donjohnston
Posted: Tue Jul 16, 2013 8:26 am Post subject: Combining alternator wires? |
I've looked through the archives because I'm sure this is in there, but I can't find it.
I've got a Velocity-XL, 28v system, single battery (up front), dual alternators (60a & 20a). The battery and starter contactors are both up front next to the battery.
With respect to the B-leads from the two alternators, does each one need to have a separate wire up to the nose? Or can I install a single wire from the firewall to the front that both alternators can tie in to? If I can do the single wire approach, would all three wires need protection with ANL current limiters, or just the two lines from the alternators?
Posted: Tue Jul 16, 2013 8:47 am Post subject: Combining alternator wires? |
If it were my airplane, the starter contactor
would be as close as practical to the starter
on the firewall.
The starter contactor becomes a fat-wire tie
point to bring alternator b-leads to the bus
by tying their current limiters to the hot side of
the contactor.
So yes, the single wire approach
works for all three devices . . . a wire which
you already have in place.
donjohnston
Posted: Tue Jul 16, 2013 10:19 am Post subject: Re: Combining alternator wires? |
the contactor. |
Thanks!
Follow up question: I can't find a 20a current limiter for the backup alternator. B&C only has them down to 40a. Do I use a regular 20a CB? Or look elsewhere for a 20a current limiter?
Posted: Tue Jul 16, 2013 2:13 pm Post subject: Combining alternator wires? |
> the contactor.
Thanks!
Use an ATC inline fuseholder with a 30
A fuse in it.
http://tinyurl.com/lusgrmw
I have these for sale at:
http://tinyurl.com/cgr42l5
you might find them in a local automotive
parts house.
steve(at)tomasara.com Guest
Posted: Wed Jul 17, 2013 6:46 am Post subject: Combining alternator wires? |
Don J. said:
Quote: | With respect to the B-leads from the two alternators, does each one need to have
Bob K. replied:
on the firewall.
the contactor.
If it were my airplane (and this is the way I layed it out in my LongEz
though I have yet to bother installing a starter and it's a single
alternator configuration):
I would put the ANL and both contactors up in the nose. The ANL in my
installation is to protect against current flowing out the battery to a
short in the wire going back to the alternator(s). The alternator(s)
themselves current limit to a degree much more than a battery does.
This wire only has to be sized to match the needs of the alternators.
The fat starter wire is only live when the starter is being activated.
The "cost" of this approach is the weight of the separate alternator
wire, the benefit to me was eliminating the un-protected, always hot
when the master is on, large wire running the whole length of the
aircraft. Acceptable though this may be, I wasn't comfortable with it.
A minor side benefit is that I had a better place to put the ANL and
starter contactor up in the nose than back on/near the firewall.
Boulder/Longmont, Colorado
Restoring (since 1/07) and flying again (8/11!): N45FC O235 Longeze
Cothern/Friling CF1 (~1000 Hrs)
Flying (since 9/86): N43732 A65 Taylorcraft BC12D
