Greg.Puckett(at)united.co Guest
Posted: Thu Jun 08, 2006 6:15 pm Post subject: N-Number font |
This is starting to seem a little ridiculous but,
Does anyone know of a commonly available computer font that meets all of the requirements of FAR 45.29 for registration marks?
Specifically, the way I read it, they want the width of all characters to be two thirds of the height except for 1's W's and M's. I neglected to get somebody to make me a stencil and I need to finish spraying the trim and clear tomorrow. I would like to paint the reg. marking rather than have the stick on.
I would like to just cut my own stencil from a product called "frisket film" and paint the number on but I'm worried that if I don't meet the letter of the regs I could be screwed.
Has anyone ever run in to a problem with a DAR over this?
Greg Puckett
Elizabeth, CO
RV-8 (finally getting close)
Dale Ensing
Posted: Thu Jun 08, 2006 7:33 pm Post subject: N-Number font |
Greg, you may want to check with your DAR. Recently a DAR in our area
required an RV to put on the 12 in. letters because the builder said the
plane was capable of more than 200 mph.
Dale
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
dan(at)rvproject.com Guest
Posted: Thu Jun 08, 2006 8:10 pm Post subject: N-Number font |
No offense to the DARs on this list, but don't let the DAR push you around.
Here's the reg...from Part 45.29:
(iii) Marks at least 3 inches high may be displayed on an aircraft for which
the FAA has issued an experimental certificate under §21.191 (d), §21.191
(g), or §21.191 (i) of this chapter to operate as an exhibition aircraft, an
amateur-built aircraft, or a light-sport aircraft when the maximum cruising
speed of the aircraft does not exceed 180 knots CAS;
Then the question is...who determines the aircraft's maximum cruising speed?
Is it YOU the builder, or is it Van's, the kit manufacturer? How can you
possibly know your aircraft's max cruising speed prior to actually flying
it? I guess they have to take Van's specs then...
And if so...
http://www.vansaircraft.com/public/rv-7per.htm
75% Cruise for an RV-7 with the biggest powerplant Van's "endorses" for the
design...200hp solo weight 75% cruise is 207 mph = 180 knots. But guess
what?! It ain't gonna be INDICATING (calibrating) anywhere near that. CAS
will be waaaay less than 180 knots.
So even for the RV-8 which Van's specs out at 212 mph (184 knots) at solo
weight 75% cruise, CAS won't be anywhere near 180 at 8000'.
The key is "CAS" here. That's what the reg says. If the DAR is gonna push
you on it, follow the reg to the letter!!!
)_( Dan
RV-7 N714D (933 hours)
http://www.rvproject.com
rv7(at)b4.ca Guest
Posted: Thu Jun 08, 2006 8:12 pm Post subject: N-Number font |
On 19:09:59 2006-06-08 "Puckett, Gregory [DENTK]" <Greg.Puckett(at)united.com>
wrote:
| Quote: | Specifically, the way I read it, they want the width of all
If nothing else, having a set of vinyl letters made first, in the same font
that you would have used for painting, would let you see how it looks
before committing to the final layout.
And it may not be first in your mind right now, but having removable
letters may make your plane a little more attractive down the road to a
potential purchaser (if someone wants to re-reg it with different numbers,
or move it to Canada, etc.)
-Rob
pbesing(at)yahoo.com Guest
Posted: Thu Jun 08, 2006 8:16 pm Post subject: N-Number font |
There goes some of those leave it up to the DAR
things...I've seen plenty of RV's with the small
numbers on them...I'm sure they are over 200 MPH quite
often! My -6A had 4" temporary hardware store numbers
on it before it was painted...I'm pretty sure it went
over 200 MPH on many occasions.
