Doc Farley's Europa
cgalley(at)qcbc.org
PostPosted: Thu Jun 08, 2006 11:57 am    Post subject: Doc Farley's Europa Reply with quote
Did a little checking on the plane... Rotax 912 powered
Europa Loaded with all sorts of electronics.
Two Grand Rapids EFIS displays,
Tru-Track 3 axis Auto pilot with the latest updates,
Insight Strike Finder,
Garman GPS, EIS engine display,
Reserve Lift indicator,
King Transponder and I presume encoder as it was based at a class C
airport,
Airmaster Constant Speed prop zero time,
King 197 Com,
ICS + NAV-COMM,
PS-Engineering Intercom,
LightSpeed head sets,
even a Sirs Compass.
AI, DG, Turn Corr, ROC for backup. There is a portable Oxygen system
available.
Have several Rotax engine manuals being latest dated 2002, Europa
Builder's
Manual, Europa Owner's Manual, etc. First Flight Nov 2001. Has 515 TT
according to the log books. There is a ground transportation Trailer.
Picture with electronics fired up.
Cy Galley - 309-738-0522
 Filesize:  137.38 KB
 Viewed:  328 Time(s)
