skyguynca
Posted: Sat Jun 10, 2006 6:29 pm Post subject: CH601HD/HDS Main Gear |
I have seen a few pictures of the spring type gear on a HDS. Does anyone know how the ribs and internal structure of the center wing section was modified to accept the stress and support the spring gear mounts? I am really interested in doing it to mine but would like to know what all is required.
David Mikesell
23597 N. Hwy 99
Acampo, CA 95220
209-609-8774
skyguynca(at)skyguynca.com (skyguynca(at)skyguynca.com)
www.skyguynca.com
Posted: Sun Jun 11, 2006 5:48 am Post subject: CH601HD/HDS Main Gear |
David,
The pictures attached give an idea of what was done in this case.
Though I don't believe the spring gear has any advantage
due to its weight and light attachment if you repeat XL structure. You
damage the spring gear and you destroy the fuselage
and all.
Larry McFarland - 601HDS at www.macsmachine.com
David Mikesell wrote:
Quote: | I have seen a few pictures of the spring type gear on a HDS. Does
David Mikesell
23597 N. Hwy 99
Acampo, CA 95220
209-609-8774
skyguynca(at)skyguynca.com <mailto:skyguynca(at)skyguynca.com>
www.skyguynca.com <http://www.skyguynca.com>
Description: |
Filesize: |
274.88 KB |
Viewed: |
396 Time(s) |
Description: |
Filesize: |
268.06 KB |
Viewed: |
428 Time(s) |
Description: |
Filesize: |
263.85 KB |
Viewed: |
415 Time(s) |
Posted: Mon Jun 12, 2006 8:41 am Post subject: CH601HD/HDS Main Gear |
I'm fairly ignorant of the internals of an HDS wing: why keep the stubs of
the old gear? They sure look draggy.
-- Craig
skyguynca
Posted: Mon Jun 12, 2006 9:11 am Post subject: CH601HD/HDS Main Gear |
Really I am not looking for a "advantage" of weight. I just prefer
spring gear. I really don't know how the XL gear is done hence why I
am asking for help.
Posted: Mon Jun 12, 2006 9:37 am Post subject: CH601HD/HDS Main Gear |
I was asking about Larry's plane specifically. From what I see in his photos
he has the spring gear but still has the stubs of the factory gear
protruding from the bottom of the wings.
-- Craig
Posted: Mon Jun 12, 2006 9:42 am Post subject: CH601HD/HDS Main Gear |
Craig,
I think in considering the weight that was added, the builder may have
had second thoughts about
what he'd done. The old gear looked like it had been there for a long
time without paint.
I'd have replaced the old gear struts or blasted and painted them again.
Larry Mc
-- Craig
Posted: Mon Jun 12, 2006 9:48 am Post subject: CH601HD/HDS Main Gear |
David,
You might look closely at the image of the gear and fuselage exploded
view on the Zenith site, see link.
http://www.zenithair.com/zodiac/xl/drawings.html
It might be a little difficult to do on a HDS correctly because of the
tie across the bottom and vertical
supports.
Larry Mc
am asking for help.
skyguynca
Posted: Mon Jun 12, 2006 11:38 am Post subject: CH601HD/HDS Main Gear |
Thanks Larry.
David Mikesell
23597 N. Hwy 99
Acampo, CA 95220
209-609-8774
www.skyguynca.com
btucke73(at)yahoo.com Guest
Posted: Mon Jun 12, 2006 7:14 pm Post subject: CH601HD/HDS Main Gear |
Gents,
I built spring gear mounts for my taildragger HDS
from pictures supplied to me by another builder.
After some ground testing, and jumping the plane up
and down under weight, I found that the forward
fuselage bottom skin is starting to concave. There is
no way it would be able to handle a hard landing. I
am currently rebuilding the mount situation, using the
XL plans for guidance (which is what I should have
done in the first place). Having been through the
process, I am not sure that I would build a spring
gear again. It would probably be a whole lot easier
building mounts for a tri-gear, but it has been a pain
for the taildragger. I am getting to the point where
I am regretting deviation from the plans. Those of
you who are thinking of this mod, give it some good
thought. I think I jumped in a little too hastily.
