stranfaer(at)btinternet.c Guest
Posted: Fri Feb 22, 2013 12:41 am Post subject: Parts required panel shroud |
Having recently looked at the possibility of selling my aircraft, only to be messed around and insulted by time wasters and dreamers and people looking for a free hours flying (you would all be surprised at how many arm chair experts are out there) I have now decided to treat her to a new Dynon engine management system and do what she does best and "FLY".
Does anyone have a spare instrument panel for a classic or a perhaps cad computer design that I can get a CNC blanking plate made up for my current shroud and my new instruments?
My best regards to all fellow Europa brethren / owners
David Joyce G-BXGG
The other one
Sent to you from David Joyce
www.eastmidsspas.com
Posted: Fri Feb 22, 2013 1:46 am Post subject: Parts required panel shroud |
David, I believe there is a standard mod for putting in
removable panels, which can be made of alloy or ply coated
in bid. If you make up panel patterns in card or paper it
is easy enough to play around with the lay out and then
form an accurate template for the actual panels. Regards,
David (Joyce - the original one!), G- XSDJ
On Fri, 22 Feb 2013 08:41:18 +0000 (GMT)
DAVID JOYCE <stranfaer(at)btinternet.com> wrote:
best and "FLY".
instruments?
David Joyce G-BXGG
The other one
rowlandcarson(at)gmail.co Guest
Posted: Fri Feb 22, 2013 3:20 am Post subject: Parts required panel shroud |
On 22 Feb 2013, at 08:41, DAVID JOYCE wrote:
| Quote: | Does anyone have a spare instrument panel for a classic or a perhaps cad computer design that I can get a CNC blanking plate made up for my current shroud and my new instruments?
David - Europa supply a blank panel (as IM01M-NH, although that seems to have disappeared from the current list) and also one pre-punched with the "standard" six-pack instrument holes (as IM01M at £39). See <http://www.europa-aircraft.co.uk/parts/> and choose approved optional mods.
I have drawn up the panel in a CAD package and can let you have a .DXF file if that would be of interest.
in friendship
Rowland
| pictures: http://picasaweb.google.com/rowlandcarson
aircraftspecialty(at)gmai Guest
Posted: Fri Feb 22, 2013 4:47 am Post subject: Parts required panel shroud |
Aircraft Specialty offers Cnc instrument panel cutting services, powdercoating and labeling of panels.
Go to www.aircraftspecialty.com for more info.
Have a great day
Steve
On Feb 22, 2013, at 2:41, DAVID JOYCE <stranfaer(at)btinternet.com (stranfaer(at)btinternet.com)> wrote:
David Joyce G-BXGG
The other one
cs.com
matronics.com/contribution
pete(at)lawless.info Guest
Posted: Fri Feb 22, 2013 5:50 am Post subject: Parts required panel shroud |
Hi
Europa have a range of precut aluminium panels for the classic instrument
panel.
I think they are on the Europa website somewhere.
Pete
bshafer708(at)gmail.com Guest
Posted: Fri Feb 22, 2013 6:41 am Post subject: Parts required panel shroud |
Hi everyone,
I used Front Panel Express (www.frontpanelexpress.com). They have a design program that is easy to use or will take CAD files as input. You can then price out the panel and order right from the program. My main panel was about $125 USD but a lot of that came from the engraved written on the panel. The program breaks down all the costs so you can add and remove what you need to keep the cost in line. You can also pick the material and thickness. I attached a picture of my panel in the program so you can get an idea. If you want any of my design files to use as a starting port, let me know.
Brad
A251
103.88 KB |
6596 Time(s) |
Posted: Fri Feb 22, 2013 8:35 am Post subject: Parts required panel shroud |
On 22 Feb 2013, at 12:03, Paul Mansfield wrote:
| Quote: | If you're happy to share your .DXF I'd be grateful for a copy
Paul - and anyone else who wants it - you can get my CAD files at the following URLs. Your browser will probably download them automatically if you click on the link, or copy & paste it into your browser address panel. NB - case is significant! I've uploaded several versions because many CAD programs will not play with every revision of the AutoCad file specs. If (f'rinstance) the spline forming the top edge of the panel does not appear when you open the file in your own CAD package, try a different version.
http://www.rowlandcarson.org.uk/tempo/main_panel_r12.DXF
http://www.rowlandcarson.org.uk/tempo/main_panel_r14.dxf
http://www.rowlandcarson.org.uk/tempo/main_panel_r2007.dxf
http://www.rowlandcarson.org.uk/tempo/main_panel.dwg
I can also, given a bit more time, put up copies of my own panel design with holes etc. In the end, I didn't use it, deciding it was easier to buy the pre-punched panel from Europa. I think that was not available when I started drawing up my own ideas, or maybe I thought I could do better!
I have also recently moved my build log from my old ClaraNET host to a new one. You can find the whole thing starting at:
http://www.rowlandcarson.org.uk/aviation/europa_435/index.php
in friendship
Rowland
Paul M 383
Joined: 19 Mar 2012 Posts: 102 Location: United Kingdom
Posted: Mon Feb 25, 2013 12:08 pm Post subject: Re: Parts required panel shroud |
Thanks Rowland!
P
