		| Author | Message |
		| N6ZY
				|  Posted: Sun Jun 09, 2013 6:22 pm    Post subject: Woodcomp or Airmaster Prop |   |
				| I am getting close to having to select an electric constant speed feathering prop for my 914-powered Europa XS Trigear.  The choice seems to be between the Woodcomp and the Airmaster.  Does anyone have flight experience of both, to provide a comparison?
 My initial impression is that the Airmaster has a good reputation, but that the available blades do not have sufficient twist near the root to offer optimum performance.  Woodcomp blades have the twist, but I have read comments that their after sales service is lacking, and there has been at least on in-flight failure.
 Are my impressions correct, and how does the performance, including top speed, compare?  I should add that i am based in the US, and that I am looking at a two blade prop.  I would appreciate any advice based on real experience.  Thanks
 Jerry
		| Back to top |  |
		| frans(at)privatepilots.nl Guest
				|  Posted: Mon Jun 10, 2013 1:34 am    Post subject: Woodcomp or Airmaster Prop |   |
				| On 06/10/2013 04:22 AM, N6ZY wrote:
  	  | Quote: |  	  | Are my impressions correct, and how does the performance, including top speed, compare?  I should add that i am based in the US, and that
 I have a 914 with a two blade Woodcomp prop with extra twist. I'm very
 happy with the prop. The pitch range is perfect for all power settings,
 speeds and altitudes.
 My tri gear Europa is a real performer. With the recent trip to the
 north cape, flying in formation with two other 914 Europa's, I had the
 lowest manifold pressure and lowest fuel consumption, despite having the
 highest weight on board (with 2 POB where the others were flying solo).
 In economy cruise I can manage 13 liters per hour of fuel with a speed
 of 110 knots. Top speed with WOT is close to Vne.
 I hasten to say that I have made many aerodynamic changes, like an
 optimized cooling system, wing root fairings, mylar strips on all
 control surface gaps, etc. so it is difficult to say how much is
 contributed by just the prop. I had this configuration from the first
 flight so I can't judge the invidual effects.
 BTW I choosed a two blade prop because it has one leading edge less,
 lower skin drag and lower weight, and at least theoretically it should
 give better cruise performance than a three blade prop. But of course
 the two blade prop feels a bit more "rough" due to the inherent
 vibrations of such a prop. But if I had to buy a new prop I would
 probably buy the same one.
 There are not many Europa's with two blade props, so you might find my
 experience interesting.
 With 230 hours, I only had one broken wire inside the spinner,
 resoldered it myself and changed the routing somewhat to minimize
 movements due to centrifugal forces, no further problems.
 I do not use the controller that came with the prop, but use the
 controller from Mark Burton.
 Frans
		| Back to top |  |
		| ploucandco
				|  Posted: Mon Jun 10, 2013 1:39 am    Post subject: Re: Woodcomp or Airmaster Prop |   |
				| Hello Jerry,
 I have had an airmaster and a woodcomp high twist on my monowheel europa. Both were 3 blades props.
 I believe that both are good props but I am happy to have my airmaster back now.
 If you are using the woodcomp, the smartavionics controller is the preferred option.
 Airmaster
 + hub quality and robustness
 + very nice metal spinner
 + controller straigthforward to use
 + no maintenance solution (except for the brushes)
 + support, fast and efficient
 + extremely easy to assemble
 - no high twist blades for cooling
 - expensive
 Woodcomp
 + high twist so better cooling (didn't see relevant improvements in speed)
 + delivered with blades cover
 + look of the blades
 + low noise blades
 - hub build quality
 - complexity of the assembly of the hub (major minus if you get the prop delivered in different pieces)
 - composite spinner
 - support, 1 man show in CZ
 - overall weight (extremely noticable with 3 blades prop)
 - need a 3rd party controller to have a robust solution
 If you are based in the US, I would think twice to use a woodcomp. Airmaster has a local dealer (your preferred Europa US dealer
  and it just works out of the box with no required maintenance.
 The only major issue with the airmaster is that you will need to have cowling adjustements  to ensure proper cooling with the 914.
 Jacques.
		| Back to top |  |
		| kheindl(at)msn.com Guest
				|  Posted: Mon Jun 10, 2013 3:48 am    Post subject: Woodcomp or Airmaster Prop |   |
				| Hi Jerry,
 I agree with most that was said by Frans and Jaques. I just wanted to add that I was the first one with the Woodcomp 3000/2W this side of the pond, and the first on a Europa.
