t41pilot
Joined: 05 Sep 2011 Posts: 38 Location: Howard City, Michigan
Posted: Tue Apr 30, 2013 9:03 am Post subject: Washing |
It's finally warm enough in Michigan to think about flying. Hooked everything back up that was disconnected for winterization and prepared to do battle with the startup. Much to my surprise it started right up. Took just a couple of minutes to blow the fogging oil out of it. The Weather is not right for flying yet but I'd like to get the dirt off with a wash. I just finished it last fall so it hasn't been washed at all yet so I'm looking for advice on proper techniques and products to use since it is a fabric covered Aircraft. I read somewhere that it was not ok to use the standard bucket of soap and rinse with the hose since it would allow water to get into places where corrosion could get started. Also I haven't put in drain holes in all the rib bays yet per plan. It seems the plane would be littered with holes especially the ailerons. Are that many holes really necessary? I have some Mr Clean car wash solution that you are supposed to put in a sprayer and just spray it on and it just sheets right off and dries clear with no residue just like their window wash stuff. I thought about maybe just using a capful in a bucket to make a weak solution and washing with a soft sponge or cloth and rinsing lightly with the hose. But that flies in the face of one post I read somewhere. Any thoughts on this?
_________________ Gregg Kaat
2011 Firefly |
rowedenny
Posted: Tue Apr 30, 2013 10:18 am Post subject: Washing |
Anything from dish soap to car wash soap in a bucket of water and sponge works for me, keep the water flowing and go easy on the lexan. When I'm done and patted dry, I hit the lexan with Plexus and a microfiber towel.
Skid Rowe
On Apr 30, 2013, at 1:03 PM, "t41pilot" <t41pilot(at)frontier.com> wrote:
It's finally warm enough in Michigan to think about flying. Hooked everything back up that was disconnected for winterization and prepared to do battle with the startup. Much to my surprise it started right up. Took just a couple of minutes to blow the fogging oil out of it. The Weather is not right for flying yet but I'd like to get the dirt off with a wash. I just finished it last fall so it hasn't been washed at all yet so I'm looking for advice on proper techniques and products to use since it is a fabric covered Aircraft. I read somewhere that it was not ok to use the standard bucket of soap and rinse with the hose since it would allow water to get into places where corrosion could get started. Also I haven't put in drain holes in all the rib bays yet per plan. It seems the plane would be littered with holes especially the ailerons. Are that many holes really necessary? I have some Mr Clean car wash solution that you are supposed to put in a sprayer and just spray i!
Gregg Kaat
2011 Firefly
http://forums.matronics.com/viewtopic.php?p=399679#399679
yellowbird1
Posted: Tue Apr 30, 2013 3:12 pm Post subject: Washing |
I use one of these on my car and don't have to dry it off nor worry about any water spots even with the very hard water we have here in New Mexico as the final rise water is filtered. The soap is designed for use with this system.
http://www.amazon.com/Mr-Clean-AutoDry-System-Starter/dp/B0006M56CE
Brad
On Apr 30, 2013, at 12:17, Dennis Rowe <rowedenny(at)windstream.net (rowedenny(at)windstream.net)> wrote:
[quote]--> Kolb-List message posted by: Dennis Rowe <rowedenny(at)windstream.net (rowedenny(at)windstream.net)>
Skid Rowe
On Apr 30, 2013, at 1:03 PM, "t41pilot" <t41pilot(at)frontier.com (t41pilot(at)frontier.com)> wrote:
| Quote: | --> Kolb-List message posted by: "t41pilot" <t41pilot(at)frontier.com (t41pilot(at)frontier.com)>
It's finally warm enough in Michigan to think about flying. Hooked everything back up that was disconnected for winterization and prepared to do battle with the startup. Much to my surprise it started right up. Took just a couple of minutes to blow the fogging oil out of it. The Weather is not right for flying yet but I'd like to get the dirt off with a wash. I just finished it last fall so it hasn't been washed at all yet so I'm looking for advice on proper techniques and products to use since it is a fabric covered Aircraft. I read somewhere that it was not ok to use the standard bucket of soap and rinse with the hose since it would allow water to get into places where corrosion could get started. Also I haven't put in drain holes in all the rib bays yet per plan. It seems the plane would be littered with holes especially the ailerons. Are that many holes really necessary? I have some Mr Clean car wash solution that you are supposed to put in a sprayer and just spray!
