Posted: Fri Jul 05, 2013 5:09 am Post subject: Master/Battery/Alt Field vs. Master/Battery and Alt Field. |
At 02:16 PM 7/4/2013, you wrote:
I'm sure I read a discussion of this question somewhere but can't find it.
I'm building an RV-9A, basic day/night VFR. I'm using the Basic
Day/Night VFR system diagram available from B&C website. It is
almost identical to the Z-11 diagram in Bob's book. One difference
is that the Z-11 uses a 2 poll 3-throw switch (2-10) for the master,
so that the alternator can be switched on after start. The Basic VFR
diagram from B&C uses a 2 poll 2 throw switch (2-3) so that the
alternator field is on during start.
What are the advantages of isolating the alternator field during
startup? My airplane has a B&C 40 amp alternator. Which approach
would you recommend?
None. The choice of switches depends on
how you plan to disable the alternator during
battery only operations. If you have a field
supply breaker that can be pulled, then the
simple 2 pole, 2 throw switch is fine. If
you've gone the crowbar ov protection route
then the breaker should be present.
Alternatively, the 3-position switch duplicates
the legacy control philosophy that allows a
battery to be turned on without the alternator . . .
like the split rocker switch.
mburbidg(at)gmail.com Guest
Posted: Fri Jul 05, 2013 8:34 am Post subject: Master/Battery/Alt Field vs. Master/Battery and Alt Field. |
I'm using the LR3C-14 external regulator and fuse blocks from B&C. My field supply includes a fuse in my fuse block but I cannot pull the fuse during flight.
It sounds like I should either move the field supply to a breaker on the panel that I can pull, or use the 3-position switch.
Another question. All of my 250 hours of flight are in a 1959 C172, which has a generator. There is a master switch with two positions. My question is under what conditions would one operate "battery only"?
Thanks for the help,
Michael-
On Jul 5, 2013, at 6:08 AM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> wrote:
> I'm building an RV-9A, basic day/night VFR. I'm using the Basic Day/Night VFR system diagram available from B&C website. It is almost identical to the Z-11 diagram in Bob's book. One difference is that the Z-11 uses a 2 poll 3-throw switch (2-10) for the master, so that the alternator can be switched on after start. The Basic VFR diagram from B&C uses a 2 poll 2 throw switch (2-3) so that the alternator field is on during start.
> What are the advantages of isolating the alternator field during startup? My airplane has a B&C 40 amp alternator. Which approach would you recommend?
