uuccio(at)gmail.com Guest
Posted: Wed Jun 05, 2013 6:56 am Post subject: flap angles, Kitfox IV |
Hi Kitfoxers,
I’m having some trouble with my full flaps setting on my Kitfox IV. The aircraft (it’s a rebuild) has a tendency to want more right aileron when I select full flaps, which makes me think that I need to take some measurement of the angles of each flaperon with the stick centered and make sure they are the same. Does anyone happen to know what are the angles corresponding to each flap position (zero, 1 notch, 2 notches, full flaps) should be?
Sacha
lcfitt(at)sbcglobal.net Guest
Posted: Wed Jun 05, 2013 12:13 pm Post subject: flap angles, Kitfox IV |
In the past, some Kitfox IV owners have reported enough loss of aileron authority with full flaps that they restricted flap deployment to something like 20 degrees.
Lowell
Sent via DroidX2 on Verizon Wireless™
-----Original message-----
To: Kitfox List <kitfox-list(at)matronics.com>
Sent: Wed, Jun 5, 2013 15:05:44 GMT+00:00
Subject: Kitfox-List: flap angles, Kitfox IV
Hi Kitfoxers,
I'm having some trouble with my full flaps setting on my Kitfox IV. The
aircraft (it's a rebuild) has a tendency to want more right aileron when I
Sacha
Posted: Sat Jun 08, 2013 9:17 pm Post subject: flap angles, Kitfox IV |
Thanks for that Lowell - I thought I had installed something wrong. Works fine with just 2 notches of flaps! I was trying full flaps with (only a little) crosswind but it was definitely not easy to control… now I know!
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of lcfitt(at)sbcglobal.net
Sent: Wednesday, 05 June, 2013 22:13
Subject: Re: flap angles, Kitfox IV
dave
Posted: Sun Jun 09, 2013 1:58 am Post subject: flap angles, Kitfox IV |
Sacha,
Flaps past 20 degrees for landing are uesless.
Full flaps 30 to 35 degrees are VERY usefull while taking off !
The real beneifit is to be found from sticky mud, long grass, sand, and water while on wheels
on Skis -- heavy Wet Snow
On floats -- a real necessity -glassy water take offs --will pop you right off the water
all the above - lifting one side up first and pulling the flaps for full deployment.
Mind you alot have limited the flap travel and for most of you that are pavement pounders
and do not explore the entire envelope of what your plane could actually do it will be jusdt fine.
for the rest - 30 to 35 degree down travel a riot.........
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
New Site - Kitfox related
Will be building soon
http://www.kitfoxflyer.com/
Highest rated on youtube |
jareds(at)verizon.net Guest
Posted: Sun Jun 09, 2013 11:26 am Post subject: flap angles, Kitfox IV |
I may have missed a lot of this conversation but on the model 4 we discussed many years ago how pulling flap lever all the way up one may think that is full flaps but in reality the full flap position is about half of that otherwise you may experience a very irratic stall situation. Full up may give you a speed break but definitely not the position to have it in for takeoff over obstical or landing config short runway etc like in conventional aircraft. Jared
Sacha <uuccio(at)gmail.com> wrote: | Quote: | <![endif]--> <![endif]-->
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of lcfitt(at)sbcglobal.netSent: Wednesday, 05 June, 2013 22:13To: kitfox-list(at)matronics.comSubject: Re: flap angles, Kitfox IV
Sent from my Android phone with K-9 Mail. Please excuse my brevity.
Posted: Mon Jun 10, 2013 12:11 am Post subject: flap angles, Kitfox IV |
Dave/Jared
Thanks for your comments.
I have now clocked up all of 4 hours solo on the Kitfox and there are no other kit foxes locally so I'm kind of learning on my own.
I've taken off with no flaps, 10deg and 20deg and have landed also with those configurations. Everything works fine.
But when I put 30deg flaps (I tried this up at altitude yesterday), the plane starts banking left and I almost need full right stick to keep it S&L. I didn't try this for very long as I'm still not very confident in the plane, but this doesn't feel normal to me. Does anyone have any suggestions for how this might be corrected? I don't really want to limit flap travel to 20deg if I can avoid doing so.
Dave:
I mostly fly from grass strips on wheels. Can you explain how 30-35deg flaps can come in handy for takeoffs? (What situations, what techniques to use). Just trying to learn more about the machine. (I'd love to try floats but it seems like installing a pair is a lot of work, and also I think the life of the aircraft would seriously be shortened by all that salt water....)