| i!
| Quote: | t on and it just sheets right off and dries clear with no residue just like their window wash stuff. I thought about maybe just using a capful in a bucket to make a weak solution and washing with a soft sponge or cloth and rinsing lightly with the hose. But that flies in the face of one post I read somewhere. Any thoughts on this?
Gregg Kaat
2011 Firefly
http://www.matronics.com/Navigator?K==============================================================================bsp; - List Contribution Web Site -p; -Matt Dralle, List Admin.
_________________ Brad Nation,
Albuquerque, NM
MK3 Xtra |
Posted: Wed May 01, 2013 4:47 am Post subject: Washing |
At 10:03 AM 4/30/2013 -0700, you wrote:
thoughts on this?
Gregg,
I was washing with a water bucket, soap and a rag and drying with lots of old
cloth bath towels. No fun. Then a I asked a hangar mate how he kept his
plane looking so good. He used a spray bottle, water and paper towels. I
mist the desired area and then wipe it down with a paper towel. The water
and the dust stay in the towel. Then I spray the same area again and wipe
it the second time with a clean towel to remove the last bit of dust and
this towel gets used for the next new dusty area to be sprayed.
Using this technique I can wash the upper horizontal surfaces and nose cone
with less that a quart of water and two dozen square paper towels.
Jack B. Hart FF004
Winchester, IN
Posted: Wed May 01, 2013 5:16 am Post subject: Washing |
old cloth bath towels. No fun. Then a I asked a hangar mate how he kept his
Jack B. Hart
Folks:
A quart of water and a dozen paper towels? Now that is frugal.
mkIII - 3218.8 hours
912ULS - 650.3 hours
_________________ John Hauck
Titus, Alabama |
Posted: Wed May 01, 2013 6:49 am Post subject: Washing |
John,
I do not want to leave a false impression.
Jack B. Hart FF004
Winchester, IN
Posted: Wed May 01, 2013 6:57 am Post subject: Washing |
Jack B. Hart FF004
I'm sure it can be done.
Back in the early 1960's, those German nationals that could afford a little
VW, Fiat 500, BMW 500, etc., could wash them with a small bucket of water.
Don't remember seeing folks lucky enough to have a water hose.
I used to carry a quart squirt bottle of Windex and a couple bath towels to
clean the bugs off my airplanes when I got to flyins. Now I looks for small
rain showers to knock off the bugs.
Titus, Alabama |
t41pilot
Posted: Thu May 02, 2013 6:49 am Post subject: Re: Washing |
I have a lot of Black in my paint scheme and I was concerned about any products that might leave a residue and show up against the Black. Also It is my understanding that Polytone paint is not that sturdy and any strong soaps might dull it. I ended up washing with a mild solution of the Mr Clean stuff I had and then used a chamois after a rinse. A lot of elbow grease as Jack had suggested but it turned out good. A spray bottle to take care of bugs. Hopefully I'll only have to do that a couple times a year and a spray bottle in between. I didn't see any comments about drain holes in the rib bays. Do all you guys out there have those in place on your aircraft?
2011 Firefly |
Posted: Thu May 02, 2013 7:03 am Post subject: Washing |
Gregg Kaat
Gregg K/Kolbers:
I use Blue Corral or Turtle Wax Car Wash with lots of water and a 5 gal
bucket. A long handle RV brush and a hand wash mitt get the job done.
Commercial car wash helps prevent streaking.
I have drain holes in everything, at their low point, when the MKIII is
sitting in its normal 3 point position .
My airplane is over 21 years old. No problems with corrosion.
I also use tube seal in 4130 tubing when I build my airplanes.
Titus, Alabama |
