injector tuning
Goto page 1, 2  Next
Bob Turner
PostPosted: Sat Feb 02, 2013 12:24 pm    Post subject: injector tuning Reply with quote
I'm starting down the road of changing injector restrictors to bring all the peak EGT's into line. Two questions:
Most of the posts seem to be going to smaller injectors. Is there any reason not to go oversize? My two worst outliers are peaking last, I'd like to flow more thru them.
If instead I tried to go the other way, going undersize on the other 4 cylinders needing less fuel, is anyone concerned about maintaining adequate full throttle fuel flow? Or is this not an issue?
Stock XIO-540D4A5 from Vans.
Bob Turner
RV-10 QB
carl.froehlich(at)verizon
PostPosted: Sat Feb 02, 2013 1:12 pm    Post subject: injector tuning Reply with quote
If a cylinder is peaking last, that implies it is getting more fuel than the
other cylinders. To make a cylinder peak earlier (as compared to the other
cylinders) you put a slightly smaller injector in that cylinder to reduce
fuel flow.
One trick you may want to try first; swap your first to peak cylinder
injector with your last to peak cylinder injector. This might be just
enough change to get the cylinders all peaking at about the same fuel flow.
Carl
Tim Olson
PostPosted: Sat Feb 02, 2013 1:39 pm    Post subject: injector tuning Reply with quote
Going larger will make them peak even later...
Also, AFP often starts for other reasons with going all smaller and working from there.
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=393458#393458
amekler
PostPosted: Sat Feb 02, 2013 2:17 pm    Post subject: injector tuning Reply with quote
After spending many months with GAMI and never getting it right I went with Don Rivera at airflow performance. Don knows his stuff. He will look at your fuel flows and pressure at full throttle. I needed my flow divider recalibrated and he took care of this as well. Cylinders that peak last are too rich and will need restrictors.
Alan
N668G
Bob Turner
RV-10 QB
rv10pro(at)gmail.com
PostPosted: Sat Feb 02, 2013 2:25 pm    Post subject: injector tuning Reply with quote
Airflow Performance's twice yearly classes are invaluable opportunities to improve performance, safety and save fuel (money).  I agree Mr. Rivera and his wife were wonderful.
Your engine will love them too.
John Cox  (from the opposite side of this country) On Feb 2, 2013 2:19 PM, "Alan Mekler MD" <amekler(at)metrocast.net (amekler(at)metrocast.net)> wrote:[quote] --> RV10-List message posted by: Alan Mekler MD <amekler(at)metrocast.net (amekler(at)metrocast.net)>
Alan
 N668G
On Feb 2, 2013, at 3:24 PM, "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
> --> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
> Bob Turner
> RV-10 QB
le, List Admin.
Kelly McMullen
PostPosted: Sat Feb 02, 2013 6:42 pm    Post subject: injector tuning Reply with quote
Your cylinders that are peaking last are your richest. You want them leaner..smaller injector orifice.
On Sat, Feb 2, 2013 at 1:24 PM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
[quote]--> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Bob Turner
RV-10 QB
le, List Admin.
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Kellym
PostPosted: Sat Feb 02, 2013 7:14 pm    Post subject: injector tuning Reply with quote
Hmm, I've only heard one other negative report on GAMI, and in that case
the individual wasn't working closely enough to give GAMI the needed
data and doing the flight testing called for to get needed data for
adjustments. I don't know on 6 cyl Lyc engines, but on the 4 cyl
injected Lycs, more than 50% of time no injector adjustment is needed.
Alan
N668G
Checked by AVG - www.avg.com
Kelly McMullen
KCHD
arplnplt(at)gmail.com
PostPosted: Sat Feb 02, 2013 8:19 pm    Post subject: injector tuning Reply with quote
As you increase the size of the injectors, the pressure drops in the fuel system behind them causing uneven flow between them. Decreasing the size increases the pressure behind them and evens out the flow between them.Increase the size of one makes it richer, but it will decrease the pressure to the others possibly making them leaner. It is a balaning act.
