jeff(at)westcottpress.com Guest
Posted: Tue Feb 19, 2013 11:40 am Post subject: Installation of fittings on the engine |
I've been hunting around for guidance on the installation of the NPT fittings on the engine (such as the VA-128 and the AN823-8D) and have, so far, come up short. Are there specific torque ranges? What thread lube/sealant should be used?
Jeff Carpenter
40304
Trying to hang this engine...
schmoboy
Posted: Tue Feb 19, 2013 12:29 pm Post subject: Installation of fittings on the engine |
I've been using the torque tables from a reprint of the Lycoming
Overhaul Manual. Lycoming part number 60294-X where X varies on the
printing. I think mine is 60294-7.
Contact me off list if you'd like a PDF of just the torque tables from
the manual.
-Sean #40303 (finishing engine baffles)
On 2/19/13 1:39 PM, Jeff Carpenter wrote:
Jeff Carpenter
40304
Posted: Tue Feb 19, 2013 3:00 pm Post subject: Installation of fittings on the engine |
On 2/19/2013 2:39 PM, Jeff Carpenter wrote:
Snug is good for tapered pipe fittings.
| Quote: | and have, so far, come up short. Are there specific torque ranges?
Not that I know of either.
| Quote: | What thread lube/sealant should be used?
I use Fuel Lube ....
Linn
Jeff Carpenter
40304
Checked by AVG - www.avg.com