 It was shipped in one piece, so installation was easy. I had terrible support problems because I couldn't get the Woodcomp controller to work properly. I returned it for a refund and switched to the Smartavionics controller. I had a couple of issues with that as well, but a software upgrade fixed that.
 My reason for choosing this prop, because I wanted a feathering 2-blade for the motorglider, and the price was right. Another choice could have been a Hoffmann, at 4 times the price and twice the weight.
 I had 3 (three) motor failures: one in flight, one probably on the ground, and a third, which I now carried as a spare, was totally corroded. At least the pitch control motors used on my prop are not designed for aviation use. I have no idea what motors they use for the Airmaster.
 Because of my experience I don't really trust electric pitch control on any make and tend to make my takeoff in manual. The biggest load on the motor is at high rpm and a failure in the takeoff /climb phase is not desirable. I assume that you have a trigear, because the longer 2-blade jobs are not suitable for a mono. Even the trigear needs to have the nosegear raised a couple of inches.
 Support from the Canadian and US agents is completely useless, and support from the factory ranges from excellent to very slow, depending on whether the only English speaker is present or on a sales trip.
 But in general, there is no need for immediate support, unless you have some kind of failure away from home (as happened to me). This prop seemed to vibrate quite a bit at first, but after balancing the carbs again, it was just as smooth as the Airmaster I was using. In fact I prefer the feel and sound of the Woodcomp.
 Since I smashed the blades in a forced landing on a farm field I have reverted back to the ground adjustable Warp Drive, which is also an excellent prop. When I have the money I will get the Woodcomp refurbished by the factory.
 Karl
  	  | Quote: |  	  | Subject: Woodcomp or Airmaster Prop From: jffisher(at)gmail.com
 Date: Sun, 9 Jun 2013 19:22:35 -0700
 --> Europa-List message posted by: "N6ZY" <jffisher(at)gmail.com>
 Jerry
 http://forums.matronics.com/viewtopic.php?p=402363#402363
		| Back to top |  |
		| Roland
				|  Posted: Mon Jun 10, 2013 4:32 am    Post subject: Re: Woodcomp or Airmaster Prop |   |
				| Hi,
 needless to say that I cannot compete to Frans' numbers. My bird does 110 KIAS at 8.500 ft (XS Trigear, Rotax 914 with no modifications except the factory speed mods) at a fuelburn of 17,5 litres.
 I have the Airmaster 3-blade and am satisfied with it. I had no issues in about two years flying and my impression is, that it's a robust and trouble free installation. When asking Martin (at) Airmaster I always (two times) got a rapid reply.
 I have to admit, that I always tend to the conventional since I'm no friend of experiments in the aviation sector in spite of maybe losing a few knots
 Roland
 PH-ZTI
 XS Trigear 914
		| Back to top |  |
		| rampil
				|  Posted: Mon Jun 10, 2013 12:38 pm    Post subject: Re: Woodcomp or Airmaster Prop |   |
				| Just for the sake of another data point I will add my two cents.
I have been flying with my Airmaster constant speed prop for close to nine years.
 Early in its life the prop spinner cracked, twice, and I TIG repaired it twice,
 then Martin revised the spinner and there have been no further issues. I keep
 up with the suggested maintenance.  I see no advantave to the Woodcomp
 alternative. The "extra" twist for enhancement of cowl port airflow is not a
 factor in a 912s application.
 As for performance quotations, I think they are pretty meaningless without
 data on weight, density altitude, manifold pressure, RPM, etc.
 In my aircraft, at a DA of 3000', GW of 1200#, and 70% power I see a reliable
 118kts TAS with about 4.1 gph. In its current configuration, I don't have enough
 data points to state a performance at 8000' which is possibly where best TAS
 might be for the 912s.
 Your mile will vary!
 Cheers,
 Ira
 Ira N224XS
		| Back to top |  |
		| budyerly(at)msn.com Guest
				|  Posted: Mon Jun 10, 2013 2:06 pm    Post subject: Woodcomp or Airmaster Prop |   |
				| <?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]-->  Jerry,
Full disclosure here, as I am an Airmaster Dealer here in the States:
 Woodcomp, Whirlwind and the AP420 are slightly faster at altitudes above  8500 MSL than the three blade AP332.
