bipolar
Posted: Thu Apr 25, 2013 1:04 pm Post subject: Air system lubrication CJ |
Good day all
Would anyone be able to confirm for me the ratio of glycerin to alcohol and the best place to introduce said mix into the system?
Last couple of little jobs and since spring is sort of here would love to get flying her
Bipolar
byronmfox(at)gmail.com Guest
Posted: Thu Apr 25, 2013 6:42 pm Post subject: Air system lubrication CJ |
Doug Sapp recommends castor oil. I've been using it with great success.
Blitz Fox
415-307-2405
On Apr 25, 2013, at 2:04 PM, "bipolar" <bushrat(at)telus.net> wrote:
Good day all
Bipolar
http://forums.matronics.com/viewtopic.php?p=399387#399387
Posted: Thu Apr 25, 2013 8:13 pm Post subject: Air system lubrication CJ |
You have a regular system, huh?
Doc
Sent from my iPad
On Apr 25, 2013, at 9:40 PM, Byron Fox <byronmfox(at)gmail.com> wrote:
Blitz Fox
415-307-2405
> Good day all
> Bipolar
Harv
bipolar
Posted: Fri Apr 26, 2013 5:48 am Post subject: Re: Air system lubrication CJ |
Basically a stock system with the SS mods added
Thanks guys
Bipolar
jetjockey
Joined: 12 Dec 2006 Posts: 31 Location: Granbury, Texas
Posted: Fri Apr 26, 2013 6:29 am Post subject: Re: Air system lubrication CJ |
Article 105 from the CJ6 Maintenance Manual clearly states: "Replenish 5-10 gr. of castor oil or No. 8 aviation lubricating oil into each retraction cylinder THROUGH THE NIPPLES OF THE CYLINDER RETRACTION AND EXTENSION PIPES AND 3-5 grams of castor oil or No. 8 aviation lubricating oil into each of the uplock hook cylinders THROUGH ITS NIPPLE."
Adding lubricant at a point right after the compressor will have little or no effect on the landing gear and uplock release actuators and will actually have a VERY NEGATIVE effect on your pneumatic system as it will unnecessarily contaminate your system filter by saturating the felt filters with lubricant and coating the desiccant with oil, rendering it ineffective.
Harv
Posted: Fri Apr 26, 2013 10:56 am Post subject: Re: Air system lubrication CJ |
Guys
Sorry misunderstood what your trying to lubricate, so be careful what you inject and where you inject it!
Been having issues with my firewall check valves (worn seals and rusty springs).
