planecrazzzy Guest
Posted: Sat Jan 14, 2006 9:39 am Post subject: Transponder "Cert" question |
Hey Guys,
I just had a "FLASH" ( not a HOT one )
My Transponder still hasn't been certified....I have to steer clear until it is.....
I have my "Repairmans Cert" for my bird....
Here's the question ( if you don't know.....Why answer ? )
Could I fly in an area where the transponder and encoding Alt is not required.....ask a TOWER what "Alt"info they are getting on their screen to cross check if that's my Alt , and ask them if they are recieving my transponder signal OK.....and "sign off" the transponder MYSELF....
Now, if it's not correct, I'd probly have to get it Certified by somebody who knew what they were doing....
But, after two years, with this same proceedure could "I" sign off the RE: Cert
Gotta Fly...
Mike in MN
PS..... John, Your still my Hero !
Firestar I&II Forum
http://groups.yahoo.com/group/Kolb_Firestar/
My Web Site:
http://www.geocities.com/planecrazzzy/Planecrazzzy.html
Sometimes you just have to take the leap and build your wings on the way down...
Got holiday prints? See all the ways to get quality prints in your hands ASAP.
JetPilot
planecrazzzy Guest
Posted: Sat Jan 14, 2006 11:40 am Post subject: Re: Transponder |
Hi,
I bought it thru Aircraft Spruce.....It's the Narco 155 Transponder w/AR850 encoding Alt... Total package was around $1,500 bucks....
I'm under Class B, and it's getting BIGGER ( KMSP )
The page of my website with the system is:
http://www.geocities.com/planecrazzzy/LSXXIX.html
There was a little more to put it in than I thought.....BUT, it wasn't hard
Gotta Fly...
Mike in MN / N381PM
Richard Pike
Posted: Sat Jan 14, 2006 11:43 am Post subject: Transponder "Cert" question |
If you are in flight and your altimeter has an error, and your Mode C
has an error, asking ATC how things are doing really doesn't tell you
much, because you have no known constant to work from. You need to work
from a known constant.
Try this: land at an airport with an approach control, and go to a point
on the runway or taxiway where the altitude MSL is known exactly, (it's
on the approach plate) then set your altimeter to the barometric
pressure on the current ATIS, and then ask ATC what your Mode C readout
is. (ground control can read it off the tower BRITE scope) Now you know
how accurate your Mode C is, and also know how accurate your altimeter
is. If either one is off, you need to go to an avionics shop.
Assuming they are good, climb to 5,000' (check current ATIS for the
barometric pressure) and ask ATC what your Mode C says, and it agrees -
good. Try it again at 10,000' and ask them again, and if it still
agrees, you are probably a safe user of the ATC Mode C system.
Probably not a legal way of pleasing the paper-pushers (should your log
books be examined,) but since you brought it up...
Richard Pike
MKIII N420P (420ldPoops)
FAA ATC (retired)
Mike Pierzina wrote:
Hey Guys,
Gotta Fly...
Mike in MN
Firestar I&II Forum
My Web Site:
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Posted: Sat Jan 14, 2006 12:26 pm Post subject: Transponder "Cert" question |
Hey Guys,
Gotta Fly...
Mike in MN
I'm afraid that's one of the areas where being an experimental doesn't
get you a pass on the regs. Logic is probably that if it's not done
right, you could tangle with another a/c while under ATC's control.
Try the EAA for chapter & verse.
Charlie
planecrazzzy Guest
Posted: Sat Jan 14, 2006 12:28 pm Post subject: Re: Transponder |
Hi Richard,
As far as knowing my Altitude, My GPS will give me that...
But you make a good point to check it's "High & Low"...Thanks
Gotta Fly...
Mike in MN
PS I like the way a message is posted "Right away" , before it would take about 45 min ....
[/quote]If you are in flight and your altimeter has an error, and your Mode C
Last edited by planecrazzzy on Sat Jan 14, 2006 12:33 pm; edited 2 times in total |
edchmiel(at)mindspring.co Guest
Posted: Sat Jan 14, 2006 1:33 pm Post subject: Transponder "Cert" question |
Hi Mike,
My avionics guy says you have to be certified to make a log entry on
the pressure instruments, avionics, etc. Not just any A&P can do it, nor
one with a repairman's certificate. I'd leave the log blank and claim
innocence, rather than make a questionable entry.
Ed in JXN
MkII/503
Do not archive.
a58r(at)verizon.net Guest
Posted: Sat Jan 14, 2006 1:45 pm Post subject: Transponder "Cert" question |
It's now 10 years since I've had a tpdr Certified, so stds may have
changed. Basically the shop places a box with one side open, and
containing an ant. around the ship's beacon ant. The box ant. is
connected to a test set via a coax. Tests will cover both Mode A
(identication) and Mode C (altitude). You won't have to worry about
Mode S...yet. With the tpdr On and set to a given code, the test set
transmits an interrogation code train at a known pwr level. The
ship's tpdr will detect this interrogation and reply with its code
setting. The test set can determine the tpdr's rec. sensitivity,
verify its code detection, reply pulse train, and ck its pwr output
and frequency. The altitude encoder is ckd by connecting a calibrated
pressure source to the coder's input. The set's press. input is
varied, and the tpdr's alt. reply is ckd for accuracy...+/- 100'. An
additional test covers the IDENT function. Tech makes dated entry in
airframe log book. Altho it takes less than hr., charges (use to)
run abt $150...EVERY TWO YEARS!
I worked on design of first test set in '50...all vacuum tubes...AN-
UPM-4.
In case anyone is interested (still awake) the Mode C alt replies are
folded biquinary for 100's, and Grey binary for 1000's.
Somewhere I have a history of IFF/Beacons I wrote almost 50 yrs ago,
updated, including solving the Mystery of the Ghost Idents.
Bob N.
Posted: Sat Jan 14, 2006 3:53 pm Post subject: Re: Transponder |
[quote="Mike Pierzina"]Hi Richard,
Mike: Might not be a good idea to depend on GPS altitude read out. From my limited experience with GPS altitude, it ain't so accurate. Everything else works good though.
_________________ John Hauck
Titus, Alabama |
planecrazzzy Guest
Posted: Sat Jan 14, 2006 4:27 pm Post subject: Re: Transponder |
Thanks Guys,
After all the replies, I think there's no way of getting around the "CERT" other than a Certified inspector......( $125 - 250 is what I've seen the price range )
I still gotta learn how to do "THE QUOTE" thingy.....I butchered it pretty bad.....???
Gotta Fly...
Mike in MN
Posted: Sat Jan 14, 2006 4:47 pm Post subject: Re: Transponder |
| Quote: | I still gotta learn how to do "THE QUOTE" thingy.....I butchered it pretty bad.....???
Gotta Fly...
Mike in MN
Mike: Me too. Practicing now to see if I have gotten it right this time.
Titus, Alabama |
Posted: Sat Jan 14, 2006 4:51 pm Post subject: Re: Transponder |
| Quote: | | Mike: Me too. Practicing now to see if I have gotten it right this time. |
Mike: Highlight and copy what you want to quote.
Then click on the "quote" box above the msg box.
Paste the reference.
Click on the "quote" box again.
Drop down a line or two and start your reply.
Titus, Alabama |
planecrazzzy Guest
Posted: Sat Jan 14, 2006 5:32 pm Post subject: Re: Transponder |
I keep getting it backwards....lets try this...
( my message was in Blue and the quote wasn't )
After a couple of "Previews" , I'm getting it.... Nice feature...
| Quote: | Highlight and copy what you want to quote.
