				 Posted: Tue Jun 11, 2013 5:36 am    Post subject: Air system 'stuff' |
				I am not suggesting this modification is for everyone.  Each owner has
 to make his or her own decision whether to keep the gear and flap
 selectors in the rear cockpit or not.  But if one decides to keep them,
 then by golly make sure you exercise them periodically.  Not exercising
 them periodically can do more harm than good.
 We could create all kinds of scenarios John to justify keeping the no
 longer used components in the rear cockpit.  Then what about the rear
 brake disabling capability?  What about the instrument failure simulator
 switches?  Next question would be, do you always fly with a qualified
 pilot in the rear seat?  If you had a non-pilot in the rear seat
 (happens much more than with a qualified pilot) do you really think the
 non qualified person is going to know what to do in the first place?
 Lastly, the Yak 52 can be landed gear up.    The question is, can the
 person in the back seat REALLY land the airplane?  Gear up OR gear down?
 Dennis
 A. Dennis Savarese
 334-285-6263
 334-546-8182 (mobile)
 www.yak-52.com
 Skype - Yakguy1
 On 6/11/2013 7:55 AM, John Nolan wrote:
 [quote] When removing any components from the aft cockpit I would consider the
  possibility of pilot incapacitation in the forward cockpit with a
  person in the back.
  John Nolan
  On Tue, Jun 11, 2013 at 7:55 AM, A. Dennis Savarese
  <dsavarese0812(at)bellsouth.net <mailto:dsavarese0812(at)bellsouth.net>> wrote:
      Since neither the CJ nor the Yak 52, which have 100% identical
      gear and flap selectors for both front and rear cockpits, the rear
      cockpit gear and flap selectors are no longer used as was
      originally intended; as primary trainers. Therefore gear and flap
      selectors in the rear cockpit serve no functional benefit other
      than to pass the air pressure through them to the front cockpit.
      Why not fabricate a 3 valve and 5 valve bypass 'block' which could
      replace both of these "rarely ever used" components and eliminate
      potential failures in the pneumatic system?
      This is not difficult to do.  In fact, I am pretty sure Jim
      Goolsby modified his rear gear selector and created a bypass. Thus
      he eliminated the potential failure of the unit.  I personally
      fabricated a bypass configuration for one Yak 52 and completely
      removed the rear gear selector.  Replacing a rear gear selector in
      a Yak 52 is far more difficult than on a CJ because the CJ's gear
      selector can be accessed from behind the front seat.  In the Yak
      52 you need a 10 year old skinny kid to get under the instrument
      panel.
      If you have never disassembled a rear gear selector after it has
      started leaking, you would not believe the rust and junk that
      accumulates inside this piece of equipment when it is never used.
      And many folks never even test them during the condition
      inspection.  So they just sit there and corrode over time.
      My contention is, if it is not used and can and will cause
      pneumatic system problems, why not remove it from the system and
      eliminate the potential problem once and for all.
      Dennis
      A. Dennis Savarese
      334-285-6263 <tel:334-285-6263>
      334-546-8182 <tel:334-546-8182> (mobile)
      www.yak-52.com <http://www.yak-52.com>
      Skype - Yakguy1
      On 6/10/2013 4:41 PM, doug sapp wrote:
          Mark,
          It has been my experience that 75% or more of the failures of
          QSF2A valves (3 port valves to you 52 types), and 12-5522-00
          (5 port valve) are caused not by moisture/rust but by grit and
          or pieces of rusted springs.  Years of rusty springs and poor
          maintenance has resulted in the majority of the air systems
          out there being contaminated to some degree.  To combat the
          base problem we switched to all stainless steel springs in
          most all of our valves quite some time ago.  The secondary
          problem of contaminated pneumatic problems is harder to solve
          as flushing the system out is very difficult.  We are
          experimenting with the installation of a second stainless
          steel desiccant filter installed just prior to the rear gear
          valve, if successful this should vastly extend the life of
          these expensive valves.
          Best,
          Doug
          On Mon, Jun 10, 2013 at 12:10 PM, Bitterlich, Mark G CIV
          NAVAIR, WD <mark.bitterlich(at)navy.mil
          <mailto:mark.bitterlich(at)navy.mil>
          <mailto:mark.bitterlich(at)navy.mil>>> wrote:
          NAVAIR,
              WD" <mark.bitterlich(at)navy.mil
              Thanks for the expert advice Doug.  I had never even
          considered that.