David Leikam
On Feb 2, 2013, at 9:13 PM, Kelly McMullen wrote:
[quote]--> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
Hmm, I've only heard one other negative report on GAMI, and in that case the individual wasn't working closely enough to give GAMI the needed data and doing the flight testing called for to get needed data for adjustments. I don't know on 6 cyl Lyc engines, but on the 4 cyl injected Lycs, more than 50% of time no injector adjustment is needed.
Alan
N668G
Checked by AVG - http://www.matronics========================[b]http://www.matronics.com/co=================
Bob Turner
PostPosted: Sat Feb 02, 2013 8:29 pm    Post subject: Re: injector tuning Reply with quote
Okay, I've got dyslexia. I should have said my worst two outliers peak first, not last.
So again, why does AFP prefer to go smaller on four rather than larger on two? Is there any concern with not reducing fuel flow at full power?
Bob Turner
RV-10 QB
amekler
PostPosted: Sun Feb 03, 2013 5:02 am    Post subject: injector tuning Reply with quote
Before changing injectors I recommend you check your flow divider and the lines and check for any intake leaks(on the leaner cylinders)
then go to http://www.airflowperformance.com and contact Don with your flight data.
Alan
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=393483#393483
flying-nut(at)cfl.rr.com
PostPosted: Sun Feb 03, 2013 6:03 am    Post subject: injector tuning Reply with quote
Excellent advice. To answer the question though ...... making the two
'offenders' orifice smaller may make them too lean to start with. There
was a thread some time ago (I have a few lists Razz ) where that happened
... right out of the box they had a too-lean situation and going with
the fuel-flow data suggested smaller orifices on the offending cylinders
which made things worse. They ended up installing larger injectors and
re-working the data. Don't remember whether they were AFS injectors for
Lycs factory ones .......
Linn
On 2/3/2013 8:01 AM, Alan Mekler MD wrote:
Alan
> Bob Turner
> RV-10 QB
bill.peyton
PostPosted: Sun Feb 03, 2013 6:18 am    Post subject: Re: injector tuning Reply with quote
I just went through this with Kyle (at) AFP. AFP believes that it is best to change out all your injector restrictors to .026 or .027 depending on your spread. The stock injection system usually comes with .028. I chose not to do that since I had 2 that were peaking last and thus required a smaller orifice. I recorded data and downloaded it to Savvy.com (my.savvyanalysis.com/home) for analysis. I changed out the two rich restrictors to .0275, which brought them in to line with the rest. I had one that peaked first and tried switching to .0285, which did not work at all, so I removed it a settled for having a .3 - .4 spread, which allows me to get to 35 LOP smooth operation. This summer I plan on flying over and seeing Kyle and Don to have them all replaced a tweaked a little closer. I can tell you that you will have to take multiple readings and you have lean very very slowly. Kyle suggests that when they fly with you that they take 10-15 minutes to run a single lean test.
WA0SYV
Aviation Partners, LLC
Dick Sipp
PostPosted: Sun Feb 03, 2013 6:25 am    Post subject: injector tuning Reply with quote
We had a very similar experience with AFP and a stock 260HP IO-540. After two iterations with “std size†injectors we went one overall size smaller and then rebalanced.
Don said 260 HP was about the point where all the injectors go up one size. Sorry I don’t have access here to the actual sizes we ended up with. As part of the process, full power fuel flow was checked to insure rich enough at takeoff. As previously noted Don’s school and work are outstanding.
Dick Sipp
N110DV 450 hours
Sent: Saturday, February 02, 2013 11:19 PM
Subject: Re: injector tuning
As you increase the size of the injectors, the pressure drops in the fuel system behind them causing uneven flow between them. Decreasing the size increases the pressure behind them and evens out the flow between them. Increase the size of one makes it richer, but it will decrease the pressure to the others possibly making them leaner. It is a balaning act.
David Leikam
Alan
N668G
Checked by AVG - http://www.matronics========================http://www.matronics.com/co=================
[/b] [quote][b]
partner14
PostPosted: Sun Feb 03, 2013 7:01 am    Post subject: injector tuning Reply with quote
When discussing this it would have been nice to know the actual numbers you came up with. GPH for each cyl when reaching LOP. Having those would have made this thread a little shorter.
