chuck960
Posted: Sun May 05, 2013 7:29 pm Post subject: Sensenich prop |
Does anyone have experience with the Sensenich ground adjustable carbon prop on the 3300A engine? It looks like a beauty and I need to dial up the rpm's a bit to get within the Jab specs. I posted a while ago about static rpm's being 2500 at most. I have to push it to see 3000 in flight. I've been cruising the neighborhood at 4gpm at 2400 rpm. This is with the sensenich 64X47.
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
zeprep251(at)aol.com Guest
Posted: Mon May 06, 2013 11:11 am Post subject: Sensenich prop |
Chuck,
Try (vlingerjr(at)aol.com).Thats what he is running on his 601.
G.Aman
libra(at)myfrontiermail.c Guest
Posted: Mon May 06, 2013 11:48 am Post subject: Sensenich prop |
I have the Sensenich white ground adj prop on my Rans S-7S with a 3300 Jab. Cruises at 105 MPH and climbs at 1000 feet per minute. Works great!!
Joe in Michigan
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of Gary Aman
Sent: Monday, May 06, 2013 3:11 PM
To: jabiruengine-list(at)matronics.com
Subject: Re: Sensenich prop
Chuck,
Try (vlingerjr(at)aol.com).Thats ([email]vlingerjr(at)aol.com).Thats[/email]) what he is running on his 601.
G.Aman
barnett6088(at)msn.com Guest
Posted: Mon May 06, 2013 7:26 pm Post subject: Sensenich prop |
Chuck
I have one on my Lightning SN 133 It works well. I have mine set to 2650 RPM on takeoff and that gives me more than adequate power. Full throttle it turns 3150. If you look at the Jab 3300 power curves you do not get a great deal of power increase after about 3100 RPM. The only quirk in its operation is at low idle RPM where, due to its low rotational mass you can feel the individual power pulses as slightly rough running. At cruise RPM it is as smooth as a turbine. Gary Barnett
| Quote: | Subject: Sensenich prop
Date: Sun, 5 May 2013 20:29:25 -0700
--> JabiruEngine-List message posted by: "chuck960" <chuckde(at)roadrunner.com>
http://forums.matronics.com/viewtopic.php?p=400025#400025
geather
Joined: 06 Feb 2008 Posts: 23 Location: Mt Hutton Australia
Posted: Mon May 06, 2013 7:45 pm Post subject: Sensenich prop |
Chuck,I also have a Senenich ground adjustable on a Lightning (Kit 127) with Jabiru 3300 and have made several adjustments over the last few weeks.
Best compromise I could get was 2700 on take off, 2850 on climb at 85 Knts, 3150 WOT. This gave 110 Knt (IAS) cruise at 2850.
Each adjustment mark is 4 degrees (or 12 inches geometric pitch). Adjustments of 1/2 degree were probably too much, needed to use 1/4 degree to tweak it just right. A digit protractor helps!!
Sounds like you need to fine it up a fraction
Geoff
On 07/05/2013, at 1:26 PM, GARY BARNETT wrote:
| Quote: | Chuck
href="http://www.matronics.com/Navigator?JabiruEngine-List">http://www.matronics.com/Navigator?JabiruEngine-List
_________________ ge |
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Tue May 07, 2013 8:07 am Post subject: Re: Sensenich prop |
Chuck,
Have you seen the caution in both the 2200 and 3300 manuals: "Do not cruise or climb in the range 2100rpm – 2400rpm?" I believe Pete at Jabiru USA said it has to do with cylinder glazing.
Dave
_________________ David Gallagher
Cincinnati, OH area |
papa11(at)centurylink.net Guest
Posted: Tue May 07, 2013 8:14 am Post subject: Sensenich prop |
On 5/7/2013 12:07 PM, DaveG601XL wrote:
Chuck,
Dave
David Gallagher
Zodiac 601 XL-B: flying, 250+ hours now
Next project under construction: Finish my father's Aircamper
http://forums.matronics.com/viewtopic.php?p=400112#400112
Has anyone used the senenich ground adj. prop on a pulsar111 with the 3300 engine? Emil
nick(at)flylightning.net Guest
Posted: Tue May 07, 2013 9:12 am Post subject: Sensenich prop |
The caution about that range has to do with the Old carb needle. If you have an engine say newer than 2004 or so you probably have the jabiru needle not the one from Bing.
The bing needle has a straight taper and casue the engine to have an extreme lean peak in that RPM range.
Of course say operating for long hours in those ranges before the engine is broke in could cause the same problem, but this is due to the rings not seating.
Nick Otterback
Arion Aircraft LLC
R&D Technical Support
931-680-1781
