g-fizy
Posted: Sun Apr 07, 2013 1:13 am Post subject: radio noise |
My radio is not very clear on receive ,i was thinking of replacing it,but i was in the hanger yesterday to charge the battery .When i switched everything on the radio was crystal clear ,,so it must be the rotax 80hp causing the problem .
has any one got a few ideas where i should look ?
many thanks jim davis
clivesutton
Posted: Sun Apr 07, 2013 2:03 am Post subject: Re: radio noise |
Jim,
My experience is that the radio and the tacho are both sensitive to interference if they run alongside the cables to the mag anywhere. I had just this problem a few months ago after 'tidying up' the wiring behind my panel.
If they do have to run close - like through the bulkhead, then I suggest it is better for them to run at 90 degrees to the mag cables to avoid/reduce inducing current in them, or that one or the other of them is double-screened and the screen earthed.
That said, its also rather easy [for us amateurs?] to get poor BNC or other connector terminations in the screened radio cables themselves as the connections are a bit tricky to make without specialist and rather costly tools.
I hope that helps somehow
Clive Sutton
G-TAGR
g-fizy
Posted: Sun Apr 07, 2013 8:40 am Post subject: Re: radio noise |
thanks Clive ,I never thought of connections and wire position i no their are some Redundant cables behind my panel, I mite have a spring clean
regards jim
Posted: Sun Apr 07, 2013 10:02 am Post subject: radio noise |
P.S. I notice that the sea temp between Dover & Calais is
just 5.4 degrees today, some two and a half degrees colder
than the minimum I recorded throughout the winter before I
was planning to fly to Australia. Shows that March really
has been cold, plus I guess that persistent NE winds blow
the colder N Sea water into the Channel. And shows that X
channel trips need serious preparation at this time of
year!
David Joyce
On Sun, 7 Apr 2013 09:40:32 -0700
regards jim
owner g-fizy
http://forums.matronics.com/viewtopic.php?p=398055#398055
Un/Subscription,
Forums!
Admin.