 The Airmaster AP332 with Warp Drive Blades is what most Europa's  have.  We are an older kit and we grew with Airmaster, so for the most  part, those of us with six or more years have had the props as they fit like a  glove and our cowl shape is made for their spinner.  Other than brushes we  re-grease annually on inspections.  The Warp Drive is flat bottomed and has  about 16 degrees of pitch and a long club section at the base.  This cuts  back efficiency a bit.  A very tough prop, but very easy to fix dings,  basically bulletproof.  It is very quiet, even at takeoff setting of 5750  RPM.  Stay away from the Warp Drive tapered blade period.  All  my performance problems have been a result of the tapered blade.  Most of  the other manufacturers boast they are faster than the Airmaster but they are  comparing their blade to the narrow chord blade which was heavily sold from the  early 90s to 2002.  The inertia was lower for the narrow chord and frankly  it was sold to prevent overstressing the Rotax starter sprag  clutch.  The wide chord is at the max inertia for the Rotax at 67  inches, but I don't care as we need a 64 inch.  If it has been working for  over ten years, I'll go with performance every time.  I won't sell another  narrow chord blade.
 Whirlwind is hydraulic and I just love hydraulic props, but they leak and  for any service they have to go back to the manufacturer.  Keep a spare  fixed prop.  The blades have great twist and make a wooshing sound at full  power, they are smooth and reliable.  You must use an aftermarket governor  (speed controller) and installation also includes a wonky setup to lock in the  cable and very expensive Rotax oil line set for the governor hookup.   They are very light and if struck the blades are totaled.  Great folks and  good support.  They will paint to suit your colors.  It is the only  other prop I recommend.
 Woodcomp two blade is good but reliability and quick service are hit and  miss.  Like the Whirlwind it has the larger twist and is fairly fast at  altitude.  We don't see much difference in climb.  Most folks see a  small difference in climb in favor of the Woodcomp over the AP332 and that  is mostly MP and RPM fine pitch limit.  Aircraft weights, and  drag vary so I don't hold much stock unless tested on the same aircraft and  conditions.  Theoretically there should be no difference in climb.
 The Woodcomp three blade is nice looking, but has the same reliability  problem.  And you have to buy an after market controller for  reliability.  Duh, they have been doing this long enough to get their stuff  together.  In their defense, I believe part of the reliability is  installation and testing at the factory.  A shame really, it is a nice  looking blade.
 Airmaster AP 4 series can be a two or three blade.
 It has many choices of blades.  I personally like the Whirwind blades  on the AP420 series for performance, Sensenich for the tapered tip and lower  noise on the 430.  The AP430 is quieter and pulls very strong.  A real  good climber and about 10 knots faster than the Warp Drive.   Kiev, and Bolly blades are also available, but they are very light blades and do  not hold up as well as the WD in grass/sandy environments.  Sensenich,  and Whirlwind have a softer leading edge, so for rough or dirty fields or  high grass expect to do maintenance...
 MT makes a very good prop also.  They are reliable, but pricey and the  language barrier is frustrating.  They are also a fast prop, but you will  have to sell a child to own one.
 One other prop is the Hoffman, they are wood/glass and have an electric  drive, but the only ones I am familiar with are the mechanical push pull  lever ones used on the Ximango MG.  I have sold Airmasters to those who  have inquired with that plane...  They are out of Germany also.
 As I said on my website.  I have never been stuck out with the  Airmaster.  With a 9 volt battery, I can manually set a pitch to get home  even with panel electrical failure.
 You can mow the grass with the Warp Drive blade (I have done it, grass  stains everywhere!)  I have flown my Europa with both the two blade AP420  and the AP332.  The 420 performs a bit better at altitude, is easier to get  the cowl off, lighter by about 4-5 pounds, but is a bit noisier outside and  in.  Not a lot of noise on the 64 inch.  Folks at the airport know  when I have the two blade on.  On the longer AP420 props I've tested the  420 is awesome at 70 inches, ground clearance is unacceptable for the  Europa but great on the Rans S-6 and the float planes.  We actually pulled  a float equipped S-6 past redline with a 912S at 5500 RPM and 26 inches of  MP.
 I like things reliable (so remind me why I have a 914?) and my bang  for the buck was the Airmaster.  In 6 years as the dealer, I just don't get  problems or call backs.  I have only had to send them to the  factory for prop strikes (at my insistence as I can't magneflux for hub  cracks).  Normally, guys just plug and play them and I get a call after six  plus years asking how to fix rock dings.  ($75-170 per blade for a rebuild  and repaint depending on damage).  The biggest complaint, Warp Drive blades  are all black and Sensenich is White, with red tips, and black on the back  only.
