Posted: Sat Jun 15, 2013 6:32 pm Post subject: IVO Prop Vs Warp Drive - Rotax 503 - FS2 - Advice |
At 01:23 PM 6/15/2013 -0700, you wrote:
..........Should I switch to a 3 blade warp drive or just stick to IVO. On
the forum I have heard good things on the warp drive prop and since they
cost almost the same, I wanted some input from you all and then proceed
ahead!
Mahesh,
Check out the spec for your gear box to find out the maximum propeller
moment of inertia it can swing. Also remember that the smaller the
propeller moment of inertia the easier it is for the propeller to absorb the
engine torque impulses due to individual cylinder/piston firing impulses.
This also translates to less engine generated vibration being transmitted to
engine crank, gear box, the cage and gives a smoother ride.
Jack B. Hart FF004
Winchester, IN
miyer2u
Posted: Sat Jun 15, 2013 8:41 pm Post subject: Re: IVO Prop Vs Warp Drive - Rotax 503 - FS2 - Advice |
Thank you John and Jack.
I have a 2.28 'B' Box and my current prop is a 3 blade 72 Inch IVO.
It has never given me an issues in the last 8 years, Did well on climb and cruise, but if there something better out there in the market then I will surely like to try it out!
Mahesh