Paul Besing
--- Dale Ensing <densing(at)carolina.rr.com> wrote:
this?
a DAR in our area
Dale
browse
Subscriptions page,
FAQ,
Admin.
rv8ch
Posted: Thu Jun 08, 2006 10:03 pm Post subject: N-Number font |
Dan Checkoway wrote:
| Quote: | (iii) Marks at least 3 inches high may be displayed on an aircraft for
which the FAA has issued an experimental certificate under §21.191 (d),
§21.191 (g), or §21.191 (i) of this chapter to operate as an exhibition
aircraft, an amateur-built aircraft, or a light-sport aircraft when the
maximum cruising speed of the aircraft does not exceed 180 knots CAS;
There's also the issue of international flying. Not sure if that
counts for Caribbean, Canada or Mexico. What do you guys who cross
the borders regularly do? Temporary 12" numbers? Anyone had
their wrist slapped for not having the big numbers on their RV?
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
_________________ Mickey Coggins
http://www.rv8.ch/ |
mstewart(at)iss.net Guest
Posted: Fri Jun 09, 2006 2:41 am Post subject: N-Number font |
We have used electrical tape and shoe polish for the 12" requirement returning from other countries.
I have 3" on my S8. My DAR never even mentioned the speed, nor did I bring it up bragging about the speed. You can see my 3" scripted font barely readable from 50' here:
http://www2.eaa690.org:8080/coppermine/displayimage.php?pos=-138
Coming back from the Turks, out electrical tape was flapping in the wind as the hot sun was softening the glue and the tape was fluttering off. Was funny to watch. We switched to shoe polish after that.
Enjoy,
Mike
Posted: Fri Jun 09, 2006 4:59 am Post subject: N-Number font |
Hi All-
A person could have a lot of fun with this one! I asked a pertinent source
about this subject and got the perfect answer. The cruise speed of a plane
has an FAA definition. Unfortunately I don't have either the citation at
my fingertips or the time to look it up right now, but you can go to the
main fed site and do a search for the info and get it right from the horses
mouth. The short version is that V sub D (design diving speed), V sub NE
(never exceed speed), V sub H (max sea level speed), and V sub C (cruise
speed) are all mathematically defined and interrelated, as well as linked
to wing loading at max gross take off weight. V sub C has a range, the
maximum end of which is defined as 0.9 x V sub H. According to Van's, V
sub H is 192 kts for the RV-8. 192 x .9 = 173. Therefore, the max cruise
speed for an RV-8 is 173 kts as defined by the FAA.
Voila!
Crossing an ADIZ is another matter, of course. We plan on 12" markings for
that reason alone.
Dale
Glen Matejcek
aerobubba(at)earthlink.net
Posted: Fri Jun 09, 2006 6:19 am Post subject: N-Number font |
Thanks for the info everyone.
I know everyone wants to hash out the height issue again and I'm sure I can find some DAR to disagree but, I think that issue is pretty clear as written in the regulation. Dan is right, its CAS and at 75% power the RV-8 will see nothing close to 180kts CAS. Glen's analysis should also be some good ammo.
The question I really needed an answer to is:
With respect to FAR 45.29 (c), has anyone ever had an issue if the width does not exactly match?
It's not like I'm using some crazy font, just a plain Swis821 LtCn BT in bold and slightly slanted but, it does not have characters that are exactly 2/3 wide as they are high and the "1" is not exactly 1/6th wide. The number "8"is exactly 2/3rd but the "N" the "G" and "P" are about as wide as they are high.
After looking a Mike Stewarts font, I can't imagine anyone having a problem with mine but before I shoot and clear coat, I wanted to know if anyone had ever heard of an issue with the width and font of the character from their DAR?
Thanks everyone.
Greg
N881GP
(c) Width. Characters must be two-thirds as wide as they are high, except the number "1", which must be one-sixth as wide as it is high, and the letters "M" and "W" which may be as wide as they are high.
(d) Thickness. Characters must be formed by solid lines one-sixth as thick as the character is high.
(e) Spacing. The space between each character may not be less than one-fourth of the character width.
Posted: Fri Jun 09, 2006 6:30 am Post subject: N-Number font |
| Quote: | There's also the issue of international flying. Not sure if that
The requirement isn't relative to border crossing or flying to other
countries. The requirement has to do with whether or not you are crossing
the ADIZ...and also depends on the regs of the countries you're visiting.
When I flew to Canada, for instance, I had just my 3" numbers. Didn't cross
the ADIZ.
