Tim Olson
Posted: Mon Feb 04, 2013 2:53 pm Post subject: RV-List: Re: Fwd: [MARKETING] VP-200/Dynon SkyView Service B |
I'm just glad my circuit breakers are still at release 1.0a firmware.
Saved me tons of time over the years with software revs on attached devices.
On Feb 4, 2013, at 4:01 PM, "Pascal" wrote:
[quote] According to Dynon Support -We only moved a few parameters around in the new serial stream, so it's unfortunate that it will take them months to fix this as it's likely just a few constants in their code to make it work again.
Hopefully “We are investigating the issue and will have additional details in the future.” means they may release a fix much sooner than the expected Q2 that I was told last Friday. Granted this should not be VP issue, kudos, to Marc for at least providing a fix, even if it is a potential long wait.
Sent: Monday, February 04, 2013 12:50 PM
To: rv10-list(at)matronics.com (rv10-list(at)matronics.com) ; rv-list(at)matronics.com (rv-list(at)matronics.com)
Subject: Fwd: [MARKETING] VP-200/Dynon SkyView Service Bulletin
Well, at least Vertical Power is listening.
rv10flyer(at)live.com Guest
Posted: Mon Feb 04, 2013 3:30 pm Post subject: RV-List: Re: Fwd: [MARKETING] VP-200/Dynon SkyView Service B |
Truthfully this is not a circuit breaker rev issue it’s a flight modes issue. To put this in perspective the VP-x, which is the circuit breaker is not “broke” has worked from day one and is not impacted by the dynon upgrade. With the VP-200 it adds a whole lot more safety than your rev 1.0a, the modes automatically kick in when a Emergency is sensed, if there is an electrical failure, it identifies the issue, shuts it down and will even go into a pre planned shutdown list to eliminate a fire, same with engine out, preset boost and checklist appears on steps to follow. It was all working and the circuit breaker piece continues to work regardless of the Dynon improvements, it’s the modes and engine information that one needs “correction” or it is lost.
Sent: Monday, February 04, 2013 2:52 PM
Subject: Re: RV-List: Re: Fwd: [MARKETING] VP-200/Dynon SkyView Service Bulletin
gengrumpy(at)aol.com Guest
Posted: Mon Feb 04, 2013 5:31 pm Post subject: RV-List: Re: Fwd: [MARKETING] VP-200/Dynon SkyView Service B |
Amen Tim!
Grumpy
Sent from my iPad
On Feb 4, 2013, at 4:52 PM, Tim Olson <Tim(at)MyRV10.com (Tim(at)MyRV10.com)> wrote:
[quote]I'm just glad my circuit breakers are still at release 1.0a firmware.