 Remember, each plane is different.  Apples and oranges is the normal  comparison we owners and dealers get.  I get to see many prop requests  and I have had two Woodcomp owners change to the Airmaster out of frustration  with reliability.  I have never had an Airmaster returned.  I have  changed out the narrow chord blades though on the AP332 for wide chord.
 I like plug and play, and that is what it is on the Europa XS or Classic  with either the AP332 or 420/430 series.
 Bud Yerly
 US Airmaster Dealer
 [quote]   ---
		| Back to top |  |
		| Remi Guerner
				|  Posted: Tue Jun 11, 2013 12:11 am    Post subject: Woodcomp or Airmaster Prop |   |
				| <<<<The "extra" twist for enhancement of cowl port airflow is not a
factor in a 912s application.>>>>>
 Hi Ira,
 I have 630 hours on my Airmaster AP332/WarpDrive and I am very happy with the reliability and performance of this prop. But the cooling problem on the ground with the WarpDrive blades is a big inconvenience, with any engine. All Europas I know, fitted with the WarpDrive prop, fixed or variable pitch, even with the 80 HP 912 have this ground cooling problem as soon as they have to wait more than a few minutes at the holding point in hot weather. With the existing Europa XS cowl, I believe the only  solution would be to have wider blades at the root and higher twist, as offered by Woodcomp.
 Remi Guerner
 F-PGKL, XS Monowheel, 912ULS, 1014 hours.
		| Back to top |  |
		| max8992
				|  Posted: Tue Jun 11, 2013 12:27 am    Post subject: Woodcomp or Airmaster Prop |   |
				| Bud,
 I have an AP332 on my XS and a MT Propeller on my MCR4S both on a 912S. Any comparison from yours? BTW has anyone fitted an MTV-7A on an XS
 As a user/maintainer above my subjective coments:
 MTV-7A: smoother to use ( no predefined pitch) – AP332 : easier to use (predefined pitch, reproducible easily on every flight)
 MTV-7A: nice design, nice efficiency in cruise: 120Kt (at)4800RPM 3000FT and 17 l/h – AP332: square design, very effective at take-off (seems more than MTV-7A) 118 Kt (at)5000RPM 3000FT and 19 l/h
 MTV-7A: TCO more expensive (overall (at)1800 hours or 6 years) –
 Max  Cointe
 mcointe(at)free.fr (mcointe(at)free.fr)
 F-PMLH Europa XS_TriGear
 Kit #560-2003 912ULS/AirmasterAP332 450 hours
 F-PLDJ Dyn’Aéro MCR 4S
 Kit #27-2002 912ULSFR/MTProp MTV7A 1550 heures
 De : owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] De la part de Bud Yerly
 Envoyé : mardi 11 juin 2013 00:06
 À : europa-list(at)matronics.com
 Objet : Re: Woodcomp or Airmaster Prop
 Jerry,
 Max8992
 Europa XS #560 F-PMLH
		| Back to top |  |
		| max8992
				|  Posted: Tue Jun 11, 2013 12:33 am    Post subject: Woodcomp or Airmaster Prop |   |
				| Fully agree, temp on ground is an issue for me (even if our country Auxerre
is not as hot as Remi's one). No such problem with the large blades of the
 MTV-7A (must admit that the cowl looks also better designed on the MCR).
 Max  Cointe
 mcointe(at)free.fr
 -----Message d'origine-----
 [mailto:owner-europa-list-server(at)matronics.com] De la part de Guerner Remi
 Envoyé : mardi 11 juin 2013 10:11
 À : Europa-List Digest Server
 <<<<The "extra" twist for enhancement of cowl port airflow is not a factor
 Max8992
		| Back to top |  |
		| grahamsingleton(at)btinte Guest
				|  Posted: Tue Jun 11, 2013 1:13 am    Post subject: Woodcomp or Airmaster Prop |   |
				| It would be worth researching exhaust extraction. I have it on my Lycoming (pusher Long EZ) and it works
Warm day, full throttle on the ground for 10 minutes, throttle back and it cools down from near red line..
