triumphrider
Posted: Tue Feb 19, 2013 6:44 am Post subject: Aileron Trim Tabs-Anyone Using? Photos to Share? |
We had a discussion on the left roll tendency that my Pulsar XP has. It doesn't track straight-I have to have a slight amount of right pressure on the center stick to keep it tracking straight. Let go and it begins a slight left turn. Kind of a pain when you need to review a sectional, etc.
I usually fly solo, so perhaps the weight on the left seat only is also a factor?
Are you using a aileron trim tab(s)? Does anyone have a picture of a small trim tab they are using for on their aircraft and perhaps, a source for them?
I have a small trim tab on the rudder-it's about an inch wide and at a 30-degree angle or so from the rudder tab-Is this the same size I should be looking for?
pilot623(at)gmail.com Guest
Posted: Tue Feb 19, 2013 7:04 am Post subject: Aileron Trim Tabs-Anyone Using? Photos to Share? |
I have a roll trim system that uses a servo to control the centering point
of a two spring system. Due to the left wing heavy tendency of my plane, the
trim system had to be kept full right. I added an 18" piece of balsa wood
which is designed to be the trailing edge of a model airplane wing. It is
taped to the underside of the right aileron near the outboard end, with the
thinner dimension facing forward. This allows my trim system to remain
fairly centered in its travel. The balsa is on the underside of the aileron
so is not visible unless you bend down and look for it. I am happy with my
"trim tab" which has been in place for more than 7 years (using the original
tape).
Jim
N623JF
Series 2.75
dougwitkowski(at)netscape Guest
Posted: Tue Feb 19, 2013 8:12 am Post subject: Aileron Trim Tabs-Anyone Using? Photos to Share? |
I used a simple wedge shaped balsa piece (1/4" x 1") double-side taped to the underside of one aeleron. Cut length based on correction needed. Been there 16 years.
garymid(at)ymail.com Guest
Posted: Wed Feb 20, 2013 9:13 am Post subject: Aileron Trim Tabs-Anyone Using? Photos to Share? |
FWIW: N9DK does not have aileron trim tabs, just servo trim. I often fly hands-off for extended periods with only minor rudder inputs every few minutes. In fact, it makes you lazy and I may look down at my flight plane, phone or sectional for much longer than I really should. I do tweak the trim during the flight to compensate for fuel burn, and she is more stable at certain speeds than others. ~120mph seems to be a sweet spot for the longest period of time without control input needed.
From: triumphrider <investmentsalesconsultant(at)gmail.com>
Sent: Tuesday, February 19, 2013 9:44 AM
Subject: Aileron Trim Tabs-Anyone Using? Photos to Share?
--> Pulsar-List message posted by: "triumphrider" <investmentsalesconsultant(at)gmail.com (investmentsalesconsultant(at)gmail.com)>
http://forums.matronics.com/viewtopic.php?p=394568#394568
