graeme bird
Posted: Sun Jun 23, 2013 12:06 pm Post subject: Use of reserve tank |
First sorry I didn't make it to the UK AGM - too windy for me.
I mentioned in my Gumpy Scotland post that I landed with 11 litres remaining. That was the reading on my FP-5L and I was able to put in 57 litres of fuel and so it was confirmed.
I was tempted to switch to reserve on approach for a sure 9 ltrs or so hopefully there. I didn't but I was ready to switch. Opinions?
Also I wondered how much would be on the reserve side after a few (gentle)turns. I guess you would actually have a bit longer on main and less than expected in reserve.
Also I filled to the top, I cant recall if the 68ltrs included the neck etc (Mono rubber style.
_________________ Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk |
Posted: Sun Jun 23, 2013 12:28 pm Post subject: Use of reserve tank |
Graeme, I measured my reserve long ago as having 11 litres
useable in it, a comfortable 1/2 hr reserve. It shouldn't
make any difference if you do turns (or even a loop!) as
they should be balanced so that neither you nor the fuel
wants to slide off to one side, but on top of that while
you are on main the reserve is constantly being topped up
by the return line.
I have a low pressure warning light and on several
occasions I have flown until the main ran dry. This put my
light on, fairly soon followed by the engine running a bit
hesitantly! but with either the light or the hesitation
giving enough time to switch to reserve and carry on
normally. You would probably not want that to happen at a
critical stage of a demanding landing so switching to
reserve if you are close to running out makes excellent
sense if about to land. If you find yourself having to do
several go arounds and you cough on reserve, you can
always switch back to main!
regards, David Joyce, GXSDJ
On Sun, 23 Jun 2013 13:06:56 -0700
"graeme bird" <graeme(at)gdbmk.co.uk> wrote:
for me.
confirmed.
reserve.
Graeme Bird
G-UMPY
Mono 912S/Woodcomp 3000/3W
Newby: 55 hours 1 year
g(at)gdbmk.co.uk
http://forums.matronics.com/viewtopic.php?p=403228#403228
Un/Subscription,
Forums!
Admin.
rlborger(at)mac.com Guest
Posted: Mon Jun 24, 2013 4:57 am Post subject: Use of reserve tank |
Frans,
Thanks very much for your detailed observation and explanation!
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On Jun 24, 2013, at 7:12 AM, Frans Veldman <frans(at)privatepilots.nl> wrote:
On 06/24/2013 12:10 PM, Sidsel & Svein Johnsen wrote:
| Quote: | I maintain that the best procedure is to run the main tank almost empty (or
until coughing engine, if one dares to), and only then switch to the reserve
tank. If that tank should run dry, there is nothing left in the main tank
(no return flow has spilled over to the main tank after consumption from
reserve tank started) - you have used all fuel there was.
I have two tank sensors, one in the main and one in the reserve side. My
tank sensors are very sensitive near the tank bottom and they display
the amount of fuel with a resolution of 1 liter! So I can offer some
insight in how the tank empties.
What I observed when I got home with little fuel left, is that once the
main tank is zero, quite a lot of fuel sloshes from the reserve to the
main side. While draining the main side, all return fuel (for the 914 a
multiple of what the engine actually uses) returns to the reserve side,
so although fuel is sloshed over constantly, it is also refilled
constantly. So, the main tank slowly decreases until it reaches zero and
the reserve side remains filled to the brim all the time.
When switching to the reserve side, the situation changes dramatically.
Fuel being sloshed over from reserve to main is now no longer pumped
back automatically. And a lot of fuel sloshes over because the tank is
wide near the top of the saddle and of course the reserve is filled just
to the edge of it. It is like walking with a bucket completely filled
with water and you don't need much movement to loose quite a lot of the
contents. In a short while I had collected 4 liters in main again (4
liters isn't much but it is half the contents of the reserve side!). It
was just moderately turbulent, the usual thing on a hot summer day with
some cumulus above the airplane, and being aware of the low fuel I tried
to keep things as calm as possible.
So, if you don't switch back to main, you can't count on having 9 liters
in reserve, but only half of it.
When I switched back to main, the main tank got empty again in two
minutes, because the 914 pumps displace 120 liters per hour and all the
excess fuel is put in the reserve side again. I kept my hand on the fuel
valve, it was just a matter of counting down and seeing the fuel quickly
move from the main to the reserve side again. Now I had 8 liters again
I had to repeat this once more, and after that the fuel level was low
enough to stay in the reserve side. And of course about that time I was
landing, with 4 liters left plus a silent amount of 2 liters of
"unusable" fuel.