 Graham
 To: Europa-List Digest Server <europa-list(at)matronics.com>
 Sent: Tuesday, 11 June 2013, 9:11
 Subject: Re: Woodcomp or Airmaster Prop
 --> Europa-List message posted by: Guerner Remi <air.guerner(at)orange.fr (air.guerner(at)orange.fr)>
 Hi Ira,
 Remi Guerner
 F-PGKL, XSics.com/Navigator?Europa-List" ="http://forums.matronics.com/" target="_blank">http://forums.matronics                     tronics.com/contribution" target="_blank">http://www.matronics.com/contri================
		| Back to top |  |
		| Roland
		| Back to top |  |
		| N6ZY
				|  Posted: Tue Jun 11, 2013 6:58 am    Post subject: Re: Woodcomp or Airmaster Prop |   |
				| Thanks to everyone who answered my original post, there was a lot of information there.  My end conclusion was much as when I posted, that the Woodcomp prop blades are really good, but the combination of poor quality control and lack of US support makes the Airmaster a better bet for me.  I dismissed the MT prop option as being expensive, and I know from previous experience that MT are not always responsive and they are not troubled by excessive humility!
 So I phoned Martin at Airmaster yesterday and we discussed the options for 20 minutes.  He gets his blades from various suppliers, and basically agrees that it would be much better if he had blades with more twist in them.  He is looking into a number of options.  This includes using Whirlwind blades; although they are a competitor, they are now willing to supply him.  Another option is blades from either Helix or Neuform in Germany.  Finally he can use any of the Sensenich blades.  He suggested that I phone the various blade manufacturers to see what they have for my application.
 The other question we discussed was the prop diameter.  I will fly 98% of the time off hard runways, and cannot see that a 68" diameter prop would be impractical even allowing for flat nosewheel tires (tyres?  I am a Brit living in the US) and my bad landings.  That would open up the number of blade options.  I know that Frans has increased his clearance using some form of nose gear spacer, but I would rather keep it simple if I can.  In addition using a 3 blade prop may make the use of smaller diameter blades equivalent to larger 2 blades.
 My end result is that I will delay the blade selection as long as possible, but will go with the Airmaster prop, probably with 3 blades, and possibly with Whirlwind blades.  They appear from their website to be well shaped with adequate blade twist.
 Any reactions to the use of a larger diameter prop would be appreciated.  Thanks again for the interest and inputs.
 Jerry
		| Back to top |  |
		| nigel_graham(at)m-tecque. Guest
				|  Posted: Tue Jun 11, 2013 7:42 am    Post subject: Woodcomp or Airmaster Prop |   |
				| Hi Jerry,
 You’ve stimulated an interesting thread and received some high         quality         feedback.
 My only         contribution is to         advise you to look carefully at the Maximum moment of inertia of         the combined         prop and VP unit if you are seriously considering fitting a         larger diameter         Prop.
 Rotax advise a         maximum of         6000 Kg cm2 (14,328 lb ft2 in old money).
 You might wish         to discuss         this with Martin before making a final decision.
 Atb
 Nigel                              Normal   0      <![endif]-->
 Normal   0      <![endif]-->            On 11/06/2013 15:58, N6ZY wrote:
 [b] 	  | Quote: |  	  | Snip ....... The other question we discussed was the prop diameter.  I will fly 98% of the time off hard runways, and cannot see that a 68" diameter prop would be impractical even allowing for flat nosewheel tires (tyres?  ..................
 Jerry
		| Back to top |  |
				|  Posted: Tue Jun 11, 2013 8:33 am    Post subject: Woodcomp or Airmaster Prop |   |
				| Good advice Nigel
Graham
 From: "nigel_graham(at)m-tecque.co.uk" <nigel_graham(at)m-tecque.co.uk>
 Sent: Tuesday, 11 June 2013, 16:42
 Subject: Re: Re: Woodcomp or Airmaster Prop
 Hi Jerry,
 Atb
 Nigel
 http://www.matro==================== 	  | Quote: |  	  | Snip .......