Sacha
On Jun 9, 2013, at 11:58, "Dave" <dave(at)cfisher.com (dave(at)cfisher.com)> wrote:
[quote] (at)font-face { font-family: MS Mincho; } (at)font-face { font-family: MS Mincho; } (at)font-face { font-family: Calibri; } (at)font-face { font-family: Tahoma; } (at)font-face { font-family: (at)MS Mincho; } (at)page WordSection1 {size: 612.0pt 792.0pt; margin: 72.0pt 72.0pt 72.0pt 72.0pt; } P.MsoNormal { MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Calibri","sans-serif"; FONT-SIZE: 11pt } LI.MsoNormal { MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Calibri","sans-serif"; FONT-SIZE: 11pt } DIV.MsoNormal { MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Calibri","sans-serif"; FONT-SIZE: 11pt } A:link { COLOR: blue; TEXT-DECORATION: underline; mso-style-priority: 99 } SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline; mso-style-priority: 99 } A:visited { COLOR: purple; TEXT-DECORATION: underline; mso-style-priority: 99 } SPAN.MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline; mso-style-priority: 99 } SPAN.EmailStyle17 { FONT-FAMILY: "Calibri","sans-serif"; COLOR: #1f497d; mso-style-type: personal-reply } .MsoChpDefault { FONT-FAMILY: "Calibri","sans-serif"; mso-style-type: export-only } DIV.WordSection1 { page: WordSection1 } <![endif]--> <![endif]--> Sacha,
dave
Posted: Mon Jun 10, 2013 1:30 am Post subject: flap angles, Kitfox IV |
flaps on take off
If you new to flying -limit your self to 20 degrees.
Take offs with 30 + degrees
zero ot 20 degrees on roll and pulling the last bit as you are real to pop off the sticky surface.
You only want to do this to break ground ......
once airboure - hold nose down and bleeds off flaps to 20 degree- now you got less drag and roll control.
Enjoy.
Dave
Posted: Mon Jun 10, 2013 4:29 am Post subject: flap angles, Kitfox IV |
Thanks Dave. Not completely new to flying (i have a PPL and about 80hrs) but still consider myself very green and definitely new to the Kitfox. It's a little more "lively" than a PA28 or a C172! I personally love it... But i'll take your advice and wait until i've clocked up a bunch of hours to get comfortable before I start experimenting with usual flap configurations.
In the meantime, do you have an opinion regarding my question as to whether a pronounced left roll with full flaps is normal or something in the controls which I should investigate and try to correct...
On Jun 10, 2013, at 11:30, "Dave" <dave(at)cfisher.com (dave(at)cfisher.com)> wrote:
[quote] flaps on take off
Enjoy.
Dave
Tom Jones
Posted: Mon Jun 10, 2013 6:54 pm Post subject: Re: flap angles, Kitfox IV |
Sacha, do you have the "Assembly manual for your Kitfox? You need it to check the rigging on your control system. The flaperons will neutralize themselves in flight. If pulling on flaps causes the plane to roll there is a problem in the rigging.
Due to the design of the differential flaperon control syatem there are different angles built into the flaperon horns in relation to the flaperons. left is 5 degrees and right is 19.4 degrees.
As said in others posts..pulling on full flaps limits roll control. I suspect your problem is the someone rigged your flaperons with the same angles and causes the limit in roll control to be all on one side.
The model 4 did not have "Notches" for the flaps if yours does that is someones own design.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Tom Jones
Posted: Mon Jun 10, 2013 7:07 pm Post subject: Re: flap angles, Kitfox IV |
To get an idea if rigging is out of wack, try this.
Sitting in the ground hold the stick full left and slowly raise the flap handle until you feel the stick start to move to the right. Mark the location of the flap handle when this resistance is felt. Now hold stick full right and pull the flap handle until you fell the stick start to move left.
The position of the flap handle when resistance in the stick is felt in each test should be the same. This is the flap position where roll control starts to be limited by too much flaps. Like I said above. I think yours may be all on one side.
Classic IV
Ellensburg, WA |
Posted: Mon Jun 10, 2013 8:28 pm Post subject: flap angles, Kitfox IV |
Tom,
Thanks a lot for the useful info.
No I have no manual; I was told it's a Kitfox IV but I don't really have any way of verifying that.
I've emailed Kitfox a few times saying i'd like to purchase a manual but i've had no reply yet. I'll keep on trying...
Sacha
On Jun 11, 2013, at 4:54, "Tom Jones" <nahsikhs(at)elltel.net> wrote:
Tom Jones
Classic IV
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p=402448#402448
Posted: Mon Jun 10, 2013 8:47 pm Post subject: flap angles, Kitfox IV |
Thanks again Tom!
I'm away from the aircraft for a week but I'll try this when I'm back and report my findings.
Sacha
On Jun 11, 2013, at 5:07, "Tom Jones" <nahsikhs(at)elltel.net> wrote:
Tom Jones
Classic IV
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p=402449#402449
dave
Posted: Tue Jun 11, 2013 1:49 am Post subject: flap angles, Kitfox IV |
Tom,
Good info - I never touched on the rigging.
