		Fred Klein
				 Posted: Thu Jul 04, 2013 9:12 am    Post subject: windscreen de-fogging |
				Gentlemen,
 I'm attempting to select a couple of computer fans to be mounted louvers in the top of the instrument panel module for the purpose of de-fogging the windscreen...I'm uncertain as to what cfm ratings or sizes will do the job.
 If anyone can pass on their experience w/ what amount of airflow is sufficient...or insufficient...I'd be grateful
 I suspect that my local climate in the Pacific NW of the US is similar to conditions in UK.
 Thanks in advance,
 Fred
 A-194
				 Posted: Thu Jul 04, 2013 9:43 am    Post subject: windscreen de-fogging |
				On 07/04/2013 07:12 PM, Fred Klein wrote:
  	  | Quote: | 	 		   I'm attempting to select a couple of computer fans to be mounted
 I did that too, and despite our damp climate I have used them only twice
 (and found out that they didn't contribute much anyway).
 You'd probably better save the weight.
 Frans
				 Posted: Thu Jul 04, 2013 9:59 am    Post subject: windscreen de-fogging |
				Fred Klein a écrit :
  Gentlemen,
 Hi Fred,
 Here is what we did recently :
 http://contrails.free.fr/cellule_defog_en.php
 Not much weight involved (about 700-800 g) though we feel that our 380
 kg four seater is a bit on the heavy side
 FWIW,
 Best regards,
 Gilles
		rparigoris
				 Posted: Thu Jul 04, 2013 10:12 am    Post subject: windscreen de-fogging |
				Hi Fred
  	"If anyone can pass on their experience w/ what amount of airflow is sufficient...or insufficient"
  	I chose to use four 12 volt mini fans. They are run off a 3 position (low, high and off). If 2 are put in series it's low, and if run off bus voltage, then high. Yes idea as a minimiist demister but also to get heat out from under instrument module. You can find info on what I am doing (I did quite a bit of fooling with different fans. There is also a folder on that page "Panel cooling and demisting ideas by others."
  	http://www.europaowners.org/main.php?g2_itemId=27305
  	I am installing temp probes under the instrument module so will be able to see temps.
  	Ron Parigoris    [quote][b]
		budyerly(at)msn.com Guest
				 Posted: Thu Jul 04, 2013 11:35 am    Post subject: windscreen de-fogging |
				<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]-->  Ron,
  I installed both 40 mm and 80 mm computer CPU fans and frankly, the 40s  don't move that much air.  The 80s do better at venting the hot air out of  the panel.  Some electronics get quite warm and I wanted to cool the panel,  not really defrost.  That was a hopeful side effect of the installation of  the fans.
  The first setup on 12AY I put the fans too far forward and they blow  into the windscreen support.  To be honest, I can't even feel the air flow  moving up the windscreen, it moves sideways.  That was a dumb execution of  a good idea.
  On others, I move the fans as far aft toward the pilot as I can  to pull the Garmin 430 and Dynon Skyview heat out of the panel.  They both  get pretty hot.  I have found that the air comes up the windscreen, but is  not hot enough or fast enough in the winter to feel like a defogger, but at  least it moves the air up the windscreen.  If you have an Ameriking type  cooling fan, one leg of that would be about as strong as my two 80s...
  The Grand Rapids and Becker radios are pretty cool running and frankly the  panel only gets about 10 degrees warmer than the cockpit, so without the heat  and high forced air flow of an auto type defogger, I do not see it as much help  on a cold day at altitude with a quick descent to the warmer air below steaming  things up.
  Sorry I don't have more info for you.  It's just too hot here in  Florida.  Even in the winter, although my canopy top fogs up and my screen  fogs for a second or two, they both clear once the inside and outside  temps stabilize.
  Bud
  [quote]   ---
		kevinmarie(at)blueyonder. Guest
				 Posted: Thu Jul 04, 2013 11:40 am    Post subject: windscreen de-fogging |
				I have no fans and it gets a little fogged up on the ground in the winter but I open the door and it clears. I never have any problems in the air and I have no heater.