When I fly to Mexico, I always use 12" temporary numbers (shoe polish).
| Quote: | From a standpoint of convenience, having 12" numbers would be a good thing.
But I can't bring myself to put 'em on there permanently for reasons that
are probably obvious to many RV pilots on this list.
)_( Dan
RV-7 N714D
Bruce(at)glasair.org Guest
Posted: Fri Jun 09, 2006 6:36 am Post subject: N-Number font |
Call your AB-DAR and ask him.
Bruce
www.glasair.org
Posted: Fri Jun 09, 2006 7:38 am Post subject: N-Number font |
<snip>
problem with mine Greg N881GP
<snip>
Its ALL IN THE DAR!
For better or worse, there are no consistent application of any rules.
After your inspection and your paperwork is done, there is nothing to
stop a ramp check from requiring you to change em. If your not in
compliance, then your not.
And on the Vx Dy stuff I know nothing about, in the end its how YOURS
performs, not the airframe. Mine does not perform to Vans published
numbers... fortunately {smile}
Best
Mike
bertrv6(at)highstream.net Guest
Posted: Sat Jun 10, 2006 5:47 am Post subject: N-Number font |
Quoting Paul Besing <pbesing(at)yahoo.com>:
Paul Besing
Paul: I thought, that the requirement, for 12" was only if you fly
outside of the U.S.?
Bert
> this?
> a DAR in our area
> Dale
> browse
> Subscriptions page,
> FAQ,
> Admin.
jsflyrv(at)verizon.net Guest
Posted: Sat Jun 10, 2006 10:13 am Post subject: N-Number font |
bertrv6(at)highstream.net wrote:
>Paul Besing
Bert
Nope, based on speed and the ADIZ.
Jerry
Posted: Sat Jun 10, 2006 1:07 pm Post subject: N-Number font |
Jerry Springer wrote
| Quote: | >
> Bert
Jerry
And where is MOST of the ADIZ??? Out of the country. Which brings up
the question? Are 12" numbers required to enter the Washington ADIZ?
Linn
do not archive ....... ADIZ off the coast!
Posted: Sat Jun 10, 2006 2:00 pm Post subject: N-Number font |
linn Walters wrote:
>> Bert
> Jerry
Linn
I don't really consider the ADIZ around the west, south and eastern
borders out of the country. Washinton is not an ADIZ it is a restricted
area and you must comply with certain procedures to fly there.
You do have your 2006 FAR/AIM right?
Jerry
Tim(at)MyRV10.com Guest
Posted: Sat Jun 10, 2006 2:59 pm Post subject: N-Number font |
Since when is the area around D.C. "not an ADIZ". Seems that's what
it's been for quite a while now.
Jerry Springer wrote:
>>> Bert
>> Jerry
> up the question? Are 12" numbers required to enter the Washington ADIZ?
> Linn
Jerry
khorton01(at)rogers.com Guest
Posted: Sat Jun 10, 2006 3:07 pm Post subject: N-Number font |
On 10 Jun 2006, at 17:07, linn Walters wrote:
<pitts_pilot(at)bellsouth.net>
>> you fly
>> Bert
> Jerry
You don't fly through an ADIZ to come up to Canada. Come visit us
sometime.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
Terry Watson
Joined: 09 Jan 2006 Posts: 290 Location: Seattle, WA USA
Posted: Sat Jun 10, 2006 4:42 pm Post subject: N-Number font |
Kevin,
Flying TO Canada is easy; it's getting back through U.S. Customs that has
been an aggravation, to say the least, as both Jerry and I have experienced.
But you know that.
Terry
>> you fly
>> Bert
> Jerry
sometime.
Ottawa, Canada
Posted: Sat Jun 10, 2006 5:38 pm Post subject: N-Number font |
I stand corrected, I was just using the 2006 AIM/FAR manual fir
reference and it did not show DC area.
Tim Olson wrote:
>>>> fly
>>>> Bert
>>> Jerry
>> ADIZ?
>> Linn
> restricted area and you must comply with certain procedures to fly
> there.
> Jerry
http://wiki.matronics.com