Here is some more info that you might find helpful.
http://www.cfisher.com/flapperons/
Michel
Posted: Tue Jun 11, 2013 2:17 am Post subject: Re: flap angles, Kitfox IV |
Hello everyone! ... (long time, no writing!
If it may interest anyone: I have a Kitfox 3 built in 1992 by someone who built it as his 3rd Kitfox. He had limited the flaps to 10 degrees and that's how I fly today.
I never use the flaps if it isn't as a pitch trim on long distance smooth air flights. I control my altitude vs. speed on final by side-slipping.
The only time I have used the 10 degrees flaps on take-off is when on a short and wet grass field. I get airborne a bit sooner and fly a couple of feet over the ground until gaining enough speed to start initial climb.
Michel
Kitfox 3 - Jabiru 2200 - Norway
Tom Jones
Posted: Tue Jun 11, 2013 5:22 am Post subject: Re: flap angles, Kitfox IV |
Dave, thanks for posting the link to Dr. Fox's flaperon differential article. I had all the old " Kitfox Times" magazines in a box but lost it in my last move.
Anyone wanting to really understand the Model IV flaperon differential design go to Dave's link http://www.cfisher.com/flapperons/ and print out
these three pages:
When I read this article when it first came out was the first time I understood the design and what makes it work.
Michel, good to hear you again. You know you were the inspiration that got me motivated to learn to fly my tailwheel kitfox.
Classic IV
Ellensburg, WA |
Posted: Tue Jun 11, 2013 5:40 am Post subject: flap angles, Kitfox IV |
I can echo Michel's comments. I have never landed with flaps. Side slips
makes finding the threshold easy enough. I have them blocked at 20° and
plan on doing some experimenting with them on my new Model IV - maybe.
Lowell
Sent: Tuesday, June 11, 2013 3:17 AM
Michel
http://forums.matronics.com/viewtopic.php?p=402468#402468
dave
Posted: Tue Jun 11, 2013 5:00 pm Post subject: flap angles, Kitfox IV |
Michael - Agree on the flap infor for your model 3
Lowell.- not using flaps ? you are limiting your usefulness of this
plane.
limit 20 degrees - sure for the vast majortiy maybe
BUT
The ones who actually can and want to explore the envelope of their kitfox
further the flaps to their maximun extent will give superior
performance benefits to the ones who chose this route.
Knowing the entire envelope of your plane is a real attribute to all
pilots/owners.
You will
know better how to take off better
know how ot land slower and shorter when needed.
know how to deadstick land on a runway or in a field
know your limits better and better
know to not become complacent
Make a bad situation better
Dave
Posted: Wed Jun 12, 2013 7:51 am Post subject: flap angles, Kitfox IV |
Dave,
Lots of different Kitfoxes and lots of different folks flying in lots of
different environments. I agree with what you said regarding exploring the
envelope, but this is what suits me. I guess the reason I posted is to let
those interested know that there are a variety of purposes, experiences and
preferences when we fly our airplanes. For the individual situation, none
necessarily better than the others - just different. I would be the last
person to suggest that it is "my way or the highway" - but rather just
another way.
Lowell
Sent: Tuesday, June 11, 2013 6:00 PM
Subject: Re: Re: flap angles, Kitfox IV
plane.
BUT
kitfox further the flaps to their maximun extent will give superior
pilots/owners.
You will
Dave
Michel
Posted: Thu Jun 13, 2013 1:55 am Post subject: Re: flap angles, Kitfox IV |
| lcfitt(at)sbcglobal.net wrote: | | Lots of different Kitfoxes and lots of different folks flying in lots of different environments. I agree with what you said regarding exploring the envelope |
I agree with you, Lowell (and I also agree with Dave!
Here in Norway, we have to do a "periodic" test with an instructor every second year. I did mine a week ago. After a few touch & go on two and three points, I am asked to climb 500 ft on a 360 left turn, then descent 500 ft on a 360 right turn. Easy, if you watch the altimeter and the needle rising 180 degrees for a 360 degrees turn. Then I am asked to do a straight ahead stall. Easy, my Kitfox mushes down beautifully. Then I am asked to do a stall in a turn. As for the previous years, I answer "No, I don't like it. This is how a spin starts!" And my instructor says " ... okay!"
My point is, we all have things we like to do and things we don't. We fly for fun so let's keep it fun.
Michel
mikeperkins
Posted: Thu Jun 13, 2013 6:22 am Post subject: Re: flap angles, Kitfox IV |
Dave, do you have numbers for what your standard T.O. distance is with flaps 0, 10, and 20?
_________________ Mike Perkins
Havana, Illinois
Model I, 532, B gearbox, GSC prop |