              By the way, there is an air filter of sorts in the YAK-50.
           It is
              located on the "T" air divider area where all the check
          valves are
              located (four of them).  It appears to be a circular
          device with
              fittings at both ends and is possibly filled with
          something like steel
              wool.  In any case, whatever was in mine came all to
          pieces and junked
              up the check valves.
              Again: Good advice on a better filter.  Hmmm.
              Mark
				 Posted: Tue Jun 11, 2013 5:51 am    Post subject: Air system 'stuff' |
				Why in the world would you put a "less than qualified person" in the
 front seat of a Yak 52 in the first place?  Putting anyone in the front
 seat of a Yak 52, including even a high time pilot,  without proper
 aircraft-specific instruction and cockpit briefing BEFOREHAND is
 potentially an accident looking for a place to happen.
 Performing aerobatic flight instruction from the rear seat in a Yak 52
 normally presumes the person in the front cockpit is a certificated
 pilot to begin with.  If not, what is that person doing in the front
 seat in the first place?  AND if an instructor is in the back seat and
 teaching aerobatics to certificated pilot, the instructor also has the
 responsibility to provide proper orientation and cockpit instruction
 long before ever having the person in the front seat push the start button.
 Dennis
 A. Dennis Savarese
 334-285-6263
 www.yak-52.com
 Skype - Yakguy1
 On 6/11/2013 8:12 AM, Bitterlich, Mark G CIV NAVAIR, WD wrote:
  I have the same concerns when flying my YAK-50.
  No seriously.... with a "person" in the back, or "you" in the back?  For
  those performing aerobatic flight instruction in their YAK-52's where
  they have some less than qualified person in the front seat, keeping the
  rear seat selectors and indicators working makes sense.  Of course that
  also then assumes the same folks are going to pay special attention to
  the known problems that accumulate due to this decision.
  Otherwise the less than qualified person is probably going to be in the
  rear seat anyway... and if the owner/pilot is incapacitated in the front
  seat the passenger can land it gear up.     Just thinking out loud...
  sorry.
  Mark
		johnrobertnolan(at)gmail. Guest
				 Posted: Tue Jun 11, 2013 5:52 am    Post subject: Air system 'stuff' |
				Dennis,
 You are correct sir and I deffer to your superior knowledge of the 52. My post was, in general, for all to consider this possibility when disabling or keeping/enabling any system.
 John Nolan
 On Tue, Jun 11, 2013 at 9:34 AM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
  [quote]--> Yak-List message posted by: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>
  I am not suggesting this modification is for everyone.  Each owner has to make his or her own decision whether to keep the gear and flap selectors in the rear cockpit or not.  But if one decides to keep them, then by golly make sure you exercise them periodically.  Not exercising them periodically can do more harm than good.
  We could create all kinds of scenarios John to justify keeping the no longer used components in the rear cockpit.  Then what about the rear brake disabling capability?  What about the instrument failure simulator switches?  Next question would be, do you always fly with a qualified pilot in the rear seat?  If you had a non-pilot in the rear seat (happens much more than with a qualified pilot) do you really think the non qualified person is going to know what to do in the first place?
  Lastly, the Yak 52 can be landed gear up.    The question is, can the person in the back seat REALLY land the airplane?  Gear up OR gear down?
  Dennis
  A. Dennis Savarese
  [url=tel:334-285-6263]334-285-6263[/url]
  [url=tel:334-546-8182]334-546-8182[/url] (mobile)
  www.yak-52.com
  Skype - Yakguy1
  [quote] When removing any components from the aft cockpit I would consider the possibility of pilot incapacitation in the forward cockpit with a person in the back.
  John Nolan
  On Tue, Jun 11, 2013 at 7:55 AM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net) <mailto:dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>> wrote:
      than to pass the air pressure through them to the front cockpit.      Why not fabricate a 3 valve and 5 valve bypass 'block' which could
      panel.
