Gwayne
Posted: Thu Feb 21, 2013 8:58 am Post subject: PC925L & PC680 mounting |
I have searched the archives and can't seem to fine any pictures or discussion on mounting a dual battery system comprising of a PC925L and PC680. Anybody have any pictures of their mounting configuration or "if I had to do it again" confessions?
I have considered the PC925L in standard rear position and PC680 on the firewall as in the RV7.
Wayne
RV10 final wiring
RV7"eh?" flying
_________________ Wayne
RV 7 "eh?" 120 hrs
RV 10 fuse |
rvdave
Posted: Thu Feb 21, 2013 1:44 pm Post subject: Re: PC925L & PC680 mounting |
That's the same configuration I'm looking at. Vans as you point out has a firewall kit for the pc680, I'm also looking at the Hawker tray. It's similar to the one I have in my flying 6 although the battery in the 6 is smaller. I believe someone has installed the firewall 680 and am looking for photos as well.
_________________ Dave Ford
Cadillac, MI |
rene(at)felker.com Guest
Posted: Thu Feb 21, 2013 2:33 pm Post subject: PC925L & PC680 mounting |
I put a 680 on my firewall and have managed to kill the battery in two
years. I think it was a heat problem. Next month while I am doing my
condition inspection I am planning on taking the battery down to the battery
shop and having them check it out and see if they can help tell me what went
wrong. I have a 925 in the back that dates back to 2007. It is still going
strong, but I am planning on having that checked out also. I put the 680 on
the firewall after I was flying for extra reserve power and.....to move the
CG forward. When I was building the airplane, because of some online
discussions, I was concerned about the forward CG position of the stock
airplane and made some decisions that drove the CG back (o2 and ELT
placement). But after I was flying I found the CG to far back. So, I added
the battery.
Rene' Felker
N423CF
801-721-6080
bill.peyton
Posted: Thu Feb 21, 2013 4:09 pm Post subject: Re: PC925L & PC680 mounting |
Here is our set up. The PC925 fits perfect in the existing Vans designed tray. I have no CG issues. I have the Hartzell 2 blade prop, which helps keep it forward.
88.52 KB |
10064 Time(s) |
97.62 KB |
10007 Time(s) |
_________________ Bill
WA0SYV
Aviation Partners, LLC
Kelly McMullen
Posted: Thu Feb 21, 2013 4:47 pm Post subject: PC925L & PC680 mounting |
Seems like you need the 925L to match the cables as Vans supplies them, with the negative at the front end of the battery and positive to the rear.
On Thu, Feb 21, 2013 at 5:09 PM, bill.peyton <peyton.b(at)sbcglobal.net (peyton.b(at)sbcglobal.net)> wrote:
[quote]--> RV10-List message posted by: "bill.peyton" <peyton.b(at)sbcglobal.net (peyton.b(at)sbcglobal.net)>
WA0SYV
http://forums.matronics.com/viewtopic.php?p=394768#394768
http://forums.matronics.com//files/img_1978_561.jpg
le, List Admin.
A&P/IA, EAA Tech Counselor
KCHD |
rvdave
Posted: Thu Feb 21, 2013 4:58 pm Post subject: Re: PC925L & PC680 mounting |
Nice setup Bill, do you have any photos of your tray construction and supports for the battery and accessories?
Cadillac, MI |
Posted: Thu Feb 21, 2013 6:16 pm Post subject: PC925L & PC680 mounting |
Nice!
Robin
Sent from the new iPad
On Feb 21, 2013, at 7:13 PM, "bill.peyton" <peyton.b(at)sbcglobal.net> wrote:
bill.peyton
rv10flyer
Posted: Thu Feb 21, 2013 7:14 pm Post subject: Re: PC925L & PC680 mounting |
Mine is set up almost like Bill's. I made my own 680 holder. It is supported off of the factory battery mount. The bottom of holder is bonded to bottom skin with proseal. If I had it to do over, I would have installed the 680 on the firewall since 95% of my flights are with family and baggage. It limits my baggage to 99 lbs with existing rear seat passenger weights. I like the 30-45 minutes of panel power and aux starting capabilities. No ext power connector needed.
_________________ Wayne G. |
rvdave
Posted: Fri Feb 22, 2013 7:25 am Post subject: Re: PC925L & PC680 mounting |
Bill, how did you support the additional tray both under and toward the f1047 rib?
Cadillac, MI |
bill.peyton
Posted: Fri Feb 22, 2013 11:12 am Post subject: Re: PC925L & PC680 mounting |
That side of the tray has a stiffener that slides under the rib to reinforce the rib. I used 3 #8 hardware to attach to the rib. It's very solid.
WA0SYV
Aviation Partners, LLC |
rvdave
Posted: Wed Feb 27, 2013 7:19 am Post subject: Re: PC925L & PC680 mounting |
Have been doing a little research on pc680 & firewall mounting. The pc680mj is rated for temps of 176f vs 680 at 140f. The tray that hawker sells for the 680 only, provides nice protection though. Not sure if that would increase its rating or what real firewall temps would be behind baffling but within exhaust piping area . I have a smaller 7ah battery on my 6 with the sd8 alternator mounted high in the center of the firewall but usually change that one out every other year. I guess real question is what are real world firewall temps on the 10?
Cadillac, MI |
bill.peyton
Posted: Wed Feb 27, 2013 1:56 pm Post subject: Re: PC925L & PC680 mounting |
They run as high as 190 F on a hot summer day at the lower firewall
WA0SYV
