Indicator light circuit with push to test
PostPosted: Sun Jun 09, 2013 1:08 pm    Post subject: Indicator light circuit with push to test Reply with quote
At 11:39 AM 6/9/2013, you wrote:
Hey Bob,
This will be a backlit panel using LEDs (Green, Red or Amber).
I see you point about the reliability of LEDs versus incandescent
bulbs and that makes perfect sense.
It just seems like every panel I've seen (and I'm pretty sure some
where LEDs) had a push-to-test switch. So I was just trying to
follow (what I thought) was best practices.
Yep. That's a common feature in aviation . . . TRADITION
can plow deep furrows . . . and the young bucks are
reluctant to ask, "why is that there?" So some things
keep showing up on next year's models even when their
utility has long since passed . . . like avionics master
switches . . . battery ammeters . . . battery boxes . . .
I did have a conversation a few years ago with
a builder wanting to get some alternator noise
out of his ADF receiver. I asked why he still had
the ADF . . . did he shoot ADF approaches? No,
says he . . . he took the loop antenna off years
ago. It was already installed and he liked to
use it as an AM radio. Seems that FM reception
at altitude was problematic as stations with
shared frequencies appeared over horizon.
The noise turned out to be a ground loop in the
audio wiring. Hammers are likely to be around
for awhile too but I'm using mine less-and-less.
Eric M. Jones
PostPosted: Mon Jun 10, 2013 5:28 am    Post subject: Re: Indicator light circuit with push to test Reply with quote
The really weird thing with using LEDs is that they will last longer than the socket, longer than the switch and longer than the airframe. So unless you're going full-on Steam Punk, or the press-to-test feature really does something useful, just remove the switch and put a cork in the hole.
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
PostPosted: Mon Jun 10, 2013 6:34 am    Post subject: Indicator light circuit with push to test Reply with quote
Does the PTT button for a lamp/socket/switch
combination not produce a false sense of security?
That's sorta like going out on a high risk
hike in the woods having only checked to see
that your sandwiches are packed. We don't
fly indicator lamps, switches, propellers
or aileron control cables. These are all
ingredients that go into recipes for a
flight system
PostPosted: Mon Jun 10, 2013 1:17 pm    Post subject: Indicator light circuit with push to test Reply with quote
At 03:39 PM 6/10/2013, you wrote:
--> AeroElectric-List message posted by: John Grosse <grosseair(at)comcast.net>
Gee, really? The situation I was imagining would be in the air, on approach, but on the ground you would be right:)
Do you happen to remember Eastern 401 that crashed in the Everglades while the crew tried to figure out if the gear light was burned out. A "push to test" function would have been handy to have.
They DID have a PTT function that didn't light the
light. So they were borrowing a lamp from another
fixture. These can be changed without tools but it
does involve 'fiddling' with the little flanged
base lamps common to this style of backlit, sunlight
viewable fixture.
Whoever was supposed to be flying got so involved
in diagnosis and in-flight maintenance issues
that a shift in a/p from altitude hold to
control wheel steering went unnoticed.
This wasn't a case of not having a 'handy'
feature, it was a breakdown of cockpit
protocol.
Bob . . . [quote][b]
PostPosted: Mon Jun 10, 2013 2:32 pm    Post subject: Indicator light circuit with push to test Reply with quote
At 04:24 PM 6/10/2013, you wrote:
Or maybe the simpler solution is two juxtaposed indicator bulbs
wired in parallel.
Actually, there are sunlight viewable, dead-front
annunciator fixtures that mount two bulbs in parallel.
The idea is that the fixture still performs its intended
function with only one lamp . . . but with obvious
gradient of brightness across the face. The likelihood
of loosing two lamps on any one flight cycle is
very remote.
All of the LED sunlight viewable fixtures I've encountered
have multiple lamps . . . mostly to get the light required
total light output and sufficient coverage of the back of
the lens. These too would 'fail gracefully' if single
lamps were to fail.
But again, press-to-test verification of lamp functionality
offers only a meager fraction of the information that
a pilot would really like to have when making important
decisions.