      Dennis
      A. Dennis Savarese
      [url=tel:334-285-6263]334-285-6263[/url] <tel:[url=tel:334-285-6263]334-285-6263[/url]>
      [url=tel:334-546-8182]334-546-8182[/url] <tel:[url=tel:334-546-8182]334-546-8182[/url]> (mobile)
      Skype - Yakguy1
          Mark,
          Best,
          Doug
          NAVAIR, WD <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)
          <mailto:mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)>
          <mailto:mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)>>> wrote:
              --> Yak-List message posted by: "Bitterlich, Mark G CIV
          NAVAIR,
              WD" <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)
          considered that.
           It is
          valves are
          device with
          pieces and junked
              Mark
				 Posted: Tue Jun 11, 2013 5:59 am    Post subject: Air system 'stuff' |
				I totally agree.
 I was playing "Devils Advocate".
 Mark Bitterlich
 p.s.  My Guy In Back is usually hanging on by a long rope.
				 Posted: Tue Jun 11, 2013 6:07 am    Post subject: Air system 'stuff' |
				John,
 I would agree with you if the airplane's mission today was for primary
 or initial flight instruction.  But since it is not, components that can
 potentially fail could be removed.  Again, that decision is always up to
 the owner.
 Dennis
 A. Dennis Savarese
 334-285-6263
 www.yak-52.com
 Skype - Yakguy1
 On 6/11/2013 8:50 AM, John Nolan wrote:
 [quote] Dennis,
  John Nolan
      gear down?
      Dennis
      A. Dennis Savarese
      Skype - Yakguy1
          John Nolan
          the rear
          and flap
          other
          'block' which could
          eliminate
          bypass. Thus
          completely
          selector in
          CJ's gear
          the Yak
          instrument
              panel.
          it has
          never used.
          system and
              Dennis
              A. Dennis Savarese
          334-285-6263 <tel:334-285-6263> <tel:334-285-6263
          <tel:334-285-6263>>
          334-546-8182 <tel:334-546-8182> <tel:334-546-8182
          <tel:334-546-8182>> (mobile)
          www.yak-52.com <http://www.yak-52.com> <http://www.yak-52.com>
              Skype - Yakguy1
                  Mark,
          failures of
          12-5522-00
          grit and
          and poor
          systems
          combat the
          to solve
          rear gear
                  Best,
                  Doug
          <mailto:mark.bitterlich(at)navy.mil>>>> wrote:
          G CIV
                  NAVAIR,
                  considered that.
          YAK-50.
                   It is
          check
                  valves are
                  device with
                  pieces and junked
                      Mark
		markdavis(at)wbsnet.org Guest
				 Posted: Tue Jun 11, 2013 6:22 am    Post subject: Air system 'stuff' |
				The good news with a YAK-52 is that if you kill the  mags and land flaps up you likely will do very little damage to the aircraft in  a gear up landing.  This of course would depend on a GIB that understands  this concept and actually gives a s#%t at the time!
  Mark Davis
  N44YK
  [quote]   ---
		bwade154(at)yahoo.com Guest
				 Posted: Tue Jun 11, 2013 6:52 am    Post subject: Air system 'stuff' |
				As were talking about air system stuff
 Does any one know if the air start valve solenoid is polarity sensitive? The wire plug connector can be attached both ways. Took it out cleaned it now it doesn't work I have voltage at the wire when start button is pushed, valve works when the lever is pushed down? Just ordered new Batteries.
 Bill Wade
  To: yak-list(at)matronics.com
  Sent: Tuesday, June 11, 2013 10:20 AM
  Subject: Re: Air system 'stuff'
  Mark Davis
  N44YK
  [quote]   ---
				 Posted: Tue Jun 11, 2013 7:28 am    Post subject: Air system 'stuff' |
				Bill,
 If I am not mistaken, a Cannon plug without a key-way indicates it can
 be connected either way.  Since it is nothing more than a solenoid with
 power and ground being applied, it should work either way.
 You can easily test it though with a 24 volt battery and some leads.
 Connect them both ways and see if the solenoid engages or not.
 Battery voltage has a significant effect on whether the solenoid engages
 or not.  Less than about 22 volts on the battery voltage instrument may
 not engage the solenoid.
