Boeing switches
woxofswa
PostPosted: Tue Jul 02, 2013 9:50 am    Post subject: Boeing switches Reply with quote
Greetings. I am trying to infuse a couple of little touches of my day job into my RV-10 project. To that end, I have purchased the yoke of a B737 and cut off the uprights to use as the stick grips of my -10.
I would obviously like to use the original Boeing pitch trim, PTT, and A/P disconnect switches if possible for the left upright. I will just wire in off the shelf switches for the right one.
The PTT, and A/P disco should be easy, but the Pitch trim might be a problem. Boeing uses a two part switch mechanism and there are four leads that come from the module. Here is the wiring diagram from the trim module itself.
What I am trying to do is interface these four leads into a Safety Trim three lead connection. Keeping the split switch capability would be okay, but not necessary.
Any comments or suggestions would be greatly appreciated.
Myron Nelson
Mesa, AZ
Flew May 10 2014
peter(at)sportingaero.com
PostPosted: Tue Jul 02, 2013 11:36 am    Post subject: Boeing switches Reply with quote
Myron,
Without the logic backing up how this is connected its difficult to
suggest how to use both switches. I would connect common ground (pin 7 I
think) to WHT/Vxx (connected to A1 & A3) and the trim up/down inputs to
B3 (WHT/GRN I think) and to B1 (WHT/BLU/ORN?), leaving the WHT/RED not
connected. You would be using the top switch only, but I don't think
that's a problem in service.
Regards, Peter
I would obviously like to the Boeing pitch trim, PTT, and A/P disconnect switches if possible.
The latter two should be easy, but the Pitch trim might be a problem. Boeing uses a two part switch mechanism and there are four leads that come from the module.
(http://s125.photobucket.com/user/myronnelson/media/photo_zpsfd9c6ca8.jpg.html)
Myron Nelson
Mesa, AZ
Emp completed, QB wings completed, legacy build fuse on gear. Finishing kit and FWF kit in progress.
http://forums.matronics.com/viewtopic.php?p=403817#403817
edpav8r(at)yahoo.com
PostPosted: Tue Jul 02, 2013 6:12 pm    Post subject: Boeing switches Reply with quote
Myron,
What is the pinout of the Safety Trim 3-lead connection (i.e. what inputs does it require from the switch)? I presume there's a common ground and one pin each for trim nose up and trim nose down. Can you confirm?
Can we get a clearer photo of the switch module legend?
It may be possible to accomplish what you want with relays, or some 4000-series logic ICs, or a simple micro-controller.
I presume your preferred outcome is to retain the "both switches must be closed" logic for the trim switches, as in the Boeing.
Eric
Myron Nelson
Mesa, AZ
PostPosted: Tue Jul 02, 2013 7:11 pm    Post subject: Boeing switches Reply with quote
Myron,
After looking at this a little more, I have to agree with Peter. I was definitely over-thinking it!
The "both switches must be closed" logic is internal to the module. They simply have the two thumb switches wired in series.
Peter's advice below should work.
Eric
On Jul 2, 2013, at 2:35 PM, Peter Pengilly <peter(at)sportingaero.com> wrote:
Myron,
Without the logic backing up how this is connected its difficult to suggest how to use both switches. I would connect common ground (pin 7 I think) to WHT/Vxx (connected to A1 & A3) and the trim up/down inputs to B3 (WHT/GRN I think) and to B1 (WHT/BLU/ORN?), leaving the WHT/RED not connected. You would be using the top switch only, but I don't think that's a problem in service.
Regards, Peter
PostPosted: Wed Jul 03, 2013 7:26 am    Post subject: Boeing switches Reply with quote
At 10:11 PM 7/2/2013, you wrote:
Myron,
Eric
The split trim switch and the recommended wiring
is a prophylactic against trim runaway caused by
failure of a single switch - i.e. both switches
CAN be operated as a single switch for normal
operations but BOTH switches have to fail to
produce a runaway condition. This technique has
been used on a host of electric trim systems.
Further the switches can be operated independently
of each other for pre-flight check of integrity
for the opposite switch. Wiring as recommended
honors the legacy failure mode effects analysis
which I've discussed in detail here.
http://tinyurl.com/lpvth8d
woxofswa
PostPosted: Wed Jul 03, 2013 9:47 am    Post subject: Re: Boeing switches Reply with quote
Thanks for the input. I'll try the suggested method. The Safety Trim gives runaway protection so I'm not so concerned about maintaining that from the switch itself.