The lessons here:
1) If you don't switch back to main, you only have half the amount of
the reserve tank available.
2) Avoid to empty the reserve side while there is still (or again) fuel
in main left, because once you switch back to main the fuel will be
pumped over again in the reserve side in just a minute!
3) Be prepared to switch a few times between main and reserve to keep
the fuel as much as possible in the reserve side.
4) Be aware, especially with a 914, that the main tank will drain very
quickly once the reserve tank is no longer full.
5) If you don't have separate fuel sensors, fuel management will become
very difficult while flying on reserve: The reserve will empty more
quickly than anticipated, and once it is empty, you will find fuel again
in main, but as it is pumped over, it will quickly disappear and then
the reserve side has fuel again!
Frans
graeme bird
Posted: Mon Jun 24, 2013 9:31 am Post subject: Re: Use of reserve tank |
thanks for the contributions, that is all really helpful. Handy to know how long it takes, that it runs rough before cutting and of course that the fuel pressure gauge can be very useful then. Also that if running on reserve is essential, and conditions are bumpy switching back to main for a minute in the early ltrs will increase the range.
kit4 (Wagstaff) TBD
terrys(at)cisco.com Guest
Posted: Mon Jun 24, 2013 10:20 am Post subject: Use of reserve tank |
I have one comment on the subject of allowing the main to completely run out, then switching to the reserve. We did that once to check the procedure in a safe, controlled, environment. The engine quit but was still wind milling. After switching to reserve, the engine restarted and went to high RPMs because the Airmaster CS prop had gone to full fine pitch when the engine cut out, and took some time to recover once the engine restarted.
The lesson of the story is, pull the throttle back to idle before switching in the reserve tank.
Terry
Posted: Mon Jun 24, 2013 12:50 pm Post subject: Use of reserve tank |
Hi! Terry /all.
I had an unplanned such event but with the direct drive Jabiru 6 fitted. I
have a long range tank fitted and although full did a wing over to position
for a photos shoot of a hotel as we left Majorca. Unbeknown that stopped
the siphon from the long range tank to the main tank , About 2 hours later
over the Pyranees to the West Spanish coast we suddenly had total silence!
Which is about the most sensitive thing that can happen to a powered flight
pilot ! I estimate I lost about 50 feet of my then 5,000ft before the engine
windmilled to start immediately. My friend with me asked what we would do to
which I replied "you will need to turn round in your seat and pump that
siphon hand ball to re-establish the siphon like you are milking a cow (or
something like that !) When I could see the gauge was back reasonable again
we switched to main tank but actually landed on the reserve tank by which
time we knew was full to over flow the saddle. I must say I have never
tried an in flight re-start with the gearbox Rotax Engine, I just don't
like to tempt providence ! If someone has the minimum windmill speed of a
914 Rotax I'll be obliged to know ? and you would be doing me a real
service.
Also If Mark Burton is reading this would he advise if the Woodcomp Prop
with the Smart Controller is likely to motor to fully fine in the event of
an abrupt un intended engine stop ?
Happy Days !
Best regards
Bob Harrison. G-PTAG
frans(at)privatepilots.nl Guest
Posted: Mon Jun 24, 2013 1:13 pm Post subject: Use of reserve tank |
On 06/24/2013 10:47 PM, Bob Harrison wrote:
| Quote: | Also If Mark Burton is reading this would he advise if the Woodcomp Prop
Although I'm not Mark Burton I think that indeed it will motor to fully
fine. The controller tries to maintain the target RPM, if the RPM drops
it will set a finer pitch, that's what it is supposed to do. If the
engine is out of fuel, the RPM drops, so the prop will be set to fully fine.
Frans
Posted: Mon Jun 24, 2013 1:25 pm Post subject: Use of reserve tank |
Hi Bob,
We have shut the engine down in flight with both the Whirlwind CS prop and the Airmaster. In both cases, the prop stops turning just above 50 knots, and once stopped, does not begin wind milling again until a little over 100 knots. This is with the 912S, which has higher compression than the 914, so your numbers may vary from this.