 Dennis
 A. Dennis Savarese
 334-285-6263
 www.yak-52.com
 Skype - Yakguy1
 On 6/11/2013 9:50 AM, bill wade wrote:
 [quote] As were talking about air system stuff
  Bill Wade
  *To:* yak-list(at)matronics.com
  *Sent:* Tuesday, June 11, 2013 10:20 AM
  *Subject:* Re: Air system 'stuff'
  Mark Davis
  N44YK
				 Posted: Tue Jun 11, 2013 7:32 am    Post subject: Air system 'stuff' |
				Yes, it should be polarity sensitive even though I have never tested it
 to that effect.  We are talking DC here, so if we reverse the polarity,
 the magnetic field will reverse as well.  I never realized that the plug
 could be connected both ways.  Hmmm.
 Connect an ohm-meter to the two pins on the solenoid and check to at
 least see that you do not have an open, meaning make sure coil is not
 dead.
 Check cockpit volt meter and make sure when you press the start button
 that you are not dropping voltage below say ... 20 volts minimum...
 actually should stay up around 23 VDC or so, but even 20 volts (when
 pushing the start button) should open the valve.
 You checked for voltage to one pin on the feed plug, but did you check
 the other pin with an ohm-meter and make sure it has a good reading to
 ground?  If you really want to be sure, connect about a 20 watt (or so)
 light bulb across the two pins in the plug and make sure it lights when
 you hit start.  Realize that when you check for power on a plug like you
 just did, it is being checked with zero load (no current flow).  So if
 you have a ton of resistance in the wire, it will still read the exact
 voltage that you want to see.  Meaning, voltage drop equals current
 times resistance.  So if E=IR and you have zero current ... zero times
 anything is zero, so you will have no voltage drop.  This rarely is a
 concern because wires normally just fail open.  But once in awhile it
 can really bite you in the tail if you are not aware of it.
 In any case, putting a light bulb across the two pins on the feed plug
 puts a load on the wires. If the bulb lights up bright, you have good
 wiring, if it glows dimly, you have high resistance somewhere.  Simple.
 Did you take it out and clean it because you were already having a
 problem?  Or just because .....  Usually problems of this nature are not
 with the aircraft wiring, but with the device itself.  A lot has already
 been writing about these things.. you might want to check the archives.
 Mark
 p.s. Doug Sapp has new ones.
				 Posted: Tue Jun 11, 2013 1:18 pm    Post subject: Air system 'stuff' |
				Actually Mark I've been having problem's building air and a friend cleaned his air starter and reported very good results on higher RPM when starting so I thought as I'm messing with the air system and I've read it should be cleaned periodically (first time in 13 years) I would take a look, falls under if it isn't broke don't fix it! actually it was very clean. As for the building air seems to be from the pump to the check valve and still chasing it, looking for a flex hose from the pump to the snot valve. I will try the bulb thing and check for an open in solenoid. Thanks
 Bill Wade
    From: "Bitterlich, Mark G CIV NAVAIR, WD" <mark.bitterlich(at)navy.mil>
  Sent: Tuesday, June 11, 2013 11:29 AM
  Subject: RE: Air system 'stuff'
 --> Yak-List message posted by: "Bitterlich, Mark G CIV NAVAIR, WD" <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)>
 dead.
 Mark
				 Posted: Tue Jun 11, 2013 1:32 pm    Post subject: Air system 'stuff' |
				Doug Sapp has the flexible hose from the compressor output check valve banjo fitting to the snot bottle.
 Dennis
 To: "yak-list(at)matronics.com" <yak-list(at)matronics.com>
 Sent: Tue, June 11, 2013 4:19:32 PM
 Bill Wade
 dead.
 Mark
		Rob Rowe
  Joined: 10 Jan 2006 Posts: 124 Location: Berkshire, UK
				 Posted: Wed Jun 12, 2013 2:38 am    Post subject: Re: Air system 'stuff' |
				 	  | mark.bitterlich(at)navy.m wrote: | 	 		  Yes, it should be polarity sensitive even though I have never tested it
 Mark
 Beg to differ here, standard solenoids are inherently NOT polarity sensitive.
 Yes reversing the polarity does reverse the magnetic field, but the induced polarity of the soft iron plunger core also reverses - so the direction of force remains unchanged.