I haven't delved into the PTT or A/P disco yet, but hopefully those should interface easily.
Myron Nelson
Mesa, AZ
Flew May 10 2014
Eric M. Jones
PostPosted: Thu Jul 04, 2013 4:29 am    Post subject: Re: Boeing switches Reply with quote
My two cents:
Using two parallel switches to prevent trim runaway seems boneheaded, and wouldn't stand a thorough engineering fault-tree review. Furthermore I'd bet that it never prevented ANY problem from occurring.
Sure, I understand the intention, but I don't think it's good engineering.
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
PostPosted: Thu Jul 04, 2013 6:29 am    Post subject: Boeing switches Reply with quote
At 07:29 AM 7/4/2013, you wrote:
My two cents:
Whether or not a problem was demonstrably
prevented is irrelevant to the reliability
study. Good FMEA mitigation assumes that the
part WILL fail. Working out a logical means
by which single failures might go undetected
for no more than a single tank full of fuel
has been a time-honored legacy design goal.
they are not used in PARALLEL. In the Boeing
case, they are in series with one side controlling
direction, the other side in SERIES controlling power.
Each side can be explored for functionality
in pre-flight, neither side capable of causing
a runaway-by-sticking.
Beech (and many others) uses the two spdt
switches to handle one half of a PM motor UP-OFF-
DN switching duty. Again, both sides easily
evaluated in pre-flight, neither side capable
of causing a runaway-by-sticking.
Lear (and many others) uses the 'coolie hat' to
drive relays that DID offer a possibility for runaway-by-
sticking. But their systems architecture included
a wheel-master-disconnect that removed power from
all trim systems along with the autopilot. I AM
aware of trim runaways in aircraft fitted with
wheel master disconnects that would not have happened
if the airplane had been fitted with the split
trim switch where the WMD switch provided the
mitigation.
jay(at)horriblehyde.com
PostPosted: Thu Jul 04, 2013 10:05 am    Post subject: Boeing switches Reply with quote
Good argument Bob.... I use a switch on the panel to power the trim, but
that may be a bit far away for a quick reaction, before the trim lurks all
the way to the end.
Jay
PostPosted: Thu Jul 04, 2013 2:22 pm    Post subject: Boeing switches Reply with quote
the way to the end.
You would do well to deduce the severity of a
trim runaway. Is the airplane controllable with
full trim either up or down? How fast does the
trim run with respect to pilot reaction times
needed to deal with a runaway? Are there stops
or limits to trim excursion necessary for the full
range of CG envelopes or will the system produce
more pitch authority than would ever be necessary
for normal operations?
In a Lear, at Mach cruise, the system is manually
failed and the pilot is obligated to keep hands in
the lap for 3 seconds. Only then can he move to
deal with the situation. After achieving a stable,
safe condition, recorded data is analyzed for
busting limits on attitude, altitude and airspeed
excursions.
The exercise is repeated and trim speeds then
adjusted until a sweat-free, runaway recovery
is assured.
The trim systems I've seen in some TC aircraft
are so slow that unexpected trims under worst
case conditions are no big deal. But what's the
story for YOUR airplane?
Yes, if trim speeds are brisk, trim authority high
and you have good reason for not reducing them, then some
form of inarguable override is indicated. Instructing
the pilot to pull a breaker for taming a trim runaway
is generally not acceptable . . . even panel mounted
switche situated amongst other switches will get
you frowns from the human factors guys.
At the same time, find out just how much risk is
associated with an uncontrolled trim event and
see if that can be engineered out as opposed to
stacking emergency ops hardware on top of the
design.
PostPosted: Mon Jul 08, 2013 12:33 am    Post subject: Boeing switches Reply with quote
That is exactly what I will be doing once the aircraft is flying; testing
how heavy the control forces are with the trim at either limit; on a
'step-by-step' basis until full travel is reached- then I can decide if any
further circuitry is merited, or perhaps a change in the mechanical trim
arrangement. That is what I like so much about OBAM aircraft; with a bit of
careful observation and rational thinking we can determine and apply the
solutions ourselves..
Jay
