		rickofudall
				 Posted: Tue Jul 09, 2013 6:40 am    Post subject: Transitioning to the Mk III |
				Dennis Kirby, all, For pilots transitioning from GA to a Kolb Mk III I made this video to help several years ago. Look at how the position of the horizon on the windscreen changes with flap setting.Hope this helps.
  http://www.youtube.com/watch?v=mQ-YaW9WgEU
 Rick Girard
 Zulu Delta
 Mk IIIC
  Thanks, Homer GBYM
 It isn't necessary to have relatives in Kansas City in order to be unhappy.
   - Groucho Marx
		Ralph B
  Joined: 14 Apr 2007 Posts: 367 Location: Mound Minnesota
				 Posted: Tue Jul 09, 2013 7:20 am    Post subject: Re: Transitioning to the Mk III |
				Rick, you know how to land a Mark III. Good job!
 Ralph B
  _________________ Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
		Larlaeb
  Joined: 02 Apr 2013 Posts: 75 Location: League City, Texas  United States
		Ralph B
				 Posted: Tue Jul 09, 2013 12:06 pm    Post subject: Re: Transitioning to the Mk III |
				"Larlaeb"
  	  | Quote: | 	 		  In addition I've noticed that with additional weight forward (passenger) that  elevator authority is different and changes the flair timing and stick movement a bit.
 Allan |
 You sure got that right. The Kolbra is a different airplane with a passenger. The sink rate increases dramatically and the stall is higher. The majority of my flying these days is carrying my wife who runs the camera from the back seat (she also is a "back-seat driver"). I flew it solo yesterday and it climbed like a Firestar. I did six takeoffs and landings and forgot how to land solo. Not that the landings were poor, but I had to compensate for the lack of weight.
 Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
				 Posted: Wed Jul 10, 2013 2:06 am    Post subject: Transitioning to the Mk III |
				I found these videos very helpful during my transition, I probably watched
 them 20 or 30 times.
 Hi
 You are making a mountain out of a molehill. I changed from a Challenger to
 a Mk111 Xtra.in a couple of days.
 The obvious change is tricycle to tail dragger. Tricycle is so much better
 in every way it amazes me that anyone bothers with taildraggers. Steering is
 accurate and precise without having to bother with differential brakes. Side
 winds problems are much reduced with easily controllable weathercocking..
 That said there is something romantic and `veteran` about a tail dragger
 that I .like or I would not have bought the Xtra.
 Hold the stick right back when taxying and point the stick into wind.
 Taxy around your field until you can point the plane in the right direction.
 Do a couple of runs along the runway until you can lift the tail (gently)
 and balance   on the mains.Find the trim position. When you can keep
 straight and on two wheels just set up the longest run you can, select one
 notch of flap, open the throttle SLOWLY or she will swing, until you are
 flat out. and go for it.
 It will be obvious when she wants to fly, don`t mess about watching the ASI,
 just let her lift off. Climb at full throttle at about 50ish. Its not that
 critical, just don`t get slow.Take the flap off at around 5/600ft
 Get 1000ft on, throttle back, play with the trim and get used to the flying
 position. Do some gradually steeper turns in both directions and just play
 with it for half an hour. Check the indicated stall speed with one notch of
 flap.which is what you will use for landing.
 Landing.
 Set up your approach giving yourself plenty of room. No steep turns in the
 circuit. Circuit height is probably around 700ft agl.
 Reduce power and trim for about 50. on the downwind The change in attitude
 is not great but.the nose will tend to lift as the power comes off. I never
 did a flapless landing, why would you?. You want increased lift at decreased
 speed when landing. Thats what flaps are for. One notch flaps,watch for
 attitude change, trim out for 50/55. Turn final . I alaways cut the throttle
 when the field is made. Let the plane sink until the blur of the grass
 changes and you can see individual blades of grass. Flare and try to keep
 the plane in the air, just off the ground as long as possible.
 She will eventually stall and you should be a few inches off the ground at
 that point. You have a perfect three pointer.
 KEEP THE STICK BACK and apply brakes if you must, but GENTLY.
 Raise the flap and taxy in.
 You will not need more than one notch of flap except in an emergency .She
 REALLY comes down steeply if you do.
 One more thing. If you sideslip and there is really not much point as the
 flaps will drop you quite quickly enough watch for a slight lift of the
 nose. The sideways motion of the air across the curved nose produces a bit
 of lift. No problem, just be aware.
 Good luck
 Pat
		Larlaeb
