Rear Trailing Edge Lift Pin Socket Mounting
tonyrenshaw268(at)gmail.c
PostPosted: Sat Jun 01, 2013 12:17 am    Post subject: Rear Trailing Edge Lift Pin Socket Mounting Reply with quote
I would like to request advice regarding methods of shaping the ply inserts for the rear Trailing Edge Lift Pin Sockets if anyone has digressed from the manual, either by material/medium or method. Thanks.
Tony Renshaw
Sydney Aussie
Richard Wheelwright
PostPosted: Sat Jun 01, 2013 12:55 am    Post subject: Rear Trailing Edge Lift Pin Socket Mounting Reply with quote
Tony,
Depending on the thickness you need. I used waste from the tri-gear leg sockets ribs. I cut a 2 1/2 inch circle with a hole saw, then it was cut down through its edge at the angel needed to contour the side of the fuselage. Worked a treat.
Richard Wheelwright
Sent: Saturday, 1 June 2013, 9:17
Subject: Rear Trailing Edge Lift Pin Socket Mounting
--> Europa-List message posted by: Tony Renshaw <tonyrenshaw268(at)gmail.com (tonyrenshaw268(at)gmail.com)>
Tony Renshaw
Sydney st" target="_blank">http://www.matronics.com/Navigator?Europa-Listhttp://forums.matronbsp; nbsp; -Matt com/contribution" target="_blank">http://www.matronics.com/contribution</=============
Richard Wheelwright
G-IRPW
First Flight 24th July 2013
richard collings
PostPosted: Sat Jun 01, 2013 3:27 am    Post subject: Rear Trailing Edge Lift Pin Socket Mounting Reply with quote
I did the same as Richard W , I drew a circle on a piece of the 12mm plywood the same dia as the bracket tried it in place with the wings in position then once I had the thickness correct blended out from the bracket circle to the edge this made the outside dia about 3 1/2 inches . Then glue and glass as per manual. Good luck Richard C
From: Richard Wheelwright (rpwheelwright(at)yahoo.co.uk)
Sent: Saturday, June 1, 2013 9:55 AM
Subject: Re: Rear Trailing Edge Lift Pin Socket Mounting
Tony,
Richard Wheelwright
Tony Renshaw
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
rparigoris
PostPosted: Sat Jun 01, 2013 4:41 am    Post subject: Rear Trailing Edge Lift Pin Socket Mounting Reply with quote
Hi Tony
"anyone has digressed from the manual, either by material/medium or method."
Here's how I did it:
http://www.europaowners.org/main.php?g2_itemId=31838
Ron Parigoris