 Now if the soft iron core plunger is replaced with a magnetised version then you'll get a polarised solenoid ... and it will be marked accordingly.
 You will also find polarity marked terminals on more modern solenoids/relays too, designed to work with electronic drivers versus mostly electro-mechanical systems in Yaks/CJs (where the bus battery effectively absorbs the bulk of any transient energy generated).
 This is not for their basic function, but because they have an integral back-emf protection diode in parallel with the coil to suppress the (potentially several hundred volt) negative spike produced as the coil field collapses when the solenoid is turned off.
 Hence the terminal polarity is essential to prevent this protection diode from being destroyed through continuous forward conduction, rather then a brief spike.
 Hope this helps.
 Brgds, Rob
				 Posted: Wed Jun 12, 2013 6:44 am    Post subject: Air system 'stuff' |
				Contact me with personal email if you still have problems.
 Problems with building air.  Lots already written on that subject as
 well.  You're on the right track.  I replaced the compressor to snot
 valve hard line years ago in my 50 (and a friends 52) with a Russian
 flexible line.  Sukhoi's have them, but darn if I know the part numbers.
 Exact fit.  At one time I believe Doug Sapp or someone else was making
 them?  Can't remember.  That line cracks and leaks all the time.  Also
 the banjo fitting on the compressor.  Well known "gets dirty and doesn't
 work right" item.  Be aware it needs crush washers to repair properly.
 This is the short version.
 Good luck.
 Mark
				 Posted: Wed Jun 12, 2013 6:59 am    Post subject: Air system 'stuff' |
				Rob said:
  	  | Quote: | 	 		   Beg to differ here, standard solenoids are inherently NOT polarity
 sensitive.
 Rob's dead right.  I was dead wrong.  Did not think it through, sorry
 folks.
  	  | Quote: | 	 		   Yes reversing the polarity does reverse the magnetic field, but the
 Yep, he's right again.
  	  | Quote: | 	 		   This is not for their basic function, but because they have an
 I doubt many on this list are familiar with reverse EMF caused by a
 collapsing magnetic field, but you're right yet *AGAIN*.
 Anyone reading this needs to take note of just whom I am speaking to:
 Rob Rowe [yak-list(at)robrowe.plus.com]
 I've not met too many people that know more than I do about YAK
 Electrical systems.  This gent is one of them.
 Thanks Rob for the (polite) correction.  Hey, when you're wrong, you're
 wrong... and I was here!
 Take care,
 Mark
		Rob Rowe
				 Posted: Wed Jun 12, 2013 8:18 am    Post subject: Re: Air system 'stuff' |
				Kind words Mark but you're the real hands-on expert, I'm just the theorist!
 Reminds us though that the Yak/CJ electrical bus can be a hard place for modern hi-tech avionics to survive, where your best friends are well maintained batteries that help absorb electrical noise.
 While the hi-tech kit will have transorbs and other protection devices fitted, they're designed for occasional transients.
 If your batteries are in poor shape then you could be subjecting the bus to frequent transients from a couple of dozen relays & solenoids, let alone the shower of sparks & carbon pile regulator.
 So a small investment in looking after your batteries will help look after your big investment in sophisticated avionics kit.
 Cheers, Rob
				 Posted: Wed Jun 12, 2013 3:48 pm    Post subject: Air system 'stuff' |
				Boy is that the understatement of the year!   A lot of folks in the aerobatic world put really small mini batteries in the Sukhoi's to save weight.  Works great!   For a little while.   Sometimes less than a year.  Then because they are constantly over-charged and otherwise "abused", they sag. Of course then they droop.  Then they fail to absorb spikes.  Then crap starts blowing up all over the airplane.
  Add an electric smoke pump, and radios and transponders bite the dust.
  As I said, you need to listen tot his guy.
  Mark
 Sent: Wed 6/12/2013 12:18 PM
 Subject: Yak-List: Re: Air system 'stuff'
  [quote]--> Yak-List message posted by: "Rob Rowe" <yak-list(at)robrowe.plus.com>
 Cheers, Rob
 http://forums.matronics.com/viewtopic.php?p=402558#402558
