Posted: Thu Mar 14, 2013 6:07 am Post subject: ROTAX 912UL/912ULS Frequently Asked Questions |
Hi Kolbers:
This info from the ROAN, ROTAX Owner Assistance Network:
http://www.rotax-owner.com/pdf/ROAN%20FAQs.pdf
Answers some good questions, especially "What speed to operate our 912's?"
_________________ John Hauck
Titus, Alabama |
frank goodnight
Posted: Thu Mar 14, 2013 6:52 am Post subject: ROTAX 912UL/912ULS Frequently Asked Questions |
Very interesting, especialy the Rpm . I have been running my 912uls
at 4800 RPM and taking off at 5000 didn't know 5500 and 5800 was better for the engine . Thanks John.
Frank
Sent: Thu, March 14, 2013 9:07:35 AM
Subject: ROTAX 912UL/912ULS Frequently Asked Questions
style="position:fixed">
Posted: Thu Mar 14, 2013 8:26 am Post subject: ROTAX 912UL/912ULS Frequently Asked Questions |
Frank
| Quote: | | In my opinion, lugging a two or four stroke is not good for them. They are designed to turn high rpm. I have always used 5,000 rpm for normal cruise. If I get in a hurry, I fly 5,200 and 5,400 rpm. Whatever is comfortable for me and the airplane. I flew 5,400 rpm from Alabama to OSH and back in 1994, with my 912UL. That was right after I got home from flying 232 hours on the first Alaska flight. Only difference was fuel burn and a little more cruise speed. john h | 012
Titus, Alabama |
undoctor
Joined: 21 Oct 2008 Posts: 212 Location: Bethelhem, PA
Posted: Thu Mar 14, 2013 12:10 pm Post subject: ROTAX 912UL/912ULS Frequently Asked Questions |
John, will you please re-post the link for the FAQ? I lost it somewhere in my computer.
Dave Kulp
On 3/14/2013 10:52 AM, frank goodnight wrote:
[quote] Very interesting, especialy the Rpm . I have been running my 912uls
Frank
From: John Hauck <jhauck(at)elmore.rr.com> (jhauck(at)elmore.rr.com)
pipercolt
Joined: 08 Jan 2012 Posts: 46 Location: Randolph New York
Posted: Thu Mar 14, 2013 2:59 pm Post subject: Re: ROTAX 912UL/912ULS Frequently Asked Questions |
Hey John
Is there a similar list for other Rotax engines, like the 582?
Posted: Thu Mar 14, 2013 4:16 pm Post subject: ROTAX 912UL/912ULS Frequently Asked Questions |
Dave Kulp
If you lose it again, Google "ROAN ROTAX FAQ".
Titus, Alabama[quote] [b]
Titus, Alabama |
Posted: Thu Mar 14, 2013 4:34 pm Post subject: ROTAX 912UL/912ULS Frequently Asked Questions |
I don't know about the 582. I found this one by accident.
A search of the ROAN site should turn up some results.
Hey John
Titus, Alabama |
Thumper
Posted: Fri Mar 15, 2013 7:30 am Post subject: Re: ROTAX 912UL/912ULS Frequently Asked Questions |
FYI. The RPM number is used for take off. What two different Rotax forum guys said is: the takeoff rpm should not be lower than 5300, which means prop loading should be set to keep the engine higher than 5300 period during takeoff load. They intended that for those guys running clean airplanes not to prop them for their top speed and forget minimum takeoff RPM's. After takeoff you can fly at whatever reduced rpm you want without harm. The Engine was designed to run at cruise of 5500 all day if you want to but it is not a requirement to do so. Once you reduce throttle you reduce load on the internal engine parts so they are not concerned with that. It has been a big confusion and people saying you are supposed to cruise at 5500 minimum but that was refuted by Phil Lockwood and the other man at another 912 forum. So just as long as the takeoff full load RPM = 5300 they are OK. The book says 5500 but they both admitted that 5300 was OK with them. I like that 3800-5000 range myself for cruise, makes a difference in noise and fuel burn change of 1.5GPH. On those days when I'm flying with my Cub friends, Challenger or Trike buddys I smoke them on fuel burn at equal speeds. Not a Kolb though, BUT I will have another one when the right deal comes along. See you at the Homecoming I hope. Dennis, Aeroprakt A20/Kolb like airplane.
_________________ Dennis Long
Oakland TN
2000 Aeroprakt A20 Vista Cruiser, 2016 A22LS Aeroprakt
Previously Kolb Mark IIIC, 94 Firestar, 84 Ultrastar.
1200+hours since 1/1/2009 |
Posted: Fri Mar 15, 2013 8:11 am Post subject: ROTAX 912UL/912ULS Frequently Asked Questions |
I like that 3800-5000 r!
1.
Dennis Long
Oakland TN
600+hours since 1/1/2009
Kolbers:
Been flying 912's on my MKIII for the past 20 years and more than 3,000.0
flight hours.
Seems I have a difficult time maintaining a minimum engine oil temp of 190F
if I don't fly at least 5,000 rpm. Engine temps drop rapidly below 5,000
rpm. Besides, with my airplane, in order to cruise at least 80 mph, I need
5,000.
Flying with a ground adjustable prop it is necessary for me to pitch for
best take off and cruise. To do this, I pitch for 5,500 rpm, wide open
throttle, straight and level flight. With this pitch setting I get aprx'ly
5,400 rpm during takeoff and climb.
If I flew at sea level all the time I might be able to pull a tiny bit more
pitch. However, on my flights West, it is necessary to climb to
12,000-13,000 feet ASL, and my flight environment and field elevations are
generally 4,000 to 8,000 feet. If I can pull 5,400 rpm climbing at
home/near sea level, I'm down to 5,100 to 5,200 rpm out West. So what I do
is set my pitch for about 5,600 rpm straight and level, wide open throttle
at home. Then when I get out West I still have respectable performance.
I am a firm believer in freeing up the engines and let them turn as they
were designed. Overpitching, to me, has the same results of lugging down a
car or truck when they are equipped with a 5 or 6 speed transmission. It
hammers them to death.
Titus, Alabama |
Thumper
Posted: Fri Mar 15, 2013 8:35 am Post subject: Re: ROTAX 912UL/912ULS Frequently Asked Questions |
Absolutely John. No lugging occurs if the takeoff RPM stays above 5300 per Phil. In flight we can cruise where we want with no harm as long as the prop is not the limiting factor, that would be lugging. NOW, I see guys with in-flight adjustable props doing just that by loading up the engine at reduced RPM, that is lugging the engine, but it is a habit they learned on high performance GA aircraft and can't seem to explain it to them. Yours is set up like mine. If I want to fly slow no harm because the engine isn't lugging. Same thing on the two strokes although on those if you reduce throttle a lot carbon build up will occurr quickly. See you at Sun-N-Fun maybe, weather permitting.
Oakland TN