 Kevin Challis
 G ODJG
 Tri gear 912s
 On 4 Jul 2013, at 19:12, Fred Klein <fklein(at)orcasonline.com> wrote:
  Gentlemen,
  Thanks in advance,
  Fred
  A-194
		rampil
				 Posted: Fri Jul 05, 2013 3:32 pm    Post subject: Re: windscreen de-fogging |
				i have read the discussion on the issue of defogging and it appears that
 are no actual answers out there yet regarding airflow, temperature, etc.
 I will add my meager data to the pool
 My bird has a Blue Mountain EFIS 4 series which shuts down at temps
 above abt 144F. I have a 24 cfm fan in a convective tower directly
 above the EFIS leading into a 3 in louver directed into the plexi.
 On a 90F sunny day as so many local days are here on Long Island,
 without the fan, the EFIS will blackout within an hour of the plane out
 of the hangar, flying or not. The installed fan slows the inexorable rise somewhat
 say by 15 min to overheat. Clearly unacceptable cooling. However,
 it has actually cleared plexi condensation in two instances where it existed,
 in about 5 minutes (this was light grey mist, not dripping condensation).
 As I contemplate my move to much warmer clime, i will need to
 re-engineer the cooling. These little muffin fans are not likely to be useful
 even if ganged together. High velocity outside air is probably the best answer. Actual flight testing is needed.
 As usual, your mileage will vary
 Ira
		craigb(at)onthenet.com.au Guest
				 Posted: Fri Jul 05, 2013 5:32 pm    Post subject: windscreen de-fogging |
				You might want to try a couple of the 12v brushless DC fans, they range in
 size from 30mm up to about 200mm
 They move a lot of air for their size, like the ones you find in your
 computer to ventilate the case
 I had two network file servers running inside a closed cupboard total load
 of about 1000w with a hole in the bottom
 Back of the cupboard and one 100mm brushless DC fan to extract the air at
 the top and didn't have an issue with them overheating
 Worth a look at least, they normally run about $10 each, or free if you can
 get your hands on a couple of old computers and pull them apart
 To get the fans out of the power supply's
 http://www.ebay.com.au/itm/2x-Brushless-DC-Cooling-Fan-12V-120mm-x-120mm-x-2
 5m-/180729347608?pt=AU_Components&hash=item2a144efe18
 this link just goes to one I found on ebay no doubt you could find your own
 regards
 craig
				 Posted: Fri Jul 05, 2013 10:48 pm    Post subject: windscreen de-fogging |
				Ira, I have a comparable system to keep my Blue Mountain
 EFIS happy, although my fan has inlet above pax feet and
 outlet through a dozen holes blowing on to pilot screen.
 Moderately effective as demister, but EFIS starts to
 complain when temps get up into vicinity of 35C (95 in
 your old units). I have found that laying a layer of 5mm
 neoprene with foil on one side, across top of panel (which
 is painted dark blue for visibility) cuts out direct sun
 heating and addresses the problem. So I have that Neoprene
 sheet available in the back and use it intermittently in
 exceptionally hot conditions
 Regards, David Joyce, G-XSDJ
 On Fri,  5 Jul 2013 16:32:15 -0700
   "rampil" <ira.rampil(at)gmail.com> wrote:
 it appears that
 temperature, etc.
 down at temps
 tower directly
 the plexi.
 Long Island,
 of the plane out
 However,
 need to
 needed.
  Ira
  Ira N224XS
  http://forums.matronics.com/viewtopic.php?p=404012#404012
 Un/Subscription,
 Forums!
 Admin.
		Duncan McFadyean
				 Posted: Sat Jul 06, 2013 12:50 am    Post subject: windscreen de-fogging |
				I took an air feed off the top of one of the side NACA ventilators,
 primarily to squirt cool air over the back of the Terra transponder (which
 (and the radios too) don't appreciate being cooked behind the standard
 sealed Europa panel). There are slots cut in the top of the panel below the
 bottom of the windscreen. It's not foolproof for demisting on the ground
 (but a wiping cloth is!), but it does keep mist cleared in flight. I had one
 computer fan previously, which worked similarly, but I took it out (heavy,
 noisy, power consumer).
 DMcF.
		rampil
				 Posted: Sat Jul 06, 2013 3:13 pm    Post subject: windscreen de-fogging |
				The 120mm brushless dc fan I linked to yesterday was supposed to move 25 CFM
 and draw about .4 of an amp
 Noise level 25db doesn't say what the weight is, but past experience I would
 say it would be around 100g