ADHD is a bitch!
-Please, no "I told you so's." I can see some
of you chomping at the bit as you read this!
R/
Brandon
naumuk(at)alltel.net Guest
Posted: Tue Jun 13, 2006 2:58 pm Post subject: CH601HD/HDS Main Gear |
Brandon-
There are times you can deviate from the plans, but you have to admit,
messing with the gear is about the worst choice of a place to experiment.
On the other hand, they don't call these "Experimental" aircraft for
nothing. I applaud you for your willingness to try a variation, but I think
you have to move the proving stage further upstream.
Right now, you're a coroner, examining the final result. If you would
have built a proof of concept scale model, you probably would have detected
the negative effects earlier, before a major rebuild became necessary. Pain
in the ass, additional time and expense, you bet. Less work and lots more
peace of mind down the line, you bet.
Good building.
Bill
Posted: Tue Jun 13, 2006 5:06 pm Post subject: CH601HD/HDS Main Gear |
By the way, I didn't come up with this idea on my own. A couple of
EAAers from Ohio by the name of Wright were the originators.
Bill
Posted: Thu Jun 15, 2006 6:44 pm Post subject: CH601HD/HDS Main Gear |
Bill,
Quote: | From my original post:
I didn't send my initial response to this - too
irritated. This is the calmer response after a 24
hour cool down. I even took out the expletives. No,
I do not admit that the gear is about the worst place
to deviate from the plans. I would say that the wing
spar, or the control surfaces would probably be a
slightly more catastrophic failure, should something
get too "Experimental." You are correct in that I did
not build a scaled model. As I said in the original
post, there is already a flying example of the design.
Will that meet your "Proof of concept" criterion? I
guess I assumed that full scale and operational would
do it.
Thank you so much for not literally saying "I
told you so." That would have simply been rude. It
may have been equally constructive while utilizing
substantially less bytes though.
Brandon
DO NOT ARCHIVE
Quote: | nothing. I applaud you for your willingness to try a
variation, but I
Quote: | think you have to move the proving stage further
upstream.
Quote: | have built a proof of concept scale model, you
probably would have
Quote: | work and lots more peace of mind down the line, you
bet.
JAPhillipsGA(at)aol.com Guest
Posted: Fri Jun 16, 2006 8:55 am Post subject: CH601HD/HDS Main Gear |
Brandon, is there anything we can do to assist you in putting the pieces back together again ? Let us know, Best regards, Bill of Georgia
rdewees(at)mindspring.com Guest
Posted: Fri Jun 16, 2006 12:34 pm Post subject: CH601HD/HDS Main Gear |
Brandon,
I thought the gear legs look like a great platform for hard points to
mount machine guns and bombs on. Have you considered a military
conversion? Early Mooney Mites were once fitted with .30 cal guns for an
Army contract. It didnt' work out tho
Ron
Definitely don't archive
JAPhillipsGA(at)aol.com wrote:
Quote: | Brandon, is there anything we can do to assist you in putting the
Posted: Fri Jun 16, 2006 2:46 pm Post subject: CH601HD/HDS Main Gear |
Brandon-
The last thing I would ever say is "I told you so" to someone with the
gumption to experiment, and I apologize if my post was written in such a way
as to imply that. I really do. Also, I always have to present the results of
"Proof of concept" experiments at work before getting free rein to the
checkbook, and forget that other people don't do this automatically, like
Pavlov's dog. Sometimes POC is a really good policy, and sometimes it's a
PITA that holds projects back unnecessarily.
The fact that you had the restraint to wait before answering is a good
sign in that you have the patience to work your way out of your mess.
If there is a flying example with your gear mod, (You've probably come
to this conclusion yourself) do some more research and find out what you
missed. There had to be something, or you would be airworthy. Hopefully,
it's just some additional bracing that won't require a major rebuild.
Good luck. We're all in this together, and I'm pulling for you. (Red
Green, 19(??) to date). I deleted your original message to cut down on the
bandwidth.
Bill