Terry
klinefelter.kevin(at)gmai Guest
Posted: Mon Jun 24, 2013 3:31 pm Post subject: Use of reserve tank |
Hi Terry and all,
I stopped my 914 a couple days ago,feathered the Airmaster and went for a long glide. Windmill start happens at about 90 knots.
I was doing touch and goes a while back in my Mono and ran out of fuel on the main just after liftoff. No problem, I just landed on the remaining runway, but that really got me thinking! I didn't realize my fuel was quite that low. So now my Takeoff and Landing checklist includes fuel selector on reserve.
Kevin
On Jun 24, 2013, at 2:25 PM, "Terry Seaver (terrys)" <terrys(at)cisco.com> wrote:
Hi Bob,
Terry
kpeng
Posted: Mon Jun 24, 2013 5:26 pm Post subject: Use of reserve tank |
Gentlemen ,
I'm stunned by this discussion. Why would you wish to go anywhere near running out of fuel? I would never take p2 with you or allow my family to take a flight with any of you!!. This talk about changing from one side of the tank and guessing what is sloshing about in the reserve is crazy and what kills people. In 14 years of Europa flight I have had no reason to go anywhere near running out of fuel. How is it that some guys have to tape up the filler cap ? Or extract litre's of water out because it was in a shower ? It's news to me.... I think I'll buy an umbrella Kevin the safe one.
On 25 Jun 2013, at 00:30, Kevin Klinefelter <klinefelter.kevin(at)gmail.com> wrote:
Hi Terry and all,
Kevin
> Hi Bob,
> Regards,
> Terry
kpeng
Posted: Mon Jun 24, 2013 5:38 pm Post subject: Use of reserve tank |
Ps, Go buy Powerflarm so you don't crash into me or fall on me because you ran out of fuel. Kevin the safe one.
On 25 Jun 2013, at 02:26, Kevin Kedward <kpeng1(at)hotmail.co.uk> wrote:
[quote] Gentlemen ,
> Hi Terry and all,
> Kevin
>> Hi Bob,
>> Regards,
>> Terry
Posted: Tue Jun 25, 2013 1:56 am Post subject: Use of reserve tank |
On 06/25/2013 03:26 AM, Kevin Kedward wrote:
| Quote: | Gentlemen , I'm stunned by this discussion. Why would you wish to go
I guess it is nobody's wish but it sometimes happens. That is why we
have a reserve after all, to use it when it is needed. Some of us
(mostly the frequent flyers, the people that travel long distances and
explore the world with their Europa) have had to use the reserve fuel,
and that is why we have the reserve fuel after all. Nobody has crashed.
Be happy that some people are able to describe what happens when you are
low on fuel and how to get the most out of your reserve fuel.
In my case it was at my homefield, I had radio contact with them, knew
that I could land there (with many suitable farmer fields on the way to
it), with a very accurate fuel flow sensor (and return flow sensor, no
guessing here!), fuel computer with GPS ground speed input, fuel flow
and fuel level, calibrated tank sensors with a resolution of 1 liter. It
was a highly reliable exercise in a very safe and predictable
environment and I arrived with the exact amount of fuel as calculated.
I'm happy to have had this experience, so I know that I can and know how
to actually use my reserve in the event of a genuine unforseen situation.
| Quote: | This talk about
No, it saves people. Maybe some day someone runs nearly out of fuel and
remembers this discussion, that you can't use the 9 liters of fuel
unless you switch back to main to retrieve the sloshed over fuel.
What't the idea of carrying around some pounds of fuel for an emergency
if you don't know how to use it when it is really needed?
Quite often the uninformed people get killed, people who never dare to
explore the limits when it is safe to do so. In this case you could get
killed because you count on having 9 liters of reserve but don't know
that in reality you can only use 4 liters of it, unless you know how to
deal with it properly. And that under no circumstance you should switch
to reserve too early and try to save some fuel in main for the landing.
| Quote: | In 14 years of
of fuel.
Maybe some day you will have. You are facing an unpredicted head wind
over sea with no suitable airfield for an extra fuel stop. Or you have a
faulty gasket in your carb and the engine is suddenly running rich and
consuming more fuel than expected, or the choosen airfield is suddenly
closed and you have to divert and are put in a holding pattern. Are you
going to declare a fuel emergency because you have only 20 liters of
fuel left?
