		waltmurphy
				 Posted: Wed Apr 03, 2013 5:47 am    Post subject: MGL digital tach on an M-14 |
				Does anyone have any experience in installing an MGL digital
 tach/manifold press gauge in an aircraft with an M-14?
 The installer added resistors and trimmed the instrument but it's still
 not correct...close but maybe 150 RPM off compared to a strobe tach on
 the prop.
 Any info on the correct resistor or ?? Would be most helpful
 thanks,
 Walt Murphy
 Reno
		rmhou(at)yahoo.com Guest
				 Posted: Wed Apr 03, 2013 7:38 am    Post subject: MGL digital tach on an M-14 |
				No experience with MGL, but my GRT EIS connected to mag switch on a Huosai works great. Strobe each on your prop measures prop rpm. Digital tach connected to mags measures engine rpm. You need to account for gear reduction to verify both measurements.
        From:                                                          Walt Murphy <waltmurphy(at)charter.net>;
                                                               To:                                                           <yak-list(at)matronics.com>;
                                                               Subject:                                                          MGL digital tach on an M-14
                                                               Sent:                                                          Wed, Apr 3, 2013 1:44:39 PM
		gill.g(at)gpimail.com Guest
				 Posted: Wed Apr 03, 2013 9:18 am    Post subject: MGL digital tach on an M-14 |
				I use their tach  and it is accurate.  It could be that it needs to be
 programmed for the correct pulse count.  The guys at MGL are always very
 helpful.
 Gill
		wlannon(at)shaw.ca Guest
				 Posted: Wed Apr 03, 2013 7:05 pm    Post subject: MGL digital tach on an M-14 |
				Walt;
 As Robin has noted you need to take the gear ratio into account when
 comparing engine to prop RPM.
 For the M14P the gear ratio is 0.658.  For the Huosai it is 0.787.    At
 2900 engine RPM the M14 prop is turning at 1908 RPM.  At 2350 engine RPM the
 Huosai prop is turning at 1850 RPM.
 Hope that helps.
 Walt
		keithmckinley
				 Posted: Thu Apr 04, 2013 5:11 am    Post subject: Re: MGL digital tach on an M-14 |
				I have an MGL tach on a Housai. The correct pulse setting is important and there are settings to fine tune it. Quite honestly I never use it. (hobbs use only) I use the analog gauge and can read that better. Does MGL make one that looks at both Mags now? if not, don't bother with it.
		N13472(at)aol.com Guest
				 Posted: Thu Apr 04, 2013 9:36 am    Post subject: MGL digital tach on an M-14 |
				The  resistor is for setting the signal level into the tach so as to not over or
 under drive the pulse detector circuit. If the tach is reading Rpm at all the resistor
 should have no effect on the accuracy of the reading.
 Tom Elliott
 CJ-6A NX63727
 777 Quartz Ave
 PMB 7004
 Sandy Valley NV
 89019
 Cell 541-297-5497
 N13472(at)AOL.COM