 Jerry
		| Back to top |  |
		| paul.the.aviator(at)gmail Guest
				|  Posted: Tue Jun 11, 2013 8:59 am    Post subject: Woodcomp or Airmaster Prop |   |
				| FWIW the new  Whirlwind blades are hollow CF and are amazingly light
On Tue, Jun 11, 2013 at 11:32 AM, GRAHAM SINGLETON <
 grahamsingleton(at)btinternet.com> wrote:
 [quote] Good advice Nigel
 Graham
 *From:* "nigel_graham(at)m-tecque.co.uk" <nigel_graham(at)m-tecque.co.uk>
 *To:* europa-list(at)matronics.com
 *Sent:* Tuesday, 11 June 2013, 16:42
 *Subject:* Re: Re: Woodcomp or Airmaster Prop
 Hi Jerry,
 feedback.
		| Back to top |  |
		| N6ZY
				|  Posted: Tue Jun 11, 2013 11:06 am    Post subject: Woodcomp or Airmaster Prop |   |
				| Thanks.  However the Whirlwind story is confusing.  Effectively there are now two Whirlwind companies, the original for fixed pitch props and a spin-off for constant speed.  I think that Martin at Airmaster was referring to the blades from the hydraulic constant speed outfit.  The fixed pitch company also has new carbon fiber blades, but I think that they are 70", which is a bit much.  I will follow up.  And yes Nigel, thanks, you are right, I do need to check the inertia data.
 This has turned out to be a much more complex question than I originally understood, but it does make quite a difference in aircraft performance and reliability.
 Jerry
 On Jun 11, 2013, at 12:59 PM, Paul McAllister wrote:
 [quote]FWIW the new  Whirlwind blades are hollow CF and are amazingly light
 On Tue, Jun 11, 2013 at 11:32 AM, GRAHAM SINGLETON <grahamsingleton(at)btinternet.com (grahamsingleton(at)btinternet.com)> wrote:
 [b] 	  | Quote: |  	  | Good advice Nigel Graham
 From: "nigel_graham(at)m-tecque.co.uk (nigel_graham(at)m-tecque.co.uk)" <nigel_graham(at)m-tecque.co.uk (nigel_graham(at)m-tecque.co.uk)>
 To: europa-list(at)matronics.com (europa-list(at)matronics.com)
 Hi Jerry,
 Atb
 Nigel
 href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
		| wdaniell.longport(at)gmai Guest
				|  Posted: Tue Jun 11, 2013 11:40 am    Post subject: Woodcomp or Airmaster Prop |   |
				| Jerry
 Thanks for the question.  I for one would appreciate an update - as and when
 possible.  I am about (well within the next 12 months haha) to go through
 the same decision.
 Yours
 Will
		| Back to top |  |
				|  Posted: Tue Jun 11, 2013 11:46 pm    Post subject: Woodcomp or Airmaster Prop |   |
				| On 06/11/2013 11:12 AM, GRAHAM SINGLETON wrote:
  	  | Quote: |  	  | It would be worth researching exhaust extraction. I have it on my Lycoming (pusher Long EZ) and it works
 I implemented exhaust extraction also in my Europa. No venturi, just the
 exhaust tube shorter than the tunnel it is fed through. I could however
 never establish that it is really working as designed. Fact is that I'm
 unable to overheat the engine on the ground, but that can also be the
 result of the completely different low drag cooling arrangement. Or the
 Woodcomp propeller of course.
 Frans
		| Back to top |  |
				|  Posted: Wed Jun 12, 2013 12:25 am    Post subject: Woodcomp or Airmaster Prop |   |
				| It has been         pointed out to         me by a good but irritatingly pedantic friend, with time to         spare and use of a         computer (he’ll be at work then) that the Imperial number I         quoted was missing a         digit.
 For those of         you about to         rush off this morning and fork out an obscene amount of money         for a new prop,         without having first checked the numbers, please be advised that         the correct         Moment Of Inertia should have read 142,328 lb ft2
 With humility
 Nigel
 On 11/06/2013 17:41, Sir Peregrine       Hardly-Worthit wrote:
 [quote]                       <![endif]-->   <![endif]-->
 Not             being picky, but that might be 142,328 lb ft2 J
 http://www.translatorscafe.com/cafe/EN/units-converter/moment-of-inertia/1-9/
 Vice-Chairman,             Pedantic Society
 From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)                 [mailto:owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)] On                   Behalf Of nigel_graham(at)m-tecque.co.uk (nigel_graham(at)m-tecque.co.uk)
 Sent: 11 June 2013 16:42
 Hi             Jerry,
 Atb
 Nigel
  	  | Quote: |  	  |  	  | Quote: |  	  | Snip .......  The other question we discussed was the prop diameter.  I will fly 98% of the time off hard runways, and cannot see that a 68" diameter prop would be impractical even allowing for flat nosewheel tires (tyres?  .................. Jerry |
 0         1         2
		| Back to top |  |
