keithmckinley
Posted: Sun Jan 27, 2013 8:06 am Post subject: deleted |
Last edited by keithmckinley on Tue Feb 19, 2013 7:24 pm; edited 1 time in total |
cjpilot710(at)aol.com Guest
Posted: Sun Jan 27, 2013 8:38 am Post subject: Air leak |
What about the flap actuator itself? Bad seals in the actuator will allow air pass the piston and vent out either flap handel.
Jim " Pappy" Goolsby
Sent from my iPad from some where on The 3rd rock from the Sun.
On Jan 27, 2013, at 11:07 AM, "keithmckinley" <keith.mckinley(at)townisp.com> wrote:
I developed a pretty bad air leak this summer coming from the rear gear selector port. I had never used the rear gear selector or the rear flap selector for that matter but found myself giving some dual from the rear cockpit so I started using those gear and flap selectors, which is when the trouble started. I found that with a certain amount of rapid cycling (from down to neutral) the rear gear selector seemed to "re seat" and the hissing would stop. Later on when the leak got bad again I used some castor oil through the valve 'in" port. This stopped the majority of the leak and my pressure was building and holding with the engine running. Around this time I also developed a bad hiss from the rear flap selector. I replaced the the rear flap selector and this seemed to stop that leak.
Fast forward to the last few months and the front gear selector is constantly venting and the front flap selector is REALLY venting in all positions. The rear gear selector seems quiet but I can feel a small amount of air venting from the port whenever the system is pressurized. My air compressor cannot keep up with the leaks. Thinking the problem was the selectors, I replaced the front gear selector and the front flap selector. This did not help at all.
So at this point all the QSF-2A's have been replaced
Today I pulled all the up lines off the 3 gear actuators at the actuators and the down line from the flap actuator and pressurized the system. I did not have any air leaking from the open side of any actuators at all so the actuators are all good. I did notice that the lines I disconnected from the 3 gear actuators and the line from the flap actuator had a very small amount of air venting through.
The emergency system was also checked at the fire wall check valves and NO air is entering the system from the emergency side. both check valves are fine.
GEAR:
My determination is that the air is being back fed through the system and the only culprit on the gear side could be the rear gear selector. Today, as soon as I replaced the rear gear selector the air stopped back feeding in the lines and therefore stopped venting from the front and rear gear selector ports. My guess is my front gear selector was fine all along and that it has been a bad rear selector for quite a while.
FLAP:
The new front flap selector is still leaking really bad and the new rear selector is quiet. I pressurized the system again and tried every different combination of front and rear flap selectors settings and the hissing from the front selector did not stop. I confirmed that during the checks that when the front flap handle was in the up position, placing the rear flap handle in the down position correctly caused the flaps to extend. However, placing the front flap selector in the down position, extending the flaps, and then placing the rear flap handle in the up position DID NOT retract the flaps.
The ONLY thing I can surmise is that a bad flap diverter valve is the culprit for the venting in the front flap selector?? How would this be possible with a brand new rear flap selector in the neutral position?
This post sheds a little light:
http://forums.matronics.com/viewtopic.php?t=40645&highlight=diverter
Obviously I need to replace one, perhaps both flap diverter valves, but what else am I missing here??? This is driving me nuts..
Keith McKinley
700HS
KFIT
http://forums.matronics.com/viewtopic.php?p=393132#393132
keithmckinley
Posted: Sun Jan 27, 2013 4:52 pm Post subject: Re: Air leak |
Hi Pappy,
If you read my trouble shooting again you'll see I disconnected one side of every actuator on the de-pressurized side then pressurized the system. there was no air leaking through any actuators at all. In fact the hoses that I had disconnected from the actuators had some air flowing which means it is back-feeding in the system. I solved that problem with a new rear gear selector. I'm guessing the flap issue is in a bad flap diverter valve, but I just dont have a good feel for the way air goes through that flap system.
BTW, whoever did the full color air schematic for the CJ... it has been a GREAT help!!!
Keith
