sarg314(at)gmail.com Guest
Posted: Sun Jun 16, 2013 10:44 pm Post subject: retorquing bolts on catto prop. |
I am doing the annual on my 6A. I re-torqued the prop bolts 22hrs ago (though that was about 10 months). Check list calls for re-torquing them, but I don't see that it's worth disturbing the thing. Catto recommends a much longer re-torquing interval than the average wood prop anyway, due, I guess, to the fiberclass outer layer of the prop.
Any opinions on this ?
Tom Sargent
Painless
Joined: 10 Jan 2006 Posts: 40 Location: Peshtigo, Wisconsin
Posted: Mon Jun 17, 2013 4:13 am Post subject: retorquing bolts on catto prop. |
I torque mine every other year
Jeff Orear
RV6A N782P
On Jun 17, 2013, at 1:43 AM, thomas sargent <sarg314(at)gmail.com (sarg314(at)gmail.com)> wrote:
[quote]I am doing the annual on my 6A. I re-torqued the prop bolts 22hrs ago (though that was about 10 months). Check list calls for re-torquing them, but I don't see that it's worth disturbing the thing. Catto recommends a much longer re-torquing interval than the average wood prop anyway, due, I guess, to the fiberclass outer layer of the prop.
Tom Sargent
_________________ Jeff Orear
RV6A N782P
Peshtigo, WI |
n320wt(at)yahoo.com Guest
Posted: Mon Jun 17, 2013 6:38 am Post subject: retorquing bolts on catto prop. |
I removed my Catto prop several times each year. Actually every time I removed my cowl. This was just the easiest thing to do for me on my aircraft. My point is that each bolt should be loosened before it is re-torqued to avoid any errors. How often to re-torque the prop depends on what climate you live in. Annually might be fine in the desert but monthly might be necessary in humid areas prone to wide barometer changes. Your airplane, you must decide!!!
Sent from my iPhoneBrian Alley
carbonfibercomposites.net
304-395-4932
On Jun 17, 2013, at 2:43 AM, thomas sargent <sarg314(at)gmail.com (sarg314(at)gmail.com)> wrote:
Tom Sargent
cs.com
matronics.com/contribution
HCRV6(at)comcast.net Guest
Posted: Mon Jun 17, 2013 2:26 pm Post subject: retorquing bolts on catto prop. |
Once a year at annual time.
Harry Crosby
RV-6 N16CX, O-360/Catto prop
To: "rv-list" <rv-list(at)matronics.com>
Sent: Sunday, June 16, 2013 11:43:56 PM
Subject: retorquing bolts on catto prop.
Tom Sargent