Why would you fly around with all this fuel if you are so sure you will
never have to use it? You probably tried to built your airplane as light
as possible, and now you are spoiling it by carrying around pounds of
useless fuel?
| Quote: | How is it that some guys have to tape up the filler cap ?
What would you do, leave the water in the tank? I'm sure that "someone"
was not amused to find the water in his tank, and I think it is fully
understandable that he from now on tapes of his fuel cap as an extra
precaution to prevent water ingress.
How can you be sure it will hever happen to you? Unless of course you
keep your airplane sheltered and only take it out on a sunny day for a
trip around the home field. Are you actually hosing over your aircraft
anually for a few hours to see whether the fuel cap is really water
tight, or are you just assuming the cap is tight and remains that way
for the rest of its life?
I'm happy that people are willing to share their experience, even if it
sounds "stupid" to some who think they are wiser than the rest of us.
I will be giving the fuel cap some more attention, thanks Bob!
Frans
ptag.dev(at)talktalk.net Guest
Posted: Tue Jun 25, 2013 2:10 am Post subject: Use of reserve tank |
Thanks for that Kevin don't suppose you remember what you did with the
throttle do you ? ......Mine starts hot on the ground with half throttle
just instantly.
I don't believe it's necessary for each one of us to experiment when the
information is readily available(except there will be a slight variation
between different props as well as engines obviously the main ting is to get
it restarted and surely the starter would be more instantaneous and the
windmill effect would only be needed in the event of the starter failing for
whatever reason .. Actually I'm surprised it starts anyway with the gearbox
effect! The Direct drive on the Jabiru was as if nothing had happened!.
Bob Harrison G-PTAG
Posted: Tue Jun 25, 2013 2:22 am Post subject: Use of reserve tank |
Thanks for that Terry, I'm a bit of a wimp and not ashamed to admit it !
Bob Harrison G-PTAG
Posted: Tue Jun 25, 2013 2:25 am Post subject: Use of reserve tank |
Thanks Frans
..........which I guess provides most instant torque to wind up the engine
anyway !
It is good to see the damn English weather is now better after it was so
desperately needed to be good over the weekend.
Bob Harrison
Roland
Posted: Tue Jun 25, 2013 2:32 am Post subject: Re: Use of reserve tank |
Absolutely well said, Frans.
And also from me thank you very much for that exact description what happens with the main/reserve. I will keep that well in mind and notice it somewhere to have it at hand when the need arises - especially because I don't have such accurate fuel gouges than you.
Bob, thanks for the tip to taper the fuel inlet when parking in rain.
Roland
PH-ZTI
XS Trigear 914
Posted: Tue Jun 25, 2013 2:34 am Post subject: Use of reserve tank |
Hi! Frans,
You are welcome to hear of my learning experiences my philosophy is like
landing gear up "there's those that have done it and those that will".
My insurance is to have the long range tank and as you are well aware I
therefore fly slower, but I just dropped my carb needles back to where they
were fitted the spats and now fly more efficiently, I'm wishing I had done
that before our North Cape trip!
Bob H .
PS any photos yet ?
Posted: Tue Jun 25, 2013 2:47 am Post subject: Use of reserve tank |
On 06/25/2013 12:33 PM, Bob Harrison wrote:
| Quote: | My insurance is to have the long range tank and as you are well aware I
Yep, I guess the extra fuel has been costing you almost as much as a
carb overhaul.
| Quote: | PS any photos yet ?
Ilona is working on it right now. We made (oh no, "took") so many
pictures that it is quite a job to make a selection.
(thanks for teaching us some proper English ).
Frans
Posted: Tue Jun 25, 2013 5:06 am Post subject: Use of reserve tank |
I advance the throttle about half also, and it fired right up. It seems easy to keep my left hand on the stick after switching on, push the nose down and right hand on the throttle to start.
Kevin
On Jun 25, 2013, at 3:10 AM, "Bob Harrison" <ptag.dev(at)talktalk.net> wrote:
just instantly.
Bob Harrison G-PTAG
kpeng
Posted: Tue Jun 25, 2013 6:43 am Post subject: Use of reserve tank |
Guys
The only reason for being that low on fuel is if some other aircraft has put bullet holes in your tank
Kevin
On 25 Jun 2013, at 11:00, "Frans Veldman" <frans(at)privatepilots.nl> wrote:
> This talk about
> In 14 years of
> of fuel.
fuel left?
useless fuel?
Frans
