not sure if it was shorter it would work better. I don't want it to flip to the other side though.
 On Jan 16, 2013, at 18:59, "Carl Froehlich" <carl.froehlich(at)verizon.net> wrote:
  air.
  Carl
780 Hours
		Tim Olson
				 Posted: Thu Jan 17, 2013 9:00 am    Post subject: Rear baffling |
				I've often wondered the same thing. Mine is maybe 1.5-2" of excess, so
 I probably have a 1-1.5" contact area with the top cowl, with all
 baffling curved inward to form a chamber.  Shorter would make it
 stiffer and maybe not give a smooth curved seal, I'm not sure.
 I've also been toying with the idea of switching from the Van's
 supplied stuff to silicone, but most silicone gasket seals are
 a tad thicker, which may change things too.  At any rate,
 I'd think that yours are probably normal length.  Mine are cut
 into a little shorter strips than some people may use, acting
 as pleats because of the curve of the seal.  If you have a
 one piece rear seal for instance, I don't think you'd get the
 flexibility enough to make a good seal.  By getting the slits
 and overlaps right, it seems like it goes together real well.
 On 1/17/2013 10:20 AM, Seano wrote:
  side though.
				 Posted: Thu Jan 17, 2013 10:05 am    Post subject: Rear baffling |
				I went with the silicone and love it. It worked suprisingly well.  A bit
 thicker and with alot more body. A minimal number of separate pieces to
 complete the job. The corners worked well.   Looks great and would seem
 to wear very well.  Very well sealed.
 Recently, I was having some trouble with my custom latch on my oil
 door.  One of the things I added was some of the silicone baffling
 material around the oil door to seal it up.  Previously, the air
 pressure would significantly deform the door by pushing the edges out.
 Adding strips of silicone reduced that significantly.  Need a pic or two.
 Bill
 On 1/17/2013 11:59 AM, Tim Olson wrote:
		Strasnuts
				 Posted: Thu Jan 17, 2013 10:19 am    Post subject: Rear baffling |
				Bill,
 I'm very interested in your oil door pics. I have the aftermarket hinge too and can see the edges bulging at cruise speeds. I've been thinking of ways to fix this.
 On Jan 17, 2013, at 11:04, Bill Watson <Mauledriver(at)nc.rr.com> wrote:
  I went with the silicone and love it. It worked suprisingly well.  A bit thicker and with alot more body. A minimal number of separate pieces to complete the job. The corners worked well.   Looks great and would seem to wear very well.  Very well sealed.
  Recently, I was having some trouble with my custom latch on my oil door.  One of the things I added was some of the silicone baffling material around the oil door to seal it up.  Previously, the air pressure would significantly deform the door by pushing the edges out.  Adding strips of silicone reduced that significantly.  Need a pic or two.
  Bill
780 Hours
		Kelly McMullen
				 Posted: Thu Jan 17, 2013 12:11 pm    Post subject: Rear baffling |
				You might want to consider the McFarlane cowl saver silicone. It is treated on one side so that it is slippery to the cowling, avoiding transfer of vibration and wear to the cowl. Of  course it costs a bit more. You will need to figure from your originals how much you need, as you don't want to pay for a lot left over.
 On Thu, Jan 17, 2013 at 9:59 AM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
 [quote] --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
   	  | Quote: | 	 		   --> RV10-List message posted by: Seano <sean(at)braunandco.com (sean(at)braunandco.com)>
  side though.
  http://forums.matronics.com
  le, List Admin.
A&P/IA, EAA Tech Counselor
KCHD |
		davidsoutpost(at)comcast. Guest
				 Posted: Thu Jan 17, 2013 6:26 pm    Post subject: Rear baffling |
				The Cowl Saver material from McFarlane is what I used.  One area I could not get it to conform and fit right was at the front of the engine around the intake openings and around the front of the case.  There I used the supplied Vans material and glued a strip of the cowl saver material on the inside of the top cowling where the Vans material meets the cowl.  I can't remember how mush I purchased feet wise but it was around $100 and I feel will be well worth the added expense in vibration reduction.
 David Clifford
 RV-10 Builder
 Howell,  MI
 Sent: Thursday, January 17, 2013 3:11:25 PM
 Subject: Re: Rear baffling
  side though.
  le, List Admin.
		Strasnuts
				 Posted: Thu Jan 17, 2013 7:18 pm    Post subject: Rear baffling |
				Thanks for the input.  I may try this and use  my old stuff as patterns.
  [quote]   ---
780 Hours
		Ron B.
				 Posted: Fri Jan 18, 2013 8:38 pm    Post subject: Re: Rear baffling |
				I ended up spending a lot of time bending a (I think it was.090") thick piece of alum. the shape of the cowl and now have a great oil door. I had to stiffen it also.