Just an FYI....Although my experience may be different than some, what I can tell you is that there sure seem to be a few variables out there.... altitude, MP, RPM, wind direction, BP, and maybe most important, how long it's been since your last injector cleaning. When the previously mentioned change, the LOP numbers may also change.
Don McDonald
Date: Saturday, February 2, 2013, 10:29 PM
--> RV10-List message posted by: "Bob Turner" <[url=/mc/compose?to=bobturner(at)alum.rpi.edu]bobturner(at)alum.rpi.edu[/url]>
Bob Turner
RV-10 QB
http://www.matronics.com/Navigator?RV10-List --> http://www.matronics.com/co=================
Don A. McDonald
40636
cooprv7(at)yahoo.com
PostPosted: Sun Feb 03, 2013 10:01 am    Post subject: injector tuning Reply with quote
You bring up a good point Don that I don't know the answer to. How does one clean the injectors and how often should this be done?
Marcus
On Feb 3, 2013, at 10:00 AM, Don McDonald <building_partner(at)yahoo.com (building_partner(at)yahoo.com)> wrote:
Don McDonald
--- On Sat, 2/2/13, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
From: Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
--> RV10-List message posted by: "Bob Turner" <[url=x-msg://17/mc/compose?to=bobturner(at)alum.rpi.edu]bobturner(at)alum.rpi.edu[/url]>
Bob Turner
RV-10 QB
robin(at)PaintTheWeb.com
PostPosted: Sun Feb 03, 2013 10:17 am    Post subject: injector tuning Reply with quote
We had the smallest amount of carbon in one restrictor and another one had white fuzzy stuff. All the restrictors were cleaned in an ultra-sonic cleaner. I didn’t see the process as it was done by a friend in their industrial unit. I do see some units on eBay for cheap but have no idea if they are appropriate. Regardless the end result was more consistent fuel flow.
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marcus Cooper
Sent: Sunday, February 03, 2013 10:00 AM
Subject: Re: Re: injector tuning
Marcus
Don McDonald
Bob Turner
RV-10 QB
href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com/">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/contribution
==============[/b][/quote] V10-List Email Forum -[/b][/quote] >[/b][/quote] :p>[/b][/quote] /o:p>[/b][/quote] tor?RV10-List">http://www.matronics.com/Navigator?RV10-List[/b][/quote] ==============[/b][/quote] nbsp; - MATRONICS WEB FORUMS -[/b][/quote] :p>[/b][/quote] tp://forums.matronics.com[/b][/quote] ==============[/b][/quote] bsp; - List Contribution Web Site -[/b][/quote] e> bsp;   -Matt Dralle, List Admin.[/b][/quote] bution">http://www.matronics.com/contribution[/b][/quote] ==============[/b] [/quote]
:p>
partner14
PostPosted: Sun Feb 03, 2013 10:20 am    Post subject: injector tuning Reply with quote
Really simple... a trip to Walmart, buy Hoppe's gun cleaner. get a SMALL muffin tray, label them 1-6, put each nozzle in there overnight... done deal.... I tried to do it every other year, but suggest every year for frequent flier's like myself.
Don
Date: Sunday, February 3, 2013, 12:00 PM
Marcus
On Feb 3, 2013, at 10:00 AM, Don McDonald <[url=/mc/compose?to=building_partner(at)yahoo.com]building_partner(at)yahoo.com[/url]> wrote:
Don McDonald
--- On Sat, 2/2/13, Bob Turner <[url=/mc/compose?to=bobturner(at)alum.rpi.edu]bobturner(at)alum.rpi.edu[/url]> wrote:
From: Bob Turner <[url=/mc/compose?to=bobturner(at)alum.rpi.edu]bobturner(at)alum.rpi.edu[/url]>
To: [url=/mc/compose?to=rv10-list(at)matronics.com]rv10-list(at)matronics.com[/url]
--> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu>
Bob Turner
RV-10 QB
http://www.matro====================
Don A. McDonald
40636
PostPosted: Sun Feb 03, 2013 10:40 am    Post subject: injector tuning Reply with quote
Thanks to both the responses. I happen to have gun cleaner,not sure if I can talk my wife out of the muffin pans though Wink
Any tricks to removing and reinstalling the injectors. Considering all the work I've done on the 4 airplanes I've built and maintained I'm amazed I never tackled this particular project.
