n223rv(at)wolflakeairport Guest
robin(at)PaintTheWeb.com Guest
Posted: Tue Apr 02, 2013 12:22 pm Post subject: Oil level |
Michael,
I usually put a bit in the oil filter then 7 quarts in the case. I then add another quart 20+ hours in. On my old cowl the breather tube was undersized at 3/4" which I now realize was a problem. With 7 Quarts I didn't have any blow by on the belly but if I put 8 quarts in it coated the belly. When we replaced the cowl we also replaced the 3/4" breather with a 1" breather tube. At the same time they did an oil change and put in 11 Quarts. Holly S*** 11 Quarts. I know I would be degreasing for the next 10 flight hours. That didn't happen. My belly is bone dry after 2 - 3+ hour flights and another 10 - 1 hour flights. Big surprise to me. I will still probably stay with 8 quarts for me on a go forward basis. YMMV.
Robin
Posted: Tue Apr 02, 2013 12:48 pm Post subject: Oil level |
I like it at 9, top it off when it gets to 8. I put a couple extra marks on the dipstick at 7 and 8.
On Tuesday, April 2, 2013, Michael Kraus wrote:
| Quote: | --> RV10-List message posted by: Michael Kraus <[url=javascript:;]n223rv(at)wolflakeairport.net[/url]>
How many quarts of oil do you all typically run in your RV-10? Anything over 10 quarts for me typically blows out.
-Mike Kraus
RV-4 sold
RV-10 flying
KitFox SS7 Radial building
" target="_blank">http://www.matronics.com/Navigator?RV10-List
MS -
e -
-Matt Dralle, List Admin.
Dave Saylor
831-750-0284 CL
rv10flyer(at)live.com Guest
Posted: Tue Apr 02, 2013 12:58 pm Post subject: Oil level |
I discovered that anything above 7qts would "disappear". I have a can that
holds the blowby so I can see how much oil is blown and it sure isn't much.
I have been running mine at 6.5-6.0qt before adding another qt.
The advice my engine builder gave me was let the oil go until it stops. Some
io-540 can run at 6, some at 8 or 9qts. In other words the oil stopped going
down at around 6qts. I can go about 5 hours or so before I see any drop, but
if I take it to 8qts the oil goes down within 2-3 hours to 7qts, than slowly
to 6 where it seems to hold without loss..
rene(at)felker.com Guest
Posted: Tue Apr 02, 2013 1:49 pm Post subject: Oil level |
I have been starting at 9 and letting it go to 8 where is stabilizes.
Anything above 9 and in a couple of hours it will be at 9.... YMMV
Rene' Felker
N423CF
801-721-6080
Posted: Tue Apr 02, 2013 2:26 pm Post subject: Oil level |
For the first 200+ hours, I was putting in 10 quarts
At 260 hours, I put in 7 which registers at 6.
Why? I've been attempting to get my oil temperature up to at least 150F.
Bill "changing it again as we speak" Watson
On 4/2/2013 3:35 PM, Michael Kraus wrote:
-Mike Kraus
RV-4 sold
RV-10 flying
Gordon Anderson
Posted: Tue Apr 02, 2013 9:38 pm Post subject: Oil level |
Robin,
Do you have an oil separator in the breather line, with the new 1" line or previously with the 3/4"?
Gordon
On Apr 2, 2013, at 10:22 PM, Robin Marks wrote:
Michael,
Robin
Posted: Tue Apr 02, 2013 9:59 pm Post subject: Oil level |
I had the Andair Air/Oil with the 3/4" line in the prior cowl set up. That is probably why we used 3/4". The new set up has no Air/Oil unit.
Robin
bill.peyton
Joined: 19 Sep 2010 Posts: 198 Location: St. Louis, MO
Posted: Wed Apr 03, 2013 4:27 am Post subject: Re: Oil level |
I have tried numerous levels, but come to the conclusion that anything over 9 is just a waste of money. The biggest changes I observed with consumption was going from the aeroshell 15/50 to Phillips XC 20/50. I used to burn a quart every 8 hours with the aero, now I have gone 10 hours with the Phillips product and I am only down 1/4qt after 10 hours. My engine has 110 hrs. I intend to not add oil until the 7 qt level.
_________________ Bill
WA0SYV
Aviation Partners, LLC |
arplnplt(at)gmail.com Guest
Posted: Wed Apr 03, 2013 4:37 am Post subject: Oil level |
9.
Dave Leikam
On Apr 2, 2013, at 2:35 PM, Michael Kraus wrote:
-Mike Kraus
RV-4 sold
RV-10 flying
partner14
Posted: Wed Apr 03, 2013 5:12 am Post subject: Oil level |
I never put in more that 7.5, and add when it gets to 6.5.... in the winter run closer to the 6.5. summer closer to the 7.5.
Don Mc
--- On Wed, 4/3/13, David Leikam <arplnplt(at)gmail.com> wrote:
Subject: Re: Oil level
Date: Wednesday, April 3, 2013, 7:19 AM
--> RV10-List message posted by: David Leikam <[url=/mc/compose?to=arplnplt(at)gmail.com]arplnplt(at)gmail.com[/url]>
9.
Dave Leikam
[quote] --> RV10-List message posted by: Michael Kraus <[url=/mc/compose?to=n223rv(at)wolflakeairport.net]n223rv(at)wolflakeairport.net[/url]>
-Mike Kraus
RV-4 sold
RV-10 flying
>sp; --> http========================
40636 |
