Alan Carter
Joined: 02 Jul 2012 Posts: 378 Location: Kent, England.
Posted: Tue Feb 26, 2013 5:54 pm Post subject: Stater Relay is 6 amps switch OK |
starter motor.
I want to install a separate starter button, i have purchased a press button switch, rated at 6 amps (at) 12 v and 6 amps (at) 250v
Is this OK.
The switch spec.
http://uk.rs-online.com/web/p/push-button-switches/6915242/?
Alan
pete(at)lawless.info Guest
Posted: Tue Feb 26, 2013 11:53 pm Post subject: Stater Relay is 6 amps switch OK |
Morning Alan
I would think so. The starter switch circuit should be protected by a 2 amp
CB according to the manual.
My switch is nothing like as good as that one. Looking at the spec these
are clearly intended for vehicle use so should be fine. You must have
bought the last one the RS website is now showing your link as back order
shipping 15 April.
Another grey and damp morning up here. Glad I got a fly on Saturday it has
not been fit since.
My mate at Goodwood got a go in an Extra 330 on Sunday. He timed the take
off - 4 seconds from start of roll to airborne at 70 kts. Mind you it is a
540 cu in engine that is 9.55 litres! Said it was a lovely aeroplane to fly
even if you could not see where you were going.
Pete
stephen vestuti
Posted: Wed Feb 27, 2013 1:14 am Post subject: Re: Stater Relay is 6 amps switch OK |
Thanks Alan, that's just what I've been looking for.
It has to energise the starter relay of course,
Steve.
Posted: Wed Feb 27, 2013 1:16 am Post subject: Stater Relay is 6 amps switch OK |
Sorry guys that last one was not for general consumption I hit the wrong
button!
DO NO ARCHIVE
Alan Carter
Posted: Wed Feb 27, 2013 12:14 pm Post subject: Re: Stater Relay is 6 amps switch OK |
Hi All.
So 6 amps is OK, i am not a builder so don,t have odd pieces of alloy laying around so had to use an old plate i found, i have made my little panel and fitted it in place, also made a little CB panel, to connect it to. Sometime i will get round to wiring it up,so a couple of questions.
The switches are 6 amps at 135v AC so i am limiting the Aux power sockets to
6 amps each by an in line fuse. I am not sure if the switch would take 10 amps at 12 volts ? 6 or 10 ?
The usage will be, phone, ipad, inspection lamp, tyre pump,
I intend to put the 2 x in line fuse on the (live + wires) BEFORE the switches,?
The Starter Button, is 6 amps, and power switch also 6 amps, flip the switch and the START BUTTON illuminates in RED,then Press for start.
Does anyone have the Rotary Mag key starter switch, because i need the starter relay wire from this switch, i take it that its is single pole so just the two wire to be taken over to my new switch, which two.?
This will now give me independent mags, for engine starting.
Later the Soft Start module this is only 20 minutes to fit if you have separate mag switches, its the easy bit.
Alan
houlihan(at)blueyonder.co Guest
Posted: Wed Feb 27, 2013 12:35 pm Post subject: Stater Relay is 6 amps switch OK |
Alan.
Just a thought, your aircraft has a LAA permit, I assume , and if so you must have an LAA inspector to sign off your re wiring work.
He , the inspector, is the best person to check out these options and changes. and give you advice
. The forum is a good place for information but in the end it is wise to have your plans looked over by another independent pair of eyes.
regards
On 27 February 2013 20:14, Alan Carter <alancarteresq(at)onetel.net (alancarteresq(at)onetel.net)> wrote:
[quote] --> Europa-List message posted by: "Alan Carter" <alancarteresq(at)onetel.net (alancarteresq(at)onetel.net)>
Hi All.
Alan
http://forums.matronics.com/viewtopic.php?p=395212#395212
target="_blank">http://www.matronics.com/Navigator?Europa-List
le, List Admin.
Alan Carter
Posted: Wed Feb 27, 2013 1:28 pm Post subject: Re: Stater Relay is 6 amps switch OK |
Hi Tim.
Yes , I am fitting torque tube clamps at the moment and the tubes are away for the fitting of new pins as well, but want the whole job done, so my inspector can check out the whole lot when he visits, the forum has people who are experts in there field, engines , electrics, and its useful to
get there opinions also.
Alan