Thanks again,
Marcus
On Feb 3, 2013, at 1:19 PM, Don McDonald <building_partner(at)yahoo.com (building_partner(at)yahoo.com)> wrote:
Don
--- On Sun, 2/3/13, Marcus Cooper <cooprv7(at)yahoo.com (cooprv7(at)yahoo.com)> wrote:
From: Marcus Cooper <cooprv7(at)yahoo.com (cooprv7(at)yahoo.com)>
Marcus
On Feb 3, 2013, at 10:00 AM, Don McDonald <[url=x-msg://26/mc/compose?to=building_partner(at)yahoo.com]building_partner(at)yahoo.com[/url]> wrote:
Don McDonald
--- On Sat, 2/2/13, Bob Turner <[url=x-msg://26/mc/compose?to=bobturner(at)alum.rpi.edu]bobturner(at)alum.rpi.edu[/url]> wrote:
From: Bob Turner <[url=x-msg://26/mc/compose?to=bobturner(at)alum.rpi.edu]bobturner(at)alum.rpi.edu[/url]>
To: [url=x-msg://26/mc/compose?to=rv10-list(at)matronics.com]rv10-list(at)matronics.com[/url]
Bob Turner
RV-10 QB
partner14
PostPosted: Sun Feb 03, 2013 11:12 am    Post subject: injector tuning Reply with quote
REALLY simple, even Robin could do it... maybe Pascal to! I don't have any pics... but once you look at the system, you'll have no problem figuring it out.
Don
Date: Sunday, February 3, 2013, 12:40 PM
Thanks again,
Marcus
On Feb 3, 2013, at 1:19 PM, Don McDonald <[url=/mc/compose?to=building_partner(at)yahoo.com]building_partner(at)yahoo.com[/url]> wrote:
Don
--- On Sun, 2/3/13, Marcus Cooper <[url=/mc/compose?to=cooprv7(at)yahoo.com]cooprv7(at)yahoo.com[/url]> wrote:
From: Marcus Cooper <[url=/mc/compose?to=cooprv7(at)yahoo.com]cooprv7(at)yahoo.com[/url]>
Marcus
On Feb 3, 2013, at 10:00 AM, Don McDonald <building_partner(at)yahoo.com> wrote:
Don McDonald
Bob Turner
RV-10 QB
http://www.matronics.com/Navigator?RV10-ofollow" target="_blank" href="http://www.matronics.com/contribution">h
Don A. McDonald
40636
PostPosted: Sun Feb 03, 2013 12:02 pm    Post subject: injector tuning Reply with quote
My only tip is be gentle with the FI lines. You will be swapping out restrictors several times. Just take it easy on the lines to prevent kinking.
Robin
Sent: Sunday, February 03, 2013 10:40 AM
Thanks again,
Marcus
Don
Marcus
Don McDonald
Bob Turner
RV-10 QB
6 ==============[/b][/quote] V10-List Email Forum -[/b][/quote] >[/b][/quote] :p>[/b][/quote] /o:p>[/b][/quote] tor?RV10-List">http://www.matronics.com/Navigator?RV10-List[/b][/quote] ==============[/b][/quote] bsp; - MATRONICS WEB FORUMS -[/b][/quote] :p>[/b][/quote] tp://forums.matronics.com[/b][/quote] ==============[/b][/quote] bsp; - List Contribution Web Site -[/b][/quote] e> bsp;   -Matt Dralle, List Admin.[/b][/quote] bution">http://www.matronics.com/contribution[/b][/quote] ==============[/b] [/quote]7
:p>
Goto page 1, 2  Next
Page 1 of 2
