sidsel.svein(at)oslo.onli Guest
Posted: Thu Feb 21, 2013 3:38 am Post subject: SV: Red Cube transducer k factor |
John,
Congratulations - it's a very good instrument. I also have if for a 912
ULS.
I used mine straight out of the box, no adjustments have been required.
However, if you do not have the return flow transducer and the differential
module, I wonder how your readings may be - with or without adjusting the
K-factor.
Svein
LN-SKJ
john.heykoop(at)gmail.com Guest
Posted: Thu Feb 21, 2013 3:52 am Post subject: SV: Red Cube transducer k factor |
Hi Svein
Sorry, I should have made it clear that I do not have a return flow transducer. However, the advise from a number of Europa pilots is that with the Rotax 912S you can get away with having a single transducer, as the K factor can take the return flow into account.
On 21 Feb 2013, at 11:38, "Sidsel & Svein Johnsen" <sidsel.svein(at)oslo.online.no> wrote:
John,
ULS.
K-factor.
Svein
LN-SKJ
